Not satisfied with Brakes - JeepForum.com
 10Likes
post #1 of 43 Old 05-25-2021, 02:56 PM Thread Starter
mikwallace
mikwallace's Avatar
Starting new - I copied and pasted this to the forum rather than continuing conversation on “What did you do to your YJ Today”.
YJ Brakes not satisfactory, put new rotors, pads on the front and drums, shoes, and hardware on the rear when I had the vehicle taken apart; maybe a 800-900 miles ago. I’ve never been happy with the stopping power! Mostly stock except 265/75-16 Goodyear Wrangler AT. Brakes would not lockup going steep downhill on asphalt. Bled again and no change. Installed new rear wheel cylinders and flushed brake fluid, bled, and adjusted. Rear wheel cylinders were corroded inside (years of non use?). Installed new master cylinder and thoroughly cleaned proportional valve. Booster passes test as per Haynes (no leak down, etc etc). Will now lockup brakes on steep downhill, but I’ve got to put all my weight on the pedal. On level ground it takes all I got to emergency stop but won’t lockup wheels. Looks like perhaps an upgrade to ‘95 YJ Booster and Master Cylinder will help?
ShaggyJim -
What kind of pads??
Oreilly’s “Break Best Select” Semi-Metallic pads - special of the day I guess?
Daddyjeep87 -
Local big box stores have booster and MC for about $150.
mikwallace is offline
post #2 of 43 Old 05-25-2021, 03:08 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
ShaggyJim -
What kind of pads??
Daddyjeep87 -
Have you considered moving to a dual diaphragm booster vs your stock single? You can swap in a stock dual diaphragm XJ or TJ booster with a modification to the master cylinder push rod for length and connection end. If you weld, it can be done DIY.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #3 of 43 Old 05-25-2021, 03:18 PM Thread Starter
mikwallace
mikwallace's Avatar
Luca - yes I have. I’ve read several threads on the topic. No wranglers in the salvage around here, so new from big box store is the solution; however, I found a 95 YJ booster, MC, and Prop valve on EBay from DeadJeeps for about $30 less. As I understand the ‘95 only have to drill the rod hole bigger on backside of booster; whereas, on XJ/TJ rod length has to be adjusted/lengthened, hence cut and weld.
post #4 of 43 Old 05-25-2021, 03:56 PM
jbolty
Administrator
jbolty's Avatar
95 booster is direct swap. no drilling. you are thinking of the TJ booster.
95s can be hard to find, which is why a lot of us switched to the TJ version.
When I got my jeep it was bone stock and it stopped ok but one of the brake lines had rusted out and the fluid was dirty so I changed everything. New master, wheel cylinders, calipers and hard and soft lines. YJ brake parts are pretty cheap. After that and and using OEM parts the braking was noticeable better. Later when I put on 35s I needed the double booster
jbolty is offline
post #5 of 43 Old 05-25-2021, 04:31 PM
cas6969
cas6969's Avatar
Used, new (rebuilt) or both?
Mine are bordering on unsafe, they certainly would be for someone not used to them. I changed pads the other day, did nothing. Actually feels worse, probably is (because I need new rotors , so flat pads on grooved rotor equals less contact area. So new rotor next week.)
I was thinking today about an old 1950's car I had, much heavier, MUCH faster, drum brakes all around, NOT power brakes, yet it stopped on a dime compared to this thing.
Silicone, the thinking man's duct tape.
cas6969 is offline
post #6 of 43 Old 05-25-2021, 06:40 PM Thread Starter
mikwallace
mikwallace's Avatar
Oreilly and AutoZone are Reman. The EBay is salvaged but operationally checked, and from Dead Jeeps.com
Sent from my iPhone using Tapatalk
post #7 of 43 Old 05-25-2021, 07:23 PM
jeep_boy02
1934 CJ7
I think you can get away without welding. I did on my CJ dual diaphragm swap. I cut the rod with an inch of stem left on rod end. Run a thread die over that stem and the remaining inch or two of the rod and use a coupling nut and lock nuts to make and adjustable rod.
Sent from my SM-A015A using Tapatalk
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #8 of 43 Old 05-25-2021, 08:15 PM Thread Starter
mikwallace
mikwallace's Avatar
Is the rod you’re speaking of the rod that goes into the master cylinder or the rod that goes through the firewall to the pedal?
post #9 of 43 Old 05-25-2021, 08:23 PM
jeep_boy02
1934 CJ7
To pedal. But it also went through, or at least to the firewall. It's been awhile since I did it and I don't have any pics and I'm away from the jeep for the next month so i can't look at it real quick. I know it wasn't one of those that has the rod end attached to booster. Was more like a slave rod from pedal to MC
post #10 of 43 Old 05-25-2021, 09:12 PM
jeep_boy02
1934 CJ7
Here's a pic I found of the same type of mod.
Wilwood and Scott drake also have similar "adjustable" rods
post #11 of 43 Old 05-25-2021, 09:12 PM
SevenSlotAddict
A MC swap will make things better for you for sure. I see folks swapping Ford and Dodge set ups in as well. Do a search for all your options. Also, IIRC, semi metallic pads take some heating up to provide the best friction. That may be ceramic, someone will correct me if I am wrong. My '90 YJ stops pretty well, a bit squirrelly under hard braking but I think thats due to the calipers being old and sticking at times. Those are definitely on the replace list along with the pads. I plan to find fiber pads for that and most likely I will swap out the hoses as well. I also think I read the braided SS hoses do not expand like the OEM rubber ones so all the fluid goes to the calipers/ wheel clyinders.
Good luck!
SevenSlotAddict is offline
post #12 of 43 Old 05-25-2021, 09:15 PM
jeep_boy02
1934 CJ7
True on the braided flex lines.
post #13 of 43 Old 05-25-2021, 10:53 PM
Waternut
Waternut's Avatar
Good luck!
Semi metallic work the best of all pads when cold.
Sent from my SM-G981U1 using Tapatalk
Waternut is offline
post #14 of 43 Old 05-25-2021, 10:58 PM
Waternut
Waternut's Avatar
As I talked about in the PM, I think your brake system is fine but your booster just doesn't have the power/performance you're expecting. IMO the only real solution is a dual diaphragm booster. If you can't weld but can get your hands on a 95 bolt in booster, you shouldn't be sitting on it bc those are super hard to find.
Waternut is offline
post #15 of 43 Old 05-25-2021, 11:50 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
less than $100 seems reasonable to me...
shaggyjim and bruinjeeper like this.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
