Purpose of this tie rod "handle"? - JeepForum.com
 8Likes
  • 3 Post By jbolty
  • 1 Post By Waternut
  • 1 Post By bhartwell59
  • 1 Post By Red88
  • 1 Post By fishadventure
  • 1 Post By bpounds
post #1 of 8 Old 04-12-2019, 09:20 AM Thread Starter
bhartwell59
1987 YJ Wrangler
Anyone know the reason for this handle thing in the red ellipse?
Trying to do my steering alignment and it's in the way... is it actually needed?
Thnx!
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline
post #2 of 8 Old 04-12-2019, 09:35 AM
bharris68
Gravel Truck Pilot
When I've crawled under my jeep to hammer on ball joints for changes and the like, I recall that the fork or rod is positioned so that rocks and road debris don't smash up your threads or screw up your alignment nuts.
There could be a more specific reason, but that was my offhand observation I suspect a lot more intelligent folks that do this for a living can either confirm or refute my hypothesis
bharris68 is offline
post #3 of 8 Old 04-12-2019, 09:57 AM
jbolty
jbolty's Avatar
It appears to be there to keep the adjuster sleeve from turning on it's own since it rides in the groove.
Mr.B, bharris68 and Azhunter1 like this.
jbolty is offline
post #4 of 8 Old 04-12-2019, 10:31 AM
Waternut
Waternut's Avatar
It fits too well in the adjustment sleeve. It might serve a dual purpose but I always assumed it was a safety feature to ensure the tie rod doesn't loosen.
Makes it really hard to adjust the tie rod so I cut it off and made sure the nuts were tight.
bharris68 likes this.
Waternut is offline
post #5 of 8 Old 04-12-2019, 11:40 AM Thread Starter
bhartwell59
1987 YJ Wrangler
Yeah, there's no grooving/threading so it just seems superfluous. Riding in the groove of the adjusting sleeve is what I thought too... but it doesn't REALLY fit in the groove. So long as the adjusting sleeve nuts are tight things should be good.
post #6 of 8 Old 04-13-2019, 10:24 PM
Red88
Red88's Avatar
It is to help keep the tie rod adjuster from turning. All you have to do is remove the bolt that holds it down and it will slide out of the way. There is a slot in the tie rod that the bolt passes through so you have to line it up when reinstalling. This is the first rig I have seen them on but I kept mine as it was put there for a purpose.
Red88 is offline
post #7 of 8 Old 04-14-2019, 06:05 AM
fishadventure
fishadventure's Avatar
It is a convenience/safety feature as mentioned ^^^^
I’m unclear how that it’s in the way?
Imho I wouldn’t remove it. While admittedly it’s nowhere near as “serious” I wouldn’t remove it any sooner than I’d remove my pitman arm nut or any of the cotter pins in the tie rod ends.
Chrisnvegas likes this.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #8 of 8 Old 04-14-2019, 05:48 PM
bpounds
bpounds's Avatar
I've always considered it a keeper, like any cotter pin or safety wire. I believe this assembly has right and left hand threads, so turning the adjuster sleeve makes a fast adjustment of toe-in. Having that turn unintentionally would not be a good thing.
Bill
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2" lift + 1" BL + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
33s hit the tie rod ends cruisingram TJ Wrangler Technical Forum 14 04-23-2019 05:07 PM
Drop pitman arm and/or tie rod flip? Waternut YJ Wrangler Technical Forum 7 04-24-2018 05:32 PM
HD y-link tie rod end help Psyclops YJ Wrangler Technical Forum 16 04-08-2018 02:44 PM
Tie Rod ends *stuck* BaODaLaZi WJ Grand Cherokee Forum 4 03-12-2018 08:06 AM
Finding a Bad Tie Rod BorderWalker ZJ Grand Cherokee Forum 4 11-26-2017 01:26 PM
