!#$@ Oil cap - JeepForum.com
post #1 of 7 Old 02-14-2008, 07:15 PM Thread Starter
wills88yj
Guest
!#[email protected] Oil cap
anyone know of a good oil cap for my 258
.....i have bought 2 from adanced and they both leak....
wills88yj is offline
post #2 of 7 Old 02-14-2008, 07:24 PM
sam.b.
get a thicker gasket or use 2 gaskets?
98 TJ Mild DD
90 YJ Sold
88 Samurai slowly being built for the rocks
<< Louisville Ky. based 4x4 club
sam.b. is offline
post #3 of 7 Old 02-14-2008, 07:30 PM
Rush1184
Rush1184's Avatar
Aren't 6cyl jeeps suppose to leak from the oil fill cap? I have never seen one that was not brand new that was dry up there, at least with the 4.0.
1993 YJ Green/Spice - 6cyl 4.0L AX-15
2x KC Daylighters on windshield hinges, front hooks, rear shackle, 20' strap, shovel, saw, tools, air compressor, etc.
FOR SALE:
- Set of 4 used 33x14.5r15 Mickey Thompson Baja Belted HP Tires on Alloy Rims (5 on 5.5 bolt pattern).
- 2x white 6" KC Stone Guards (NEW)
(PM me if interested)
Rush1184 is offline
post #4 of 7 Old 02-14-2008, 07:36 PM
pat8942
pat8942's Avatar
Crankcase pressure causes the cap to leak.
If your crankcase ventilation system PCV/CCV is working right it should'nt leak.
I recently replaced my valve cover gasket and put on a new $2.99 Stant cap and it doesn't leak a drop.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #5 of 7 Old 02-14-2008, 07:55 PM
ElvisV04290
ElvisV04290's Avatar
I got mine from AutoZone and it holds just fine, every cap I ever got from advance leaks within a week.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #6 of 7 Old 02-14-2008, 08:12 PM
J33Pyj
Ya the one i got from advance leaks to, so replaced valve cover gasket and change my pvc and it still leaked bought one fron autozone and no more leak
90 yj/ 4:88 gears/33x12.50x15 Super Swamper TRXUS Mud Terrains/K&N air system/2.5L/D30front aussie equip'd/D35 rear / 3in BL/ 2in shackle lift / XRC8 Winch
If you havent broken it, you havent been wheelin
J33Pyj is offline
post #7 of 7 Old 02-14-2008, 09:40 PM
goatboy
Guest
Bought mine from the dealer for less than four bucks...OEM design, doesn't leak a drop...I'll bet you paid more for less at those aftermarket stores...
goatboy is offline
