Which NP435 rebuild kit to get? - JeepForum.com
post #1 of 7 Old 07-29-2020, 08:20 AM Thread Starter
9Dark6
Hey guys, making a separate post for this from my build to ask a specific question:
Which NP435 rebuild kit should I get? Whats the best bang for my buck? I've been stalled out(partly because I have been trying to order this at work and we have been slammed) largely because there seem to be several kit options and many places don't seem to have a comprehensive parts list of what the kit includes.
Novak has a complete parts list of what their kit includes but its $258, whereas I have seen kits in other places that seem to have the same components in the pictures but without a parts list I am iffy on ordering it because some places use "stock photos". I'd contact them but heck even the ford dealership the other day told me a part was in a kit when I called them and after ordering it and getting it in I found it was not... I'd like to find a kit that has syncros in it.
Also, I'm worried about quality. I don't feel like having to rebuild this tranny in a few thousand miles because the parts are crappy(I've had some crappy quality ebay parts lately in other projects) but I also don't want to overpay for the same quality parts I could get someplace else.
So do you guys have any input? I see the number BK127WS in several kits?
Broncograveyard.com has a kit that looks complete for a good price
https://shop.broncograveyard.com/NP-...uctinfo/21006/
Allstategears.com has one with a lot pictured but no actual list and it says "rings no longer available"?
https://www.allstategear.com/NP435-B...shoppingengine
Novak is probably the best but dang they are proud of it!
https://www.novak-adapt.com/catalog/...ts/np435-parts
9Dark6 is offline
post #2 of 7 Old 07-29-2020, 08:26 PM
GrantYJ
GrantYJ's Avatar
Sub'd.
Have you pulled it apart to see what it needs? Those are dead simple transmissions. If it mainly needs bearings and seals, most of the kits shouldn't be too bad. For what it's worth, my brother is an early Bronco guy (a '74) and has had nothing but good luck with BroncoGraveyard.
I've got an NP435 that was orignally mated to a Dana 21 (craptastic T-case with no neutral or 4-low) that will eventually be mated to a 203/205 doubler that's complete other than working out the levers. The NP435s that came with the D21s were more like a 2WD NP435 (very different than the 4WD models on the tail end) and I should be able to shave a decent amount of length off when I build the custom adapter.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #3 of 7 Old 07-30-2020, 09:13 AM Thread Starter
9Dark6
Thanks grant, I've only pulled the cover off once while cleaning, I'm not 100% sure I'd even know what to look for. I've read recently that third gear catches heck with them so I'll look closer at that.
This was out of a farm truck for a dairy I used to work for in high school. I remember how you could hit the brakes and the shifter would fall back into first gear. When I bought the truck a few months back the farmers daughter told me that so many hands had tried that trick that you couldn't keep it in second anymore, or couldn't shift to second, I forget. So I figure that a total rebuild with new synchros isn't a bad idea. That old transmission taught a lot of youngins how to drive standard and has suffered a lot of abuse hauling hay an feeding cows lol
9Dark6 is offline
post #4 of 7 Old 08-02-2020, 07:10 AM Thread Starter
9Dark6
I went with the Bronco graveyard kit
9Dark6 is offline
post #5 of 7 Old 08-04-2020, 04:47 AM
fishadventure
fishadventure's Avatar
Probably should buy new 2nd gears. If it pops out to first the synchros aren’t the answer: the gears are worn out.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 7 Old Yesterday, 08:50 AM Thread Starter
9Dark6
How can I tell if second gear is worn by looking at it? The rebuild kit should arrive tomorrow
9Dark6 is offline
post #7 of 7 Old Today, 05:29 AM
fishadventure
Spalling, pitting, tapered edges, sharp-edged teeth. But if it pops out of 2nd on deceleration you don’t need to look at it much.
