oil in my air filter... - JeepForum.com
post #1 of 15 Old 06-06-2004, 05:02 PM Thread Starter
hmk_21
Guest
ive heard the term 'blow by' used...
but whats the cause..
and how do i attempt to repair :/
hmk_21 is offline
post #2 of 15 Old 06-06-2004, 05:08 PM Thread Starter
hmk_21
Guest
sorry...
1989 YJ, 4.2L 6cyl
hmk_21 is offline
post #3 of 15 Old 06-06-2004, 05:10 PM Thread Starter
hmk_21
Guest
hmk_21 is offline
post #4 of 15 Old 06-06-2004, 05:15 PM
drew2000
drew2000's Avatar
This is often caused by clogged PCV/CCV systems not allowing the crankcase to vent. I don't remember which system yours has, my 94 2.5 uses a CCV system which is very easy to clean out.
Drew
Originally Posted by hmk_21
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #5 of 15 Old 06-06-2004, 05:17 PM
RCHavok797
RCHavok797's Avatar
Your 89 has a PCV system and is located on the valve cover.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #6 of 15 Old 06-06-2004, 06:27 PM Thread Starter
hmk_21
Guest
so is it a matter of replacing the pcv value?
seconds of work i gather...
hmk_21 is offline
post #7 of 15 Old 06-06-2004, 08:36 PM
MarathonScott
Guest
It doen't take long, just make sure the grommet that the PCV valve plugs into is soft and not hardened. If it gets hard, it won't make a good seal.
MarathonScott is offline
post #8 of 15 Old 06-07-2004, 09:15 AM
gustaia
Guest
oil in th eair filter
I had the same thing, I tried cleaning the orifices and vacum hoses to no result...but i bought an oil separator (I did a search on yahoo/shopping) for about 8$ (6$= 2$ shipping). It took me 2 minutes to install it (it fitts where the oil caps goes) and since then no more oil in the air filter...
gustaia is offline
post #9 of 15 Old 06-07-2004, 09:56 AM
RCHavok797
RCHavok797's Avatar
I've never heard of an oil separator. Can you tell me more about it?
post #10 of 15 Old 06-07-2004, 10:00 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Hopefully it's the PCV valve... that would be the cheapest problem to fix. There are other causes for blow-by. Ive heard about people taking off their valve cover and cleaning off all the gunk inside that can clog the vents on top and basically do the same thing as a bad PCV valve.
Blow-by can also be caused by worn piston rings in the engine which allow some of the exploding gas in the cylinder to slip past into the crankcase and kinda pressurize the valve cover... which is relieved through that vent into the air cleaner.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #11 of 15 Old 06-07-2004, 10:08 AM
JayJEEPguy
JayJEEPguy's Avatar
Or, you can do what I did, if a new PCV doesn't cure your oil-filled air filter. I removed the hose that connected the PCV to the air filter, and rerouted it from the PCV to the lower end of the motor compartment. No more oil in the air filter
Jason T.
'99 GMC Suburban: Gas-guzzling people mover with 18" Z71 wheels
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hear
JayJEEPguy is offline
post #12 of 15 Old 06-07-2004, 11:08 AM
rollmeover
Guest
sounds about right!! I think any one with the ol 258 is going to have a blow by problem, just ask the cj owners!!
I have tried everything short of replacing the motor with no results. i ended up routing a hose out of the valve cover into a "catch can" type container that way the pressure could be released and any oil that came out with the pressure could be caught instead of dripping on the ground or in the motor bay.
rollmeover is offline
post #13 of 15 Old 06-07-2004, 11:36 AM Thread Starter
hmk_21
Guest
so it simply blows any blow-by into the open air?
this sounds like a decent idea
hmk_21 is offline
post #14 of 15 Old 06-07-2004, 12:11 PM
JayJEEPguy
JayJEEPguy's Avatar
With my set-up, yes. Or, you could set-up a catch-can like rollmeover did. It just vents the blow-by somewhere else, instead of into the air filter.
My blow-by was extremely bad when I bought the Jeep. Within a 1-minute drive up the street after changing the PCV and the airfliter, they were both oil-soaked (Jeep sat for a little while before I bought it). Since my quick "repair", I have not noticed any oil coming out of the hose anymore...
Jason T.
post #15 of 15 Old 06-07-2004, 06:07 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
This is actually what I did, execpt I put a small breather filter on the end of the hose to keep any dust or whatever out.
synthetic oil filter vs regular oil filter MacK JK Wrangler Technical Forum 2 10-31-2009 11:09 PM
Air Filter Oil Filter whats the difference? LlamaJeep YJ Wrangler Technical Forum 9 03-15-2008 11:52 AM
K&N Square Stock Filter or Round K&N filter??? SupaJosh TJ Wrangler Technical Forum 9 09-13-2005 05:59 PM
Fram Disposable Air Filter (Same Part Number Different Filter) julietkilo TJ Wrangler Technical Forum 7 07-15-2005 10:02 PM
stock filter vs. K&N air filter 90yjwrangler YJ Wrangler Technical Forum 8 12-01-2004 06:49 PM
