New Member/Possible Electrical Problem 90 2.5L - JeepForum.com
 9Likes
  • 1 Post By Jeepsr4me
  • 1 Post By fishadventure
  • 4 Post By fishadventure
  • 1 Post By BIGJoe29
post #1 of 13 Old 02-13-2019, 09:09 PM Thread Starter
BIGJoe29
Howdy everyone, I had an account on here 5-6 years ago and failure to access resulted in a new account. I am the second owner of this 1990 YJ 2.5L, got it with 89XXX miles and it now has 144XXX miles. It is no longer my DD, so I have the ability to now work on it more extensively. This thing has a Rugged Ridge SYE kit/XJ front driveshaft, 2.5in rough country springs and has gotten a new alternator, battery, starter, fuel pump, brakes and tires within the last 2 years.
It hadn't been driven from Nov2017 to Aug2018, in August I drove it just once around my block. It barely turned over that time and now won't fully turn over even when hooked up to jumper cables. Half the time I turn the key none of the electrical componentry will fire up. Most of the new parts listed above were replaced in pursuit of the problem, the new starter seemed to help for a month but I am now worse off than before. Sorry for the long read, feels good to back on here, massive thanks for any help.
BIGJoe29 is offline
post #2 of 13 Old 02-13-2019, 10:11 PM
Jeepsr4me
Check grounds and the main power cable for corrosion. That is the #1 issue with power.
bharris68 likes this.
Jeepsr4me is offline
post #3 of 13 Old 02-14-2019, 04:44 AM
CESWAMPY
1987 YJ Wrangler
Was it a rebuilt starter?
CESWAMPY is offline
post #4 of 13 Old 02-14-2019, 11:51 AM
fishadventure
fishadventure's Avatar
This
Replacing the cables: if you have a local place that sells welding cable and copper lugs it will cost like $20 to be better than oem.
The ground (-)neg is hypercritical too. Running a couple extra neg(-) cables from the dipstick location to a clean, shiny firewall stud, and another to alternator frame is a benefit, too.
My money is on bad cabling.
Chrisnvegas likes this.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #5 of 13 Old 02-14-2019, 02:46 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
A while back, the site got hacked. So they made everyone change their password. I know that a lot of members couldn't get back on because the email they had on file wasn't any good anymore. If you really want your old name back, you can ask for help from a mod or admin. If you remember what your old email was that will help.
I have a '90 FSM with an electrical manual attached. Send me a PM, and I'll reply with a link.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #6 of 13 Old 02-16-2019, 04:31 PM Thread Starter
BIGJoe29
This will be my first step, I clean anything I can get my hands on, thank you.
I am under the impression it is, it's from Autozone.
Originally Posted by fishadventure View Post
This
Never thought about either of those, if it comes to replacement(and I think it will) I will go that direction. Thanks!
BIGJoe29 is offline
post #7 of 13 Old 02-23-2019, 03:12 PM
Boojo35
1987 YJ Wrangler
You did not drive the vehicle for almost a year as I understand. How did you store the battery or did you keep it maintained?
A battery that is very dead can take many hours to really begin to accept a charge. A low battery that has been frozen is almost certainly junk..... like 99.9% of the time. Car batteries do not like to be cycled below about 50% and cannot do it many times. You may just have a bad battery.
Do you have a voltmeter?
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #8 of 13 Old 02-24-2019, 03:04 PM
Mr.B
Mr.B's Avatar
I see you got your old name back. Congrats
Ham license:
Everyone is Welcome
Mr.B is offline
post #9 of 13 Old 02-24-2019, 05:05 PM
fishadventure
Originally Posted by Boojo35 View Post
...(Car) {starting} batteries do not like to be cycled below about 50% and cannot do it many times?
This is correct.
To elaborate on boojo: 50% discharged doesn’t mean 6V- from a practical engineering perspective, 10V is /past/ 100% discharged, setting at 10V for a period of time creates chemical conditions inside the case that usually spell final death to a starting battery. Once a battery won’t hold a charge they don’t seem to make anywhere near the amps they’re supposed to and they’re essentially useless.
Nevertheless I have attempted to ‘restore’ some bad batteries for a time with a smart charger and then running them. Works rarely but I’m cheap and I try anyway lol
post #10 of 13 Old 03-16-2019, 11:26 AM Thread Starter
BIGJoe29
Hey everyone, finally got access to my account for good. I cleaned both sides of the power cables and every ground I could find. Along with a new battery, she started right up and I drove her around my neighborhood and filled up the tank! Thanks a ton you guys
2.5L w/ AX-5, NP231J w/ Rugged Ridge SYE and XJ front driveshaft, open D30 and D35 w/ 4.10 ratio, stock JK 18in wheels w/ Spydertrax 1.25in spacers and 32in toyo at, 2.5in RC lift with .5in shackles(BESRK), rear TJ flares. 8.8 rebuild soon
BIGJoe29 is offline
post #11 of 13 Old 03-16-2019, 01:18 PM
fishadventure
That’s awesome that you followed up.
Share some adventures!
post #12 of 13 Old 03-19-2019, 09:04 PM Thread Starter
BIGJoe29
Well, I got her running a few days ago(my most recent post). I drove her around my neighborhood again today for about 15-20 for the heck of it, then did some minor work on it before it got dark. Changed some hoses and the air filter, nothing that would affect the electrical system.
Went to start her up tonight and the electrical cut out .25 seconds after turning the key(same problem as before). I know there is corrosion on the main power cable, tomorrow I will be going to a local weld shop to acquire materials for some new power cables and extra grounds.
BIGJoe29 is offline
post #13 of 13 Old 04-15-2019, 07:43 PM Thread Starter
BIGJoe29
I ended up throwing in some new power cables and no more power cutting out! It's been smooth sailing, besides the other things I have to do to it lol. Thinking I need to start a build thread....
BIGJoe29 is offline
1990 , 2.5 , electrical , YJ
A horrible electrical problem... xDraven TJ Wrangler Technical Forum 15 03-05-2020 08:48 AM
High idle electrical problem direwolf TJ Wrangler Technical Forum 10 01-08-2019 11:27 AM
Electrical Problem BSM XJ Cherokee Technical Forum 1 08-16-2018 04:12 PM
Praying you guys had this electrical problem XJtoWJ KJ Liberty Forum 7 07-30-2018 07:52 AM
Electrical problem after leaving the batt disconnected for 2 days OffRoadDevilD WJ Grand Cherokee Forum 8 02-08-2018 04:27 AM
