Power steering high pressure switch ? - JeepForum.com
post #1 of 14 Old 12-17-2007, 10:27 PM Thread Starter
KenF
What is the purpose of the power steering high pressure switch on a 2.5
KenF is offline
post #2 of 14 Old 12-17-2007, 11:18 PM
ElvisV04290
ElvisV04290's Avatar
From my understanding the switch detects the load on the pump and tells the ECU to adjust the engine idle so the pump gets more power when under load.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #3 of 14 Old 12-17-2007, 11:46 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Really? I thought it was just to let the ECU know if there was something wrong with the pressure.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #4 of 14 Old 12-18-2007, 08:09 AM
bamato
bamato's Avatar
I went to change my ps pump and realized I don't have one.... is that a bad thing?
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #5 of 14 Old 12-18-2007, 12:31 PM Thread Starter
KenF
The OEM manual says they are only on the 2.5s.
It will send a signal to the ECU when this system is under higher load like turning against the lock when the motor is idleing.
But does not say why. It makes sense that it would bump the idle up on the smaller motor.
KenF is offline
post #6 of 14 Old 12-18-2007, 05:36 PM
Desert Bob
Guest
Got this from the Service Manual:
"A pressure sensing switch is included in the power
steering system (mounted on the high-pressure line).
This switch will be on vehicles equipped with a 2.5L
engine and power steering. The switch (figure 12, YJ
models or figure 13, XJ models) provides an input to
the PCM. This input is provided during periods of
high pump load and low engine rpm; such as during
parking maneuvers. The PCM will then increase the
idle speed through the idle air control (IAC) motor.
This is done to prevent the engine from stalling under
the increased load.
When steering pump pressure exceeds 1896 kPa +/-
172 kPa (275 +/- 25 psi) the PCM will increase the engine
idle speed. This will prevent the engine from
stalling."
Desert Bob is offline
post #7 of 14 Old 12-18-2007, 06:56 PM
pat8942
pat8942's Avatar
Great information.
the increased load.
When steering pump pressure exceeds 1896 kPa 6
172 kPa (275 6 25 psi) the PCM will increase the engine
stalling."
pat8942 is offline
post #8 of 14 Old 12-18-2007, 09:56 PM
Mr.B
Mr.B's Avatar
And I just thought that the ECU sensed the lower RPMs and increased to compensate. Now I know why my rpms go up. I wish there was a sensor for when my Taurus fan kicks in.
Ham license:
Everyone is Welcome
Mr.B is offline
post #9 of 14 Old 12-10-2019, 11:42 PM
GRM1230
GRM1230's Avatar
Is it safe to assume if the IAC doesnít kick up the idle that the power steering switch is bad? Or is this one of those pull the thread until youíve replaced everything on the heep?
GRM1230 is offline
post #10 of 14 Old 12-11-2019, 09:27 AM
fishadventure
fishadventure's Avatar
Ya, start with new valve stem caps. Once you get those done and the comp-cut and SOA is complete- and it still isn’t working- replace the pressure switch. Or at least test it with a multimeter.
My 89 -now a 4.0- has a ‘91 2.5 harness in it. The switch plug is still there. I’ve always wondered if it still worked (with the 4.0 ecu)
In your case, since the pressure switch only completes a circuit and sends a signal to the ecu, you could configure a standard 5-pin relay to tell the computer “the pressure has gone up” when the fan kicks in...
[size=ď3Ē]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #11 of 14 Old 12-11-2019, 07:56 PM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by fishadventure View Post
Ya, start with new valve stem caps. Once you get those done and the comp-cut and SOA is complete- and it still isnít working- replace the pressure switch. Or at least test it with a multimeter.
My 89 -now a 4.0- has a Ď91 2.5 harness in it. The switch plug is still there. Iíve always wondered if it still worked (with the 4.0 ecu)
In your case, since the pressure switch only completes a circuit and sends a signal to the ecu, you could configure a standard 5-pin relay to tell the computer ďthe pressure has gone upĒ when the fan kicks in...
Fish, unlike you to get sucked into a 12 year old thread
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #12 of 14 Old 12-11-2019, 08:59 PM
GRM1230
GRM1230's Avatar
I like that order of operations lol. Itís been bothering me since I got the Jeep earlier this year - the idle dropping whenever Iím pulling in the garage or cutting the wheel hard (and me thinking itís gonna stall).
Getting back home this weekend and Iíll try to test it.
Sent from my iPhone using Tapatalk
GRM1230 is offline
post #13 of 14 Old 12-11-2019, 09:34 PM
GRM1230
GRM1230's Avatar
GRM1230 is offline
post #14 of 14 Old 12-14-2019, 10:11 AM
fishadventure
>sigh<
Error Code 65 - power steering high pressure BringThaPain TJ Wrangler Technical Forum 22 07-29-2017 11:32 PM
Power steering high pressure? CRITCHER TJ Wrangler Technical Forum 5 09-12-2008 08:53 PM
High pressure power steering hose fittings farinspace TJ Wrangler Technical Forum 0 07-31-2008 01:51 PM
Power Steering High Pressure Switch 1stTimeJeeper TJ Wrangler Technical Forum 3 08-13-2007 01:37 PM
Power Steering Pressure Switch Tiffy TJ Wrangler Technical Forum 1 09-23-2003 09:58 AM
