Power Brake Booster Issues? - JeepForum.com
 2Likes
  • 2 Post By Waternut
post #1 of 4 Old 05-16-2019, 04:41 AM Thread Starter
Boland398
I am trying to diagnose a problem with my 1991 YJ. Was driving as normal and it appears as if my left rear brake shoe is locked up. Likewise I am also losing braking power (have to pump the brakes once or twice to build up pressure to break). Any ideas what is causing this? Is it my Power Brake Booster?
Boland398 is offline
post #2 of 4 Old 05-16-2019, 06:01 AM
Siva283
Siva283's Avatar
Check ALL your brakes at the tires and make sure they are functioning properly. Brakes lose stopping power when they get hot and can make it feel like they arent working right. Check and repair them first then reavaluate if there is still a problem.
Ask me how I know...
Siva283 is offline
post #3 of 4 Old 05-16-2019, 06:06 AM
Que89YJ
Most of your pedal adjustment comes from the rear so pumping it with the rear shoe extended makes sense. The first thing I would do is look at the brake shoe. There has to be a reason its stuck. Check all you springs and the wheel cylinder. The most common issue is the stuck ebrake cable hold the shoe in.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #4 of 4 Old 05-16-2019, 02:25 PM
Waternut
Waternut's Avatar
My guess is your wheel cylinder on the left is leaking. Pull the drums and verify. Everything should be dry in there. Check your fluid in the master cylinder while you're at it because running out of brakes is never fun.
Typically brake booster failure is a ruptured diaphragm which will sound like a hiss under braking and you may even notice poor idle under braking since that hiss is a vacuum leak.
Boojo35 and Brad Perryman like this.
Waternut is offline
Brake power booster install Not again WK2 Grand Cherokee Forum 8 03-31-2019 07:39 PM
Brakes binding after replacing brake booster NYHighlander WJ Grand Cherokee Forum 7 02-19-2019 06:51 AM
'84 CJ7 Brake Upgrades/Power Booster? ~JM~ Jeep CJ Forum 5 02-16-2019 05:08 AM
2004 GC driver side brake light issues reblinds Grand Cherokee General Discussion 1 01-18-2019 08:48 AM
Commander brake booster help w/removal whyohwhy WK Grand Cherokee & XK Commander Forum 0 08-16-2018 08:34 AM
