Newer Computer PCM pin-out diagram HERE! - Page 2 - JeepForum.com
post #16 of 26 Old 07-27-2014, 05:57 PM
Shane1447
Which, after seeing this... Makes an interesting point. If i crank the engine for 10 plus seconds, it throws an engine code for ign. Coil 1 and 3, and injector 6. Please help me to repair my ecu. This puppy (2001 xj) has 252,600 miles, and the only thing wrong with her is the damn computer.
Shane1447 is offline
post #17 of 26 Old 04-15-2015, 09:07 PM
matt14
ok guys im having a simular problem i have a 2000 xj was a 2.5 i just swaped to a 4.0 i added my leads with my old wire harness for the injectors and changed some plugins but i bought a 01 computer and it will not pulse injectores 2,3,4,5 but runs on 1 and 6 but i can hook up my 2.5 computer and it runs the first 4 injectors im looking for the wire pin out on the ecm not the plug in its self? please help me out thanks so much
matt14 is offline
post #18 of 26 Old 08-30-2015, 05:13 PM
justmud
justmud's Avatar
Quick question along this thread topic
I'm trying to decipher the answer to my question by reading through his thread. I realize I'm reading a knowledge base that is immeasurable!
My question is can I cross reference my ecu on my 92 YJ to another year? The non programmable plug-n-plays from 92 are almost unobtainable and I'm looking for alternatives.
I have a physically fried multi-pin connector both male and female ends with 1 pin cooked and melted transistors on board. Happened by misfiring the field coil of the alternator directly to the battery while the engine was running.
I don't want to hijack a thread but if anyone could reach out to me in regard to this mystery, I would very appreciative!
Btw.. 30' hunter capt here!
justmud is offline
post #19 of 26 Old 08-31-2015, 03:44 PM
Que89YJ
Any 91/95 ecu with the same engine from an xj or yj will work. The trans doesn't matter.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #20 of 26 Old 10-23-2019, 12:35 PM
MountainMan304
I know this is a very old post, but can anyone tell me why the images have a photobucket watermark that I can't view? Anyone know where to get these same photos?
MountainMan304 is offline
post #21 of 26 Old 10-23-2019, 12:41 PM
IronScott
IronScott's Avatar
Photobucket disabled hotlinking a while back, so they blur or disable viewing embedded photos from other sites. If you use Chrome as a browser, you can google "google chrome photobucket embed fix" and see if the addon extension will work. I haven't confirmed it yet.
IronScott is offline
post #22 of 26 Old 10-24-2019, 05:26 PM
WestfieldMX5
WestfieldMX5's Avatar
The blur is not because of the hot linking. It's because they only allow 25MB bandwidth / month for hotlinked pictures. When owner's account is over the limit, the pictures get blurred until next month. Isn't Photobucket wonderful.
The extension won't fix this.
WestfieldMX5 is offline
post #23 of 26 Old 10-25-2019, 10:33 AM
bluejunior
bluejunior's Avatar
Originally Posted by WestfieldMX5 View Post
The blur is not because of the hot linking. It's because they only allow 25MB bandwidth / month for hotlinked pictures. When your over the, they get blurred until next month. Isn't Photobucket wonderful.
Side note for anyone fighting photobucket: Imgur is free and unlimited. That's where I keep all of my forum images.
Just keep in mind that the default when uploading is to dump it in their public gallery. Just need to flip that switch to private so you can link to it in forums but don't dump it into the meme site for comment.
Lifted, Locked, Stiffened
bluejunior is offline
post #24 of 26 Old 11-16-2019, 02:11 PM
Xomby0
I NEEDED these to fix my '96 that was intermittently stalling/not starting. As my thank you, I've re-uploaded these images on imgur. unfortunately I don't have enough posts. Sorry. I'll try again later.
imgur.com/db9yJND
imgur.com/MqNLxrK
imgur.com/zI9k2dw
Xomby0 is offline
post #25 of 26 Old 11-18-2019, 08:42 AM
bluejunior
bluejunior's Avatar
imgur.com/db9yJND
imgur.com/MqNLxrK
imgur.com/zI9k2dw
All you have to do is wrap the direct link from imgur in img tags, so {img}https://i.imgur.com/db9yJND.jpg{/img} except use the square brackets instead of the squiggly ones.
Like so
post #26 of 26 Old 11-19-2019, 08:50 AM
Xomby0
I don't have enough posts to use the image tags. Thanks, though.
Xomby0 is offline
computer , diagram , ecm , pcm , pin
97 and Newer 2.5L in a YJ?? Jim93YJ YJ Wrangler Technical Forum 0 10-14-2008 07:16 AM
newer 4.0 88wagon TJ Wrangler Technical Forum 4 11-15-2007 05:36 AM
Older or Newer TJ? Falcor TJ Wrangler Technical Forum 15 02-26-2007 02:09 PM
Looking at a newer TJ GoldenEagle TJ Wrangler Technical Forum 6 08-29-2005 01:52 PM
Newer 4.0 into my 91 YJ CuzzinOlaf YJ Wrangler Technical Forum 1 10-07-2004 08:38 AM
