New horn, need pictures of yours - JeepForum.com
 4Likes
  • 2 Post By fishadventure
  • 1 Post By zrickety
  • 1 Post By Awesome
post #1 of 11 Old 01-26-2019, 12:46 AM Thread Starter
xpage
The next step in returning my Jeep YJ to full functional status is putting in a new horn. The old one was missing, along with the relay, and all horn related equipment inside the Jeep.
After getting some parts, I can find diagrams to install the horn button but, I don't see anything for the actual horn wiring outside in the engine. I am holding in the pic below the 2 pin connector for where i think some wiring harness from the horn connects to (any part # on this?), Though the actual horn I bought came with no wiring or leads. This isn't a big issue, I'd just like to know where to connect stuff to so I do it correctly.
Next step after this is to put in a universal windshield fluid reservoir and pump. this pic below shows the tubing for the fluid, and the mystery cylindrical device on the right... I have no idea what it's for or if it's missing wires. Enlighten me
xpage is offline
post #2 of 11 Old 01-26-2019, 05:56 AM
HaskiE
HaskiE's Avatar
yep, first plug is for the horn!
not sure what that second plug is for, I don't think it's for the washer pump(s) they are only two pin box like connectors.
edit:
my original horn looks like this:
https://www.ebay.com/itm/Jeep-Wrangl...d=220829754901
#theneverendingaxe
HaskiE is offline
post #3 of 11 Old 01-26-2019, 08:33 AM
NHfireLJ
NHfireLJ's Avatar
I believe the second is a data port...
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #4 of 11 Old 01-26-2019, 11:51 AM Thread Starter
xpage
ok. The OMIX-ADA 17249.01 Low Pitch Horn didn't come with a connector like that, so looks like i get to spilce wires or hit the auto parts store for a connection. Thanks
data port. ok, looks like i won't be using that. I'll keep it where it is
xpage is offline
post #5 of 11 Old 01-26-2019, 04:54 PM
fishadventure
fishadventure's Avatar
I’d probably not use a stock type horn.
Junkyard: 199x BMW dual tone horn. Very loud, doesn’t blow the fuse. People hear it. No body says it’s its “cute.”
I think of the jeep as essential
HaskiE and Awesome like this.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 11 Old 01-26-2019, 06:29 PM
zrickety
zrickety's Avatar
I put Hella supertones in mine, happy with them. Install was easy.
Visible in this pic
HaskiE likes this.
1988 Jeep Wrangler Laredo
zrickety is offline
post #7 of 11 Old 01-26-2019, 09:33 PM
Awesome
Awesome's Avatar
Very old video, but I don't think anyone here can beat my horns.
HaskiE likes this.
The 4th 5-seater YJ in the world.
Awesome is offline
post #8 of 11 Old 01-27-2019, 10:55 AM
stephencbrinson
There is my original horn.
Sent from my SM-G930U using Tapatalk
1992 YJ, 2.5L, AX5, D30, D35, 2.5 RE lift
Daniel 3:18
Ephesians 2:1-12
stephencbrinson is offline
post #9 of 11 Old 01-27-2019, 10:28 PM Thread Starter
xpage
Thanks, seems I'll get to splice everything in or splice it to a connector if i want to be fancy
xpage is offline
post #10 of 11 Old 01-28-2019, 05:42 AM
stephencbrinson
It was attached to the rusted hole in the fender. But now it just lays there and bounces around.
Daniel 3:18
Ephesians 2:1-12
post #11 of 11 Old 01-29-2019, 07:38 AM
JarheadAl
You can stop that bouncing for $1
JarheadAl is offline
Horn not working clarkg Jeep CJ Forum 8 12-10-2018 11:22 AM
2007 JK Horn Fix and Airbag Removal WranglersDirect JK Wrangler Technical Forum 0 09-04-2018 11:10 AM
Wiring a single horn to the old dual horn Silentmase Grand Cherokee General Discussion 0 06-16-2018 01:29 AM
'95 YJ Horn help... JeepYJ44 YJ Wrangler Technical Forum 2 02-21-2018 07:12 PM
Need Help Installing OEM YJ Horn JeepYJ44 Audio, CB & Ham Radios, GPS, & Electrical 1 02-19-2018 03:53 PM
