pilot bearing removal - JeepForum.com
post #1 of 11 Old 12-22-2017, 11:09 AM Thread Starter
corvairdan
I have a 4cyl 6 speed wrangler. I am trying to replace the pilot bearing. I have the flywheel removed and I am having trouble getting the pilot bearing out of the flywheel. I managed to destruct the old bearing and the only part left is the race. Does anyone know how to get it out? Does it come out the front or back There is a large plate on the backside.
corvairdan is offline
post #2 of 11 Old 12-22-2017, 01:09 PM
Opihi59
from here it gets rough
Opihi59's Avatar
It should be able to be pressed/driven out.
Besides replacing the pilot bearing, what else are you doing? New clutch system? What do you plan to do as far as the flywheel goes? Are you going to have the flywheel refaced at a machine shop, or are you going to put in a new one? If new, then don't worry about the old one. If refacing, then you likely need a puller. Honestly, I thought the bearing race was accessible from both sides of the flywheel and could be easily driven out.
Since you say 6-speed Wrangler, and I have nothing else to go by though, is this a YJ we're talking about? Or what? You have nothing in your profile to direct me further in being able to help you out on this.
Welcome to the forum.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 11 Old 12-22-2017, 01:36 PM
Towny72
I went through some struggles with this recently myself.
here is a link to the thread, the team here helped me get past this mental block!
https://www.jeepforum.com/forum/f12/p...inues-4193162/
Should have gotten a tetanus shot with this jeep!
Towny72 is offline
post #4 of 11 Old 12-22-2017, 01:42 PM
Opihi59
Opihi59's Avatar
Wrangler 4.0 the pilot bearing is installed in the back of the crank.
Wrangler 2.5 (4 cyl YJ) the pilot bearing is installed in the flywheel.
It's a horse of a different color. If for some reason the configuration of the OPs flywheel doesn't allow access to the pilot bearing from both sides of the removed flywheel, then blind hole puller will do it, like rental for deposit from Vatozone, O'Really's etc. Not sure what OP has though, it's a mystery at this point, awaiting further information, maybe even some photos.
Opihi59 is offline
post #5 of 11 Old 12-22-2017, 07:28 PM
project_mercy
Came for the bread shenanigans, stayed for the 6-speed answer.
With your help I will resist the urge to buy a chrome grill guard for yet another day.
project_mercy is offline
post #6 of 11 Old 12-22-2017, 09:22 PM
Opihi59
Opihi59's Avatar
He said Shenanigans......
Opihi59 is offline
post #7 of 11 Old 12-22-2017, 09:57 PM
Towny72
I wish I had a 6spd
Towny72 is offline
post #8 of 11 Old 12-25-2017, 02:50 PM
crackedcornish
I'm also curious about this 6 speed thing...are you sure your YJ has a 6spd?
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #9 of 11 Old 12-25-2017, 04:10 PM
Opihi59
Opihi59's Avatar
I'm thinking OP may not have a YJ, but a TJ. I don't mind helping Wrangler owners of any ilk figure out their issues if I can. Hope we do hear back from OP sometime, as open-ended threads are not helpful to others searching for answers. Sometimes though, we never hear back from Newbs with interesting concerns.
As I know it, in the TJ series, behind the 2.4L L4 there was an option for the 6 speed NSG370 manual transmission but only in like the 2005/6 series, also the NV1500 with which I have no experience. Prior to that behind the 2.5 TJ it was the AX 5 that we all know. Since the NSG370 was also put behind the 6 cylinder, it must have been very nice to get a 4 cyl with that transmission that is known to be able to handle a lot more torque than the other 4 cylinder transmissions.
This 6-speed though is like the 6 speed behind the Gen 2 Tacomas where only the 6th gear is an overdrive. Direct drive is not until you get to 5th, so if you're driving around in 4th, you're still in a reduction gearing so to speak. Gen 3 Tacoma 6 speeds though went back to direct drive in 4th, and the 5th/6th are both overdriven gears.
So, depending on bell housing, the NSG 370 can go behind the 4.0, as well as the 3.8L V6, and apparently, the 2.4 4 cylinder as well.
Waiting on OP.......
Opihi59 is offline
post #10 of 11 Old 01-02-2018, 12:36 PM
Opihi59
Opihi59's Avatar
OP--where are you on this project? Any followup?
Opihi59 is offline
post #11 of 11 Old 01-04-2018, 07:09 PM
Towny72
Somebody at MOPAR found out he had the elusive YJ with the test 6spd..... What they did to him, well I can not say
Towny72 is offline
