!Quick! 1991 Ax-15 Tranny Help !QUICK! - JeepForum.com
post #1 of 14 Old 10-14-2004, 05:21 PM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
Okay, so at work today I got out and hopped in my Jeep. Went to put it in reverse and it kind of slid into 4th so I'm like hmmm okay and pulled it back into N. As I pulled it into N I felt a weird pull like something moved. I went to put the jeep in 1st for grins and couldn't get into it. I played with the shifter a little bit and then tried a last ditch effort of putting it into Reverse again and as I did I felt another strange pull as I moved the shifter. Now I can only move the shifter an inch in any direction and into NO gears. We drug my jeep home behind my dad's truck, and we have it apart out in the barn. What is wrong, how can we fix it? Help is needed ASAP!!!! My dad was thinking maybe the shift forks shifted and it's stuck in between gears. If someone can verify this is what happened please advise on how to fix.
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #2 of 14 Old 10-14-2004, 05:29 PM
beddo
Guest
Does it shift into gear when the engine is off? If it does you might have a throw out bearing problem.
beddo is offline
post #3 of 14 Old 10-14-2004, 06:14 PM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
Shifter is locked completely. Won't move in any situation. Engine on/off. Clutch engaged/disengaged. Locked in place, won't shift left right up down or otherwise.
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #4 of 14 Old 10-14-2004, 06:17 PM
beddo
Guest
It sounds terminal. You could possibly rebuild it, but the easier and possibly cheaper route would be to call a junkyard. Good luck.
beddo is offline
post #5 of 14 Old 10-14-2004, 06:24 PM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
For the love of God someone please tell me it's not terminal. Read the last line of my signature. I just had this thing rebuilt from scratch and it cost me over 2,000.00 - I can't afford to rebuild it again. I better have some kind of warranty on this thing. I'll check into that, in the meantime ... someone .... anyone.... <help>,
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #6 of 14 Old 10-14-2004, 06:39 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
have you pulled the lever out of the shift tower yet? might just be something broken in there. but it doesn't sound good regardless.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #7 of 14 Old 10-14-2004, 06:58 PM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
I pulled the shift boot off and removed the shift lever from the tower. I then removed the top hatch on the transmission and looked down into it. There's a round hole that I can stick things in and try and move it around but it's seized up good. We looked at it awhile and stared down into the nothingess to see just that... nothingness. I'm at a loss, the jeep sits in the barn yet again. Hopefully I won't be without it for another 3 months.
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #8 of 14 Old 10-15-2004, 12:53 AM
jeep75
Guest
is it possible that since you just had it rebuilt that possibly it could have been ran dry w/ no fluid in the trans? some shops aren't too bright. A friend just had her car engine burned up cause wal-mart forgot to put the oil drain plug in after the oil change so just a thought.
jeep75 is offline
post #9 of 14 Old 10-15-2004, 05:45 AM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
I suppose I can't rule it out, anything is possible, but there was fluid inside of it when we opened it up. The guy who did it was a friend of the family and he said that he put the best lube and fluid he could buy inside of it.
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #10 of 14 Old 10-16-2004, 12:47 PM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
It's official, I'm once again without a JEEP. I'm pulling the transmission out of it again and taking it into the shop. Here's to another 3 months without a JEEP CHEERS!
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #11 of 14 Old 10-16-2004, 12:54 PM
sjlplat
Guest
You can get a used AX-15 for cheap. Don't throw another $2k into that one. I've seen entire 4.0L drivetrains complete with tranny and t-case going for $1500 all over the place.
sjlplat is offline
post #12 of 14 Old 10-16-2004, 11:11 PM
fratis
fratis's Avatar
chances are your friend screwed it up. always gotta be wary of people trying to make an extra buck on the side by doing auto repair in their spare time. there is a big difference between a "mechanic" and a "parts replacer"
fratis is offline
post #13 of 14 Old 10-17-2004, 07:05 AM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
The guy who did the transmission work has been working on semi transmissions for 30 years. He owned his own transmission shop for 5 years afterwards and recently opened his own general maintenance shop. He knows transmissions, but I agree that I'd never have someone who 'kind of knew what part went where' do work on my rig. I always go where I know I'm getting it done right. He said it sounds like a shift fork came out of alignment.
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
post #14 of 14 Old 10-17-2004, 07:07 AM Thread Starter
Matusel3
Matusel3's Avatar
1977 CJ5
Last night we pulled the transmission out of it and we're throwing it in the back of the truck to haul it to the shop. I should know in a day or two what is wrong inside there. I'll keep the thread alive in case someone else should have a problem like this down the road, more people will know the culprit.
1977 CJ5
-258
-T150 3 Speed
-Dana 44 Rear Axel
Matusel3 is offline
quick tranny question LeftoverSalmon TJ Wrangler Technical Forum 1 01-28-2008 04:47 PM
quick carb & tranny Qs newYJfan YJ Wrangler Technical Forum 2 09-30-2007 11:22 AM
Quick tranny question kadmos TJ Wrangler Technical Forum 5 04-25-2007 05:18 PM
Quick Man. Tranny Question?? sdog30 TJ Wrangler Technical Forum 9 01-27-2006 11:50 AM
Quick tranny question DevilDogJeep YJ Wrangler Technical Forum 2 03-30-2004 02:02 PM
