Potential New YJ Owner, Help - Page 2 - JeepForum.com
 19Likes
post #16 of 36 Old 06-04-2018, 10:14 PM
Chrisnvegas
Chrisnvegas's Avatar
Although your Jeep looks good and the work you did looks professional,
the YJ front looks better.
Mr.B and bruinjeeper like this.
End the Ethanol Rip-Off
Chrisnvegas is offline
post #17 of 36 Old 06-04-2018, 10:55 PM Thread Starter
bowhunter11199
Got her home! All is good except the linkage in the 4x4 is slipping and wonít engage into 4x4
The 4x4 shifter that is in the cab is slipping on the linkage bar that runs to the transfer case.
Iím thinking I just need to tighten it and it will work. At worst I just need some new linkage
She definitely looks very basic but I have some plans to replace the bumpers and fender and possibly a small lift and some 32Ēs. Think 33Ē+ would be too much in all the driveline components and motor. Currently has 31Ēs
I mainly care about functionality of the Jeep off-road while maintaining the ability to drive on the free way for miles. I have a jack up 17 Silverado when I want to look like Iím compensating lol
Sent from my iPhone using Tapatalk
bruinjeeper and Ravenbar like this.
bowhunter11199 is offline
post #18 of 36 Old 06-04-2018, 10:56 PM Thread Starter
bowhunter11199
What size lift and tires/wheels are on yours? Looks good
post #19 of 36 Old 06-04-2018, 10:59 PM Thread Starter
bowhunter11199
post #20 of 36 Old 06-04-2018, 11:05 PM Thread Starter
bowhunter11199
This is all I think I need to do to get it into 4x4!
https://youtu.be/Apm1QtTQO8o
post #21 of 36 Old 06-04-2018, 11:36 PM
Chrisnvegas
We'll get into the suspension in a bit.
Lets talk about your 4x4.
What does the lever feel like and what makes you think it's slipping?
The number one reason I have seen is jury rigged or worn vacuum lines to the front center axle disconnect that we call a CAD.
It's an easy fix and a whole new factory harness is a 20 minute install and it costs 50 bucks.
Jeep 4x4 is pretty good and usually not an expensive fix.
Oh, and CONGRATS! Looks good!
post #22 of 36 Old 06-05-2018, 12:25 AM Thread Starter
bowhunter11199
When going between 2H and 4H seems like nothing engages. So I had the gf push and pull the knob back and forth and the shifter linkage is slipping on the transfer case linkage.
Or at least that exactly what it looks like because the transfer case linkage doesnít move at all while the shifter linkage is moving
post #23 of 36 Old 06-05-2018, 12:29 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I'm glad you finally got it. Welcome to your new brotherhood.
When you say that it slips out of 4wd, you can actually feel the shifter slip out 4wd/ Or does the 4wd light just go out. If you feel it in the shifter, then yes you need to adjust the linkage. It's not hard to do, but the adjustment is small increments to get it right. The best way that I found was to disconnect it, and move the lever on the TC manually. Then re-attach, check and repeat. If the light just goes out, then like Chris says, it might be the vac hoses.
Edit: You were posting while I was slowly typing. It sounds like a linkage problem. Try like I said and see if you can do it manually.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #24 of 36 Old 06-05-2018, 12:33 AM Thread Starter
bowhunter11199
Thanks!
The light doesnít come on at all so Iím also certain itís the linkage. Iíll take some pictures of the linkage tomorrow evening and post them up
post #25 of 36 Old 06-05-2018, 12:37 AM
Mr.B
Mr.B's Avatar
Thanks!
The light doesn’t come on at all so I’m also certain it’s the linkage. I’ll take some pictures of the linkage tomorrow evening and post them up
Your way too fast in responding for me.
Disconnect it and manually and see if it will work.
Ham license:
Everyone is Welcome
Mr.B is offline
post #26 of 36 Old 06-05-2018, 08:13 AM
fishadventure
fishadventure's Avatar
I manually.
Or at least that exactly what it looks like because the transfer case linkage doesnít move at all while the shifter linkage is moving Sent from my SpyPhone using iCrap&talk
That sounds like the correct diagnosis. As far as the light, that is triggered by a switch on the CAD for a 1995if Iím not mistaken. It is only an indicator, whether itís on or off doesnít matter really. It comes on when the switch plunger is depressed inside the CAD shift fork actuator. Just in case you didnít/donít know that.
As far as a lift, thereís some cleaning advantage to a 1Ē body lift (you shouldnít go taller with body mounts for lots of good sound reasons). And that may be adequate for 32s.
You can gain another 1.25Ē in front by cutting off the factory spring perches and making low-profile perches, thereby keeping the nice stock spring ride. That involves welding and you havenít mentioned how tooled up you are. To bring the back up to match the front is more involved because you need to move the rear shackle hangers from the center to the bottom of the frame (welding job again) and use 5/8Ē lift rear shackles if you need a little more to be about level. With the 1Ē body lift you wind up with basically 2Ē of lift for quite little expense, and the only thing you might need to change is the shock mounting locations. (Or just buy OME springs, but those are taller, quite a bit more money, and if you add the 1Ē body lift might look too tall for 32s.) These are my opinions only; health benefits and claims have not been approved by the FDA.
Last piece of advice: donít order or look at any catalogs or ads for kits and bolt-ons. They will be glad to take your money, but folks here on JF will help you get what you want and not wind up with a terrible ride or mud flaps and a chrome grille or something else ridiculous.
Chrisnvegas likes this.
[size=ď3Ē]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #27 of 36 Old 06-05-2018, 09:58 AM Thread Starter
bowhunter11199
Thanks for the info, itís appreciated! In regards to how handy I am with tools, Iíve installed several liftedon trucks in the past with good success but tend to shy away from cutting and welding due to be worries it doesnít work out right and itís really messed up now.
I typically shy away from body lifts too just because they can rust through and seem to be fairly involved compared to a suspension lift.
Right now it has 31x10.5x15 highway tires that donít rub, but I havenít off-roaded it yet. Iím sitting at approx 9Ē of cleanse on the rear diff and about 13Ē of clearance on the axle tube body of the axle
post #28 of 36 Old 06-05-2018, 01:44 PM
fishadventure
Uh-uh, no. You are not understanding this.
A SHORT 1" body lift is NOT "involved," it is often very simple actually in a rust free world like yours. You take factory ~7/8" tall rubber mounts out and put ~1-5/8" tall urethane mounts back in their place- no rust risks at all. Urethane and rubber don't rust, and any rust around them will or would have happened anyway if you don't take care of the rig and deal with stuff before it becomes a big inconvenient project.
The 1" body lift has almost NO negative consequences nor does it usually require extra/other parts. Maybe adjustment of the fan shroud.
A 2" or 2-1/2" suspension lift, on the other hand, changes drag link angles, sometimes affects the driveshaft (vibes), should probably have longer shocks or relocated shock mounts, bothers the (unnecessary) track bars, affects the sway bar, often needs compensation for brake and vent lines, and likely needs taller bump stops. Etc.
Not that you shouldn't do springs, but I just wanted you to see the realities.
I think chrisnvegas is on 33s and iirc he did the nice OME sprigs and the 1" body lift.
Took folks here a while to convince me the 1" body mounts were a good idea, but as soon as I installed them I knew it was the right thing to do.
Chrisnvegas and bruinjeeper like this.
post #29 of 36 Old 06-05-2018, 01:53 PM Thread Starter
bowhunter11199
Many years ago while looking for lifts for an old Tacoma, I was told how bad body lifts are but you changed my mind! Thanks for the info!
post #30 of 36 Old 06-05-2018, 01:55 PM Thread Starter
bowhunter11199
I did some more searching and I figured out Iím missing a bolt in the linkage were the green arrow is pointing to.
Best thing I can think of is go to hardware store and just try different size and pitch bolts.
Anyone by chance know the bolt size?
