No start - JeepForum.com
 1Likes
  • 1 Post By GTS225
post #1 of 13 Old 07-04-2020, 06:45 PM Thread Starter
jaycal3
jaycal3's Avatar
No start
On vacation after driving the Jeep 3 hours and got back in to a no start. The gauges move and lights work but there is no clicking or cranking. Any ideas off the top? I thought maybe fuel pump because I donít hear it but wouldnít it still crank?
Iím in Lake George until Monday if anyone is in this area - I have no tools but can buy beer and pay!
Sent from my iPhone using Tapatalk
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #2 of 13 Old 07-04-2020, 09:16 PM
jtec
jtec's Avatar
2014 JK Wrangler
maybe NSS or clutch switch.
jtec is offline
post #3 of 13 Old 07-04-2020, 09:49 PM Thread Starter
jaycal3
jaycal3's Avatar
No start
I may have to have it towed Sunday and hope for a fix by Monday.
KCCO
jaycal3 is offline
post #4 of 13 Old 07-05-2020, 09:49 AM
dead_eye
dead_eye's Avatar
My YJ is an auto and does this sometimes. I shift it to neutral and it will crank and run fine. If yours is an auto, try this.
dead_eye is offline
post #5 of 13 Old 07-05-2020, 10:03 AM
mikewiz38
Could also be the starter. You can test it by jumping the terminals, but use caution.
1994 Wrangler YJ - 4.0L - 5 Speed
mikewiz38 is offline
post #6 of 13 Old 07-05-2020, 10:34 AM
wizekrakr
First thing to check is your battery cables. Pull off both the pos and neg and clean the posts and the cable ends. Make sure to scrape any hardened surface or crust off of them. Then you can go from there. Try some jumper cables. That will usually eliminate battery issues. If nothing still you will need to check the starter trigger. Could be an interlock like stated above with an auto trans.
wizekrakr is offline
post #7 of 13 Old 07-05-2020, 10:44 AM Thread Starter
jaycal3
jaycal3's Avatar
Just wanted to update: it was the ground wire to the block... it was fried and pulled off. All set now!
KCCO
jaycal3 is offline
post #8 of 13 Old 07-05-2020, 03:24 PM
GTS225
Must have been loose or dirty for some time to be fried that badly.
Roger
Boojo35 likes this.
GTS225 is offline
post #9 of 13 Old 07-05-2020, 04:20 PM
Boojo35
1987 YJ Wrangler
Roger
That right there is one of the most misunderstood things in auto electrical. People think that the current or amperage increased causing the meltdown when it is the other way around. Excessive resistance causes heat. The current or amperage actually decreases. Think of a seat heater. It is how they work and why they get warm. When this happens at a connection it is bad juju. Js.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #10 of 13 Old 07-06-2020, 06:40 AM
GTS225
And the load never changed. (Probably the starter motor load) The loose/dirty/corroded connection is what causes the increase in resistance. Trying to pull the same current load through the now poor connection is what causes the heat. Each time this is done, the connection gets just a little poorer and more burnt, until finally, it gives out entirely.
Wait.....maybe I should ask if you're finding fault with my response, or expanding on it?
Roger
GTS225 is offline
post #11 of 13 Old 07-06-2020, 04:19 PM
Boojo35
1987 YJ Wrangler
Roger
Expanding on it.
Boojo35 is offline
post #12 of 13 Old 07-09-2020, 12:44 PM
YoYjay
Expanding on it.
Good to know the two of you didn't have a "disconnect".
I'll let myself out now ...
YoYjay is offline
post #13 of 13 Old 07-09-2020, 01:10 PM
fishadventure
fishadventure's Avatar
Originally Posted by jaycal3 View Post
Just wanted to update: it was the ground wire to the block... it was fried and pulled off. All set now!Sent from my iPhone using iCrapntalkie
Okiedokie then
I was working but then again Lake George is four hours...
[size=ď3Ē]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
