New Here! - Page 5 - JeepForum.com
 17Likes
post #61 of 76 Old 09-28-2020, 09:47 AM Thread Starter
CaliYJ3
Originally Posted by fishadventure View Post
Good work!
One of the rocker cover hoses leads to the air box This is the provision for providing filtered air to the motor crankcase- which is ventilated from a hose to a manifold barb. The manifold has more vacuum potential (lower static psi- actually ďnegativeĒ psi to be vacuum- than the airbox which is nearly atmospheric pressure) and this creates a flow into the manifold.
Oil migrating to the airbox is not uncommon due to either blow-by, regular and/or sustained full-throttle low vacuum situations (likely frequent with a 2.5!) or a hydraulic engineering phenomenon that creates a pulsing vapor Ďcloudí where vaporous droplets travel /towards/ the air flow and condense where the pressure drops. (white clouds of fuel standing 2Ē above a carburetor opening on a hotrod motor is an example of this weird thing)
Either way get the hoses right and donít worry about the oil right now. Thatís not going to effect anything youíre trying to do or fix at the moment. Once itís running well you can worry about that.
Thanks for the info! Once I get home from work, i'll put in some coolant and hope it's all sealed up. Then fire it up and take it for a spin!
CaliYJ3 is offline
post #62 of 76 Old 09-28-2020, 10:04 AM Thread Starter
CaliYJ3
Here’s the freeze plug installed
CaliYJ3 is offline
post #63 of 76 Old 09-28-2020, 08:51 PM Thread Starter
CaliYJ3
Fix one coolant leak and another starts , needs a new radiator. But glad the freeze plug isn’t leaking. Sounds better with the new plugs wires and all that.
CaliYJ3 is offline
post #64 of 76 Old 09-29-2020, 04:42 PM
bruinjeeper
bruinjeeper's Avatar
that's how it rolls unfortunately.
good news is you're getting more new parts!
cpia84 likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #65 of 76 Old 10-03-2020, 06:45 PM Thread Starter
CaliYJ3
New radiator is in! NO MORE LEAKS!!! WHOOOOOOO!!
Took it out for a little drive today. Runs 10x better with everything. No more rattle from the rear end! Thanks for the info on that!
Next up:
Brakes
Tranny oil
Front/rear diff oil
Shocks
Probably just going to enjoy it for a few weeks. Appreciate everyone’s help and advice! Glad I came to the right spot.
4642C38E-3A44-4393-BB44-8307C76A160F_1601772305903.jpg   601B83DC-1ADD-438D-AB28-D99BBF305575_1601772318563.jpg
bruinjeeper likes this.
CaliYJ3 is offline
post #66 of 76 Old 10-03-2020, 10:11 PM
bruinjeeper
are you not going to use a shroud for the rad/fan setup?
you could cut down the stock 2.5L one if it came with your jeep ...that's what i did
post #67 of 76 Old 10-04-2020, 09:57 AM Thread Starter
CaliYJ3
No, it didn’t come with it.
CaliYJ3 is offline
post #68 of 76 Old 10-05-2020, 09:06 AM Thread Starter
CaliYJ3
Took the jeep on a little drive this weekend, cleaned up the mess underneath it. Its a nice feeling walking out this morning and not seeing a mess or anything leaking anymore!!
CaliYJ3 is offline
post #69 of 76 Old 10-08-2020, 01:16 PM Thread Starter
CaliYJ3
Question - Has anyone ever tested injectors? I have not so i'm looking for some advice. The car has 170K miles so it may be worth it to buy new ones?
CaliYJ3 is offline
post #70 of 76 Old 10-08-2020, 02:44 PM
bruinjeeper
What gives you the impression you need them? You can noid light it or just pop them off and inspect and clean them.
Fairly certain mine are original. Lol.
post #71 of 76 Old 10-08-2020, 03:02 PM Thread Starter
CaliYJ3
I am getting CEL #27 - "One of the injectors output drivers does not respond property to control signal"
But the CEL is not on when driving, I need to get a smog check, but I don't want to deal with the hassle of it failing.
CaliYJ3 is offline
post #72 of 76 Old 10-10-2020, 05:38 PM Thread Starter
CaliYJ3
Took it for smog and it passed. So I guess the code it was throwing wasn’t popping up. Time to give it a bath and shine it up.
CaliYJ3 is offline
post #73 of 76 Old 10-16-2020, 08:44 PM Thread Starter
CaliYJ3
Not jeep related, but we had a bbq. We all have Dodges. Looking like a dodge used car dealer haha
CaliYJ3 is offline
post #74 of 76 Old 10-19-2020, 08:27 PM Thread Starter
CaliYJ3
Anyone have any recommendations on front fender replacements? There are quite a few options online. Seeing if anyone has positive or negative feedback from their orders.
CaliYJ3 is offline
post #75 of 76 Old Yesterday, 04:02 AM
fishadventure
fishadventure's Avatar
If you’re not ‘restoring’ “classic to current” has inexpensive stuff that works.
From what little I’ve seen, a similarly named company “Classic Enterprises” has much better quality and oem fit.
Look ‘em up and pick one.
I did have a problem with classic2current where their rear crossmember replacements were .020” or so thinner than oem AND they were over 1/4” taller than my factory parts; they wouldn’t refund me or send replacements so I cut and hammered to get fitment. Ymmv
[size=ď3Ē]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
