Odd power problem - JeepForum.com
post #1 of 4 Old 07-22-2021, 10:41 AM Thread Starter
Jeepfather
Odd power problem
Ok, I have an electrical issue. Itís a 1989 with the 4.2 and a manual trans. I went out the other day and no power to anything. I replaced the relay on the firewall. I immediately have light but when I turn the key to start it I get a click and then no power to anything again. I unhook the battery then hook it back up and I have lights again. Turn the key to start and it all goes dead again. This is driving me nuts. Any ideas? Thanks and any help is appreciated!
Jeepfather is offline
post #2 of 4 Old 07-22-2021, 10:45 AM
timatoe
timatoe's Avatar
I'd start with checking voltages into and out of the ignition switch (the actual switch behind the dash on top of the column) and checking the condition of the battery cables (they're known to corrode inside the cable).
timatoe is offline
post #3 of 4 Old 07-22-2021, 11:02 AM
jay-h
A corroded connection can do this. When cold it has reasonable continuity, however once you put load through it, it heats up locally and the resistance goes way up.
with key on, check voltage drop between battery + and various points along the way.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #4 of 4 Old 07-26-2021, 01:24 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Remove both battery cables at the battery. Naturally check the connectors to see if they are clean and in good condition and are on properly. Then grab each one by the connector and twist it back and forth rather vigorously at least a half dozen times. Now grab them and bend them out shape pinching the cable back onto itself. Put the cables back on. IF the battery is fully charged hit the key and see what it does. If it has a fully charged battery and it fires up I would also suspect that the cables are all green underneath the insulation......Replace them!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Found out Grandpa is addicted to Viagra. No one is taking it harder than Grandma...
laybackman is offline
