Outside door handle issue - JeepForum.com
 1Likes
  • 1 Post By Magnum
post #1 of 6 Old 05-22-2019, 11:36 AM Thread Starter
zrickety
zrickety's Avatar
My passenger side door handle was not 'catching' and not working about 6 months ago. I was able to get inside the door and bend the linkage to where it would operate again. Today it happens again, kind of getting stuck in the open position without actually opening the door. The inside handle is fine. Is this a known issue and is there a better replacement available? Not a fan of the Chinese Omix Ada parts.
1988 Jeep Wrangler Laredo
zrickety is offline
post #2 of 6 Old 05-22-2019, 07:42 PM
Boojo35
1987 YJ Wrangler
Try lubing and cleaning the crap out of the door latch itself. It may not be a handle problem at all.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #3 of 6 Old 05-22-2019, 09:49 PM
timatoe
timatoe's Avatar
I had issues with the formed metal clips that hold onto the threaded rods sliding out of adjustment.
I grabbed a couple of simple L brackets and some nylock nuts and got rid of the factory clip things. I don't know if that really makes sense but, once you're in there it makes more sense.
timatoe is offline
post #4 of 6 Old 05-23-2019, 07:22 AM Thread Starter
zrickety
zrickety's Avatar
Thanks guys. What I found before was a little arm that rubs a pivot linkage, that arm was worn. I bent it for more contact but it must have worn more or bent back. I'll dig into this on Saturday.
zrickety is offline
post #5 of 6 Old 05-23-2019, 09:20 AM
Magnum
Let me echo what Boojo35 said about lube. When I first got my YJ, the latches and locks on both doors were very stiff. When I pulled the door panels, I recall that one of the plastic "fittings" was broken. All of the other problems were due to the lube turning into solid little cakes of gunk. Clean out that old lube and put on some new. Even if this is not your problem right now, it will save you some pain down the road.
zrickety likes this.
94 YJ, 4.0, 5-Spd, 33x12.5 GY Duratrac, RE 2.5" Lift
Brown Dog Mounts, 8.8 w/ disks, TrueTrac f & r
Magnum is offline
post #6 of 6 Old 05-25-2019, 11:01 AM Thread Starter
zrickety
zrickety's Avatar
I got into the door today...it was the same as before. The linkage for the outside handle it worn, so the one pivot part slips past the handle cam. I bent it like I did before for better contact. This works. I might have to throw some tack welds on it eventually to stiffen it up or just replace the whole outside assembly.
zrickety is offline
Unknown Issue: Knocking coming from under TJ when decelerating Eric6123 TJ Wrangler Technical Forum 18 04-16-2019 08:09 AM
Another Howell conversion issue: I am stumped! Nucking1Futs Jeep CJ Forum 75 03-12-2019 10:03 PM
SKIM or PCM issue? tcmault TJ Wrangler Technical Forum 18 01-22-2019 09:47 PM
Odd sputtering issue (long and kinda rambling but need help) Lkfool TJ Wrangler Technical Forum 10 12-29-2017 09:50 AM
