Is it possible to Mess up your Alernator while 4x4'n? - JeepForum.com
post #1 of 17 Old 01-02-2008, 07:49 AM Thread Starter
WindBlown
Guest
Because on my way home the day after 4 wheelin my alternator went on me and i was stranded in the dark on the side of a freeway with no hazzards. I don't want this to happen again could this be due to me 4wheeling or is this irrelavent. If it could have caused it then I will check my Alternator after 4wheeling next time.
WindBlown is offline
post #2 of 17 Old 01-02-2008, 07:53 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Possibly if mud and water found their way into it... although I've had mine saturated a number of times and have not had any problems. More than likely your case was a coincidence.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #3 of 17 Old 01-02-2008, 08:08 AM
OneLung
Guest
I did the 136 amp alternator upgrade and the guy at the junk yard had a whole stack of them for $25.00 each, so I got an extra one and keep it in my spare parts box under the duster cover.
OneLung is offline
post #4 of 17 Old 01-02-2008, 08:50 AM
EABiker
You should probably go over all wiring connections, including the grounding straps; a hard jolt may have may have loosened something!
EABiker is offline
post #5 of 17 Old 01-02-2008, 09:18 AM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
Mine died at Rubicon Springs at the Rubicon. I drove out through Cadillac Hill on battery power. It sucked because I was constantly worried about the battery dying. But I drove for 2 hours on an Optima Red Top without a problem. Finally I swapped batteries with my buddy before the battery died.
Alternators can go at any time, but definately mud can cause them to fail. I used to take my Jeep in the mud all the time. I had one fail during that period as well.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #6 of 17 Old 01-02-2008, 10:35 AM
jeepross
I am in the process of putting on a new alternator, do i looen the serpentine by way of loosening the power steering pump bolts?
jeepross is offline
post #7 of 17 Old 01-02-2008, 02:13 PM
joe's_yj
joe's_yj's Avatar
yes
ten char
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #8 of 17 Old 01-02-2008, 02:50 PM
jeepross
Thanks Joes YJ.
jeepross is offline
post #9 of 17 Old 01-02-2008, 06:38 PM
dbikers
it's pretty much possible to mess up anything while 4x4'n...
4x4 makes me do dumb (but fun )stuff...i've even messed up my lighter...
dbikers is offline
post #10 of 17 Old 01-02-2008, 06:46 PM
RANGER_DANGER
My buddy went hunting with his XJ and went through some deep stuff and he told me his alternator started squeeling and pretty much seized up. He also said he saw sparks on the ground behind him. I'd have to say it is possible but unlikely this is the cause of your alternator dieing. XJ's alternators are generally pretty low on the motor.
RANGER_DANGER is offline
post #11 of 17 Old 01-02-2008, 07:48 PM
joe's_yj
joe's_yj's Avatar
Thanks Joes YJ.
no problem hope it works
my build up
joe's_yj is offline
post #12 of 17 Old 01-02-2008, 09:40 PM
--chris--
--chris--'s Avatar
Not to get to far off topic here, but i had a '82 rabbit that ran on a ****ty battery with no alt for about 1 hour 15 once.
So....i guess it would be reasonable to assume (if you were ever stuck on the trail without your alt) that you have anywhere from 1:15 - 2:00 hours untill you get into trouble.
--chris-- is offline
post #13 of 17 Old 01-03-2008, 07:44 AM Thread Starter
WindBlown
Guest
Well I did submerge myself a few times on the trip. Unfortunatley my Battery Gauge Isnt connected or something because i dont get a different reading no matter how much battery i have i really should get that fixed. ahha
post #14 of 17 Old 10-20-2008, 08:03 PM
dbikers
revisited...answer is yes
dbikers is offline
post #15 of 17 Old 10-20-2008, 08:34 PM
ZeroGravity
ZeroGravity's Avatar
Anything can happen.
ZeroGravity is offline
15W 30/40 did I mess up? RebuildRookie YJ Wrangler Technical Forum 6 12-11-2011 06:08 PM
I got a mess Plowhoss YJ Wrangler Technical Forum 11 02-26-2009 02:27 PM
Did I just mess up? *pics* 98tjsahara TJ Wrangler Technical Forum 5 07-13-2007 06:57 PM
Oh Boy, i cant wait to fix this mess Wshift YJ Wrangler Technical Forum 2 05-29-2007 10:16 PM
What a mess...need some help. titus95 YJ Wrangler Technical Forum 30 02-21-2006 10:49 PM
