PLEASE HELP 89 YJ TFI no spark - JeepForum.com
post #1 of 5 Old 08-13-2020, 07:58 PM Thread Starter
Craigscotty28
Craigscotty28's Avatar
Hey guys please help. I did the entire TFI igniton upgrade a couple years ago and it's been running great. The problem is after I did and oil change, I let it run for a bit then turn it off. I Mistakenly left the keys in and turned to the ON position. The last time I did that... the igniton coil got super hot and I had to replace it. And everything worked fine. Keep in mind I'm running the TFI upgrade so I have the ignition coil from a 1982-83 f150. Anyways now I tried replacing the igniton coil again and..nothing. PLEASE HELP. This thing is not getting spark and yes the ignition coil reads 12vs so it's not bad. I'm at a loss guys I even replaced the ICM still nothing. any ideas guys? I'm new to the forums and would appreciate/recommendations some help with this!
Craigscotty28 is offline
post #2 of 5 Old 08-13-2020, 08:21 PM
4Low2G0
4Low2G0's Avatar
Check the pick up inside the dist. next
Whats over that next ridge?
4Low2G0 is offline
post #3 of 5 Old 08-13-2020, 08:32 PM Thread Starter
Craigscotty28
The pick up? what does it do? sorry unfamiliar with it
post #4 of 5 Old 08-13-2020, 09:54 PM Thread Starter
Craigscotty28
is the pick up under the Dist cap where the Rotor is?
post #5 of 5 Old 08-14-2020, 09:40 AM
4Low2G0
4Low2G0's Avatar
Yes
4Low2G0 is offline
