Oil Leaks - JeepForum.com
post #1 of 4 Old 04-13-2004, 07:40 PM Thread Starter
Mazdaboy
Oil Leaks
I go through oil like it poop through a moose. My engine doesn't seem to be bruning it off, but it does seem to be leaking all over the place. Where's the most common place for a 258 (4.2L) to leak oil?
If I had the funds, I'd pull the engine and replace all the seals (they're all original after 133000 miles). Course if I had the funds I'd replace the engine with a 350...
But it looks like I need to go after the major seals one by one, starting with the most problematic. Any ideas?
89 YJ 4.2 auto
MB
Mazdaboy is offline
post #2 of 4 Old 04-13-2004, 08:19 PM
sailor77
Ok here are the three top seals to replace
Rear Main seal. Probably one of the hardest to replace. Plan for at least 4 hrs.
This will lead you in to the next which is the oil pan. Get a good one piece seal to replace the old style three piece. I got mine from napa.
The last would be the valve cover seal. This is fairly easy to do once you have all the crap removed from the top of it.
Hope this helps.
sailor77 is offline
post #3 of 4 Old 04-14-2004, 11:38 AM
MarathonScott
Guest
First check your PCV valve, the hoses and the grommet that holds the PCV valave into the valve cover. My 90 had some leaks until I changed the grommets. They get hard and don't hold the vacuum like they should.
MarathonScott is offline
post #4 of 4 Old 04-14-2004, 02:41 PM
KEVNISE
Guest
mine was leaking from the valve cover I replaced the gasket I t did leak quite a bit
KEVNISE is offline
2.5 leaks oil? roccomonte YJ Wrangler Technical Forum 3 09-01-2009 01:03 AM
Leaks fixed in one spot, now I got 3 new leaks in new spots yay MacK JK Wrangler Technical Forum 5 11-08-2008 09:20 AM
Leaks, Leaks Everywhere? dpr333 YJ Wrangler Technical Forum 11 02-09-2008 04:58 PM
Leaks Leaks Leaks from my 4.2, question olyjeep YJ Wrangler Technical Forum 9 03-13-2007 01:26 PM
Got another YJ and it LEAKS :( Eriq35 YJ Wrangler Technical Forum 5 05-20-2004 05:04 PM
