Put together some DIY beadlocks for the YJ. Like how they turned out. - JeepForum.com
 7Likes
post #1 of 18 Old 02-21-2020, 10:50 AM Thread Starter
NotmyJK
Built a machine to weld and mill DIY steel beadlocks and the latest set turned out pretty nice. Pics posted out of order but it will work. Lol
87041737_522632041967380_4364696665576177664_n.jpg   82053687_703924566678223_7878094649460523008_n.jpg   82017840_1022092098189992_987877301674835968_n.jpg   86935792_328945184726894_2054746310417842176_n.jpg   86307390_608115483305866_9114822437869977600_n.jpg
87TPIYJ likes this.
2000 TJ sport
2008 Dodge dually
1972 Kaiser Jeep deuce and a half
2008 JK unlimited (wifes)
2001 Boxster (wifes)
1995 Ford F350 dually flatbed (wifes)
NotmyJK is offline
post #2 of 18 Old 02-21-2020, 11:06 AM
jhrebs
1987 YJ Wrangler
Iíve been thinking about doing there. I want bead locks so bad. Just canít spend that money. Iíve been eyeing up these https://www.totalmetalinnovations.com
But many people have said diyís leak. Donít go well on the road.
You made yours from scratch? How they handling?
Sent from my iPhone using Tapatalk
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #3 of 18 Old 02-21-2020, 11:16 AM Thread Starter
NotmyJK
I used a TMI kit. Ive built two other sets for buddys and they don't leak. I did build a machine that makes one continuous weld around the lip to avoid leaks. I also machine the weld flat to avoid leaks.
I now have 3 sets of beadlocks on different rigs and they all have balanced out well along with the sets I built for my buddys..
2000 TJ sport
2008 Dodge dually
NotmyJK is offline
post #4 of 18 Old 02-21-2020, 12:18 PM
grandboost98
grandboost98's Avatar
That's a pretty sweet setup you got there.
Heres my DIY recentered H1 double beadlocks with flat centers and PVC inserts. Haven't lost any air yet but I also haven't driven out of my driveway with them either so we'll see.
NotmyJK likes this.
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #5 of 18 Old 02-21-2020, 05:56 PM
NHfireLJ
NHfireLJ's Avatar
I used a TMI set and had leaks in 2 of the 5 rims.... Even had a welding shop do the initial welding... chased leaks forever... granted it took a week to leak down, but what a PIA.
They balanced OK. Heavy though....
I finally went with the Hutchinsons. Love em... Easy assembly and breakdown... And light. Do yourself a favor and buy them... No regrets
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #6 of 18 Old 02-21-2020, 06:17 PM
Waternut
Waternut's Avatar
Yeah I felt like I wouldn't be able to weld perfectly enough to keep the DIY wheels from leaking but I do love the look and the price of those DIY beadlock kits. Maybe one day.
Waternut is offline
post #7 of 18 Old 02-21-2020, 07:34 PM
Awesome
Awesome's Avatar
I love your homemade orbital welder.
NotmyJK likes this.
The 4th 5-seater YJ in the world.
Awesome is offline
post #8 of 18 Old 02-21-2020, 08:11 PM
jhrebs
1987 YJ Wrangler
$400 each?!?!
jhrebs is offline
post #9 of 18 Old 02-22-2020, 07:01 AM
NHfireLJ
NHfireLJ's Avatar
$400 each?!?!
Yup....
but lightweight, and they'll outlast your tires for years..
Also so easy to breakdown and reassmble... I did 3 tires / rims in the time it took to mount just one of the DIY lock set ups... They are 2 piece rims.
Sometimes you just need to vomit the cash... and don't look back...
SOLD
style intake
NHfireLJ is offline
post #10 of 18 Old 02-22-2020, 07:05 AM
jsawduste
2006 YJ Wrangler
Have made 2 sets.
One had a small leak but found and fixed it.
Downside is they are HEAVY. That added mass can play hell with axle shafts. Balanced out fine though.
Went to Racelines and they don't leak, lighter but if you want them to stay nice looking you have to keep them polished. Every couple years I replace the outer rings for a few bucks.
jsawduste is offline
post #11 of 18 Old 02-22-2020, 07:42 PM
TSEJEEPERS
TSEJEEPERS's Avatar
I went with TMI too. Yes they are heavy!
No leaks but went heavy on the RTV.
NotmyJK likes this.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #12 of 18 Old 02-23-2020, 04:44 AM Thread Starter
NotmyJK
I'm running Spyderlocks on my TJ and Allied Rockathons on my XJ. I have never had leaks on beadlocks bought or built. I have two more sets to build so knock on wood on that whole non leaking trend. Lol. When I was looking at beadlocks for the TJ, I looked at Hutchinsons but they didn't offer enough offset/backspacing to fit my 38x15.5 tires.
70626087_525577231585222_5391092573991337984_n.jpg   67186395_887545398310925_2480452933242585088_n.jpg
2000 TJ sport
2008 Dodge dually
NotmyJK is offline
post #13 of 18 Old 02-23-2020, 06:37 AM
jhrebs
1987 YJ Wrangler
I see raceline has steel beadlocks $266 each. And the same size I have now so no need for new tires. Their weight is 34 lbs. seems my cragars are around 25 lbs each. If you add the DIY beadlocks not sure which would be heavier. I cant seem to find the weight listed of other beadlocks. I think Iíll call TMI and ask the weight of their kits
jhrebs is offline
post #14 of 18 Old 02-23-2020, 07:50 AM
jsawduste
2006 YJ Wrangler
https://www.jegs.com/i/Cragar/260/3978812/10002/-1
37 lbs.
Not sure what size wheel your using but this came in for a 17" x 8"
Searched around but could not find a BL kit weight.
post #15 of 18 Old 02-23-2020, 08:09 AM
jhrebs
1987 YJ Wrangler
15x8. Is what I have now. I would either need DOT legal or a separate set. I donít need DOT for legalities. But I heard the ride is better. DOT seems to be at least $400. Not sure this will be feasible in the near future. So many more important projects. Tummy tuck, roll cage, snorkel.
jhrebs is offline
