quick question rear axle - JeepForum.com
post #1 of 15 Old 09-10-2021, 03:43 PM Thread Starter
jay-h
I was messing with my brakes today, and I noticed that the axle shaft (non C clip) has a little bit of end play (maybe .030). No other signs of trouble (noise, leakage, no radial play). Is this typical? Bearings were replaced a few years ago.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #2 of 15 Old 09-11-2021, 01:32 AM
YJ40
YJ40's Avatar
Check the mounting plate behind the bearings, with the 4 boltholes,sometimes they bend...
89´YJ 4.6l
94´YJ 4.0l
YJ40 is offline
post #3 of 15 Old 09-11-2021, 03:47 AM Thread Starter
jay-h
I've not seen the bearing. Is it a straight roller bearing? I'm guessing it's not tapered or ball?
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #4 of 15 Old 09-11-2021, 03:52 AM
YJ40
YJ40's Avatar
Non c-clip should look like this...
89´YJ 4.6l
94´YJ 4.0l
YJ40 is offline
post #5 of 15 Old 09-11-2021, 04:13 AM
YJ40
YJ40's Avatar
Installed you cant see the bearing,only the retaining plate with 4 bolts.
89´YJ 4.6l
94´YJ 4.0l
YJ40 is offline
post #6 of 15 Old 09-11-2021, 06:15 AM Thread Starter
jay-h
thanks
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #7 of 15 Old 09-12-2021, 01:43 PM
fishadventure
fishadventure's Avatar
I don’t think 030 is an issue.
I actually don’t recall if there’s a spec but that would seem normal to me, eh, @Boojo35 ?
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #8 of 15 Old 09-13-2021, 05:52 AM Thread Starter
jay-h
Sounds good, I'm thinking that it might be ok.. For all I know it could have been this way for years. I will have my mechanic guy take a look today. (I'll be taking it on a bit of a trip at the end of the month, so that's why I'm checking so carefully)
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #9 of 15 Old 09-13-2021, 06:24 AM Thread Starter
jay-h
I talked to the mechanic. He said that a little end play was common in these, not really a worry.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #10 of 15 Old 09-18-2021, 01:52 AM
80cj
80cj's Avatar
1980 CJ5
My Friend has a 94 (I believe) and we could grab the rollbar and shove sidewards back and forth and hear the axles making a clunking sound against the thrust block in the diff. Did that off road too. No harmful effects that we could notice.
80cj is offline
post #11 of 15 Old 09-21-2021, 03:02 AM
YJ40
YJ40's Avatar
Non c-clip axles have tapered roller bearing. C-clip axles have different bearing design,cylindrical roller (like your friends 94), so end play is not big problem.
On a tapered roller bearing every little play reduces the contact surface and leads to wear.
The more play,the less contact surface...
89´YJ 4.6l
94´YJ 4.0l
YJ40 is offline
post #12 of 15 Old 09-21-2021, 06:07 PM
Boojo35
1987 YJ Wrangler
I have popped in and out on this thread a few times and tried to find a spec for this. I cannot find one and if anybody could, I have a chance of being that guy. It is how I roll. Being that the axle bearing is tapered as @YJ40 mentioned, it should be pretty damn tight. I fully agree that the mounting plates will probably bend with normal wear and tear and should be replaced. Tapered roller bearings need preload for the reasons he stated. My experience tells me that they are more forgiving when on the looser side like in certain uses like the front brake rotors on older RWD vehicles. However. Differential pinion bearing preload is a place where it will bite you in the a$$ quickly. There is probably more deflection there than in any other place due to gear ratios and their effects on leverage. Differentials are what really taught me the importance of preload on tapered bearings. Play in them is just not a good thing. The bearing no longer works as designed and actually fails very quickly in some instances.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #13 of 15 Old 09-22-2021, 07:02 AM Thread Starter
jay-h
The weird thing is, there seems no mechanism for adjusting a preload here. No wheel nut (and usually preloaded tapered bearings are mounted in opposite pairs), just a non precision plate which sandwiches the bearing between the oil seal on one side and the pressed on collar on the other. That's kind of all there is. In actual fact, unless I am really missing something, the only thing holding the axle in place is a pressfit between the inner race and the axle.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #14 of 15 Old 09-22-2021, 12:41 PM
80cj
80cj's Avatar
1980 CJ5
Tapered roller bearings don't necessarily require preload. A good example is the tapered roller bearings used in tapered axle setups like stock AMC 20's and Dana 44's as used in early CJ's. In these axles there is a .004-.006 endplay spec that must be adhered to. When properly installed, you can grab the axle shaft and actually shake it up and down/ shove it in and out a minute amount. This endplay spec takes into account expansion of axle shafts from temperature and prevents the bearings from being overloaded due to thermal expansion. In differential setups carrier bearings and pinion bearings are given a pre-determined amount of preload to control gear deflection and compensate for wear, thermal expansion. Further, differentials are constantly bathe in a fairly large amount oil which helps keep temperatures under control.
The OP's bearings I think are set 9. This bearing type is self a contained unit bearing. In installation, the bearing is captured in the housing bearing cavity and the bearing controls end play within itself since the unit bearing has a "rib ring" to control end play on the non tapered side (that faces the axle flange) Because the bearing contains end play, the axle shaft is allowed to float in the differential, unlike the later C clip setup that needs a thrust block and C clip to retain the axle and control end play. I think .030 endplay in the OP's bearing is a little excessive. Compare it with a new bearing.
80cj is offline
post #15 of 15 Old 09-22-2021, 05:17 PM
Boojo35
1987 YJ Wrangler
@80cj I will totally buy into your explanation. Most of my diff experience is with c-clip type or full floaters as in tons. I know that you are a knowledgeable and competent diff guy. Thanks for sharing your knowledge.
Boojo35 is offline
