New Lift Suspension Issues - JeepForum.com
 6Likes
post #1 of 18 Old 07-18-2019, 01:20 PM Thread Starter
ChiefHof
ChiefHof's Avatar
I recently installed a 1.5" Superlift Super Ride suspension lift on my YJ and the springs are now biased to the driver's side of the Jeep. My first inclination was to remove the track bar, but when I loosened the nut on the driver's side of the bar I was able to free-spin the bolt which is telling me that the track bar is in a no-load condition and not the reason for the bias condition. Does anyone have any input on this that may be helpful? For back ground info, I purchased the Jeep 4 years ago from the original owner with just 28K original miles on it and has never been driven in the rain, let alone off road, and never in an accident. All bolts are torqued to 95 lbs/ft as per the maintenance manual and it seems to handle o.k. I'm of the impression that maybe I need to drive it around a bit to settle the suspension, but am out of Schlitz at this point from a troubleshooting perspective...
ChiefHof is offline
post #2 of 18 Old 07-18-2019, 04:15 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Have you checked to see if the front spring hanger mounts have developed cracks along the frame anywhere?
Is there any evidence that any of those same mounts have ever been repaired/rewelded etc?
Joe Dillard is offline
post #3 of 18 Old 07-18-2019, 06:14 PM
bruinjeeper
bruinjeeper's Avatar
i see your track bar is still connected, as you have pointed out
take it off. that should settle it some. You've changed the geometry of your jeep suspension now... you either need an extension bracket on that track bar... or the better and cheaper option is to throw it out. It's not needed and will make your jeep ride harsh.
Despite you pointing out that you could free spin the bolt - just take it off and drive the jeep a bit and settle the suspension.
Boojo35 likes this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #4 of 18 Old 07-18-2019, 07:43 PM
jbolty
jbolty's Avatar
from the picture it looks like the inner tubes are too long or the shoulders on the bushings too thin
jbolty is offline
post #5 of 18 Old 07-19-2019, 06:08 AM
Siva283
Siva283's Avatar
Your shackles also look bent now so you may want to replace them. I have a brand new in the box set of stock shackles. I dont know what your back looks like but I have enought to replace the front. They are crown. THey dont have bushings anymore I used them but you have new bushings so you should be alright.
Ask me how I know...
Siva283 is offline
post #6 of 18 Old 07-19-2019, 10:12 AM Thread Starter
ChiefHof
ChiefHof's Avatar
Joe Dillard, bruinjeeper, jbolty, Siva283...thank you all for the input. Spring mounts are good to go, and I think the shackles and bolt sleeves are all o.k. and to specs. I'll look into the track bar as that's really the only component that would cause the bias and see where I end up...thanks again for having my back on this, I appreciate it...AIRPOWER!!!
ChiefHof is offline
post #7 of 18 Old 07-19-2019, 10:44 AM
jbolty
jbolty's Avatar
It just looks like the shackles are leaning.
jbolty is offline
post #8 of 18 Old 07-22-2019, 06:16 PM
NHfireLJ
NHfireLJ's Avatar
Yup. lose the track bar
AUDREY...95 YJ UNLIMITED
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #9 of 18 Old 07-24-2019, 01:15 PM
bruinjeeper
Any update here?
~YJOTM MAY '16~
~YJOTM JULY '19~
post #10 of 18 Old 07-25-2019, 02:31 PM Thread Starter
ChiefHof
ChiefHof's Avatar
Afternoon bruinjeeper...I finally have a little down-time coming and will be pulling the track bar on Saturday...do you recommend pulling the rear tb as well?
ChiefHof is offline
post #11 of 18 Old 07-25-2019, 02:52 PM
NHfireLJ
NHfireLJ's Avatar
Both are unnecessary
bruinjeeper likes this.
SOLD
style intake
NHfireLJ is offline
post #12 of 18 Old 07-25-2019, 03:49 PM
Awesome
Awesome's Avatar
I don't know how much difference it would make (probably none) but your u-bolts are on all wonky as well.
The 4th 5-seater YJ in the world.
Awesome is offline
post #13 of 18 Old 07-25-2019, 09:30 PM
bruinjeeper
noticed that as well... good eye
~YJOTM MAY '16~
~YJOTM JULY '19~
post #14 of 18 Old 07-27-2019, 07:06 PM
dwtaylorpdx
Make sure the springs are in the right direction, they have a front and a rear. also there are front and rear springs they are not all 4 identical in all sets of springs, the locator pins are about a inch forward.
dwtaylorpdx is offline
post #15 of 18 Old 07-29-2019, 10:38 AM Thread Starter
ChiefHof
ChiefHof's Avatar
Copy all...I pulled the front track bar and the bias appears to be less. I'm getting it aligned today as the steering wheel vertical is now sitting at the 7 o'clock position. The u-bolts are seated properly... the inboard u-bolts are wider and longer than the outboards and sit on a "perch" close to the pumpkin that gives the appearance that they are misaligned when in actuality, they're good to go. Thanks again for all of the input, I appreciate it!
Awesome and bruinjeeper like this.
ChiefHof is offline
