New Here! - Page 3 - JeepForum.com
 17Likes
post #31 of 76 Old 09-09-2020, 08:01 PM
bruinjeeper
bruinjeeper's Avatar
Originally Posted by pa.driven View Post
Welcome to the forum!
Looks like you need a merry Welcome to the forum as well.
Man, what a great place. We got new members joining an hour before already wishing Welcomes to JF to guys who joined a couple weeks ago! That's the spirit!
Lol.
CaliYJ3 likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #32 of 76 Old 09-09-2020, 08:05 PM Thread Starter
CaliYJ3
I believe it’s leaking. I just changed the thermostat and was trying to run a coolant flush, and it was misting from that area. The overflow reservoir isn’t, but something is spraying water.
CaliYJ3 is offline
post #33 of 76 Old 09-09-2020, 08:06 PM
bruinjeeper
You SURE it's not the reservoir? or the hosing with a pin hole leak?
U sure its coolant? Could also be the green windshield fluid from the windshield reservoir right beside it.
post #34 of 76 Old 09-09-2020, 08:09 PM Thread Starter
CaliYJ3
I pulled the hose out of the reservoir. The reservoir is dry. No windshield fluid either. I don't know what else it could be?
CaliYJ3 is offline
post #35 of 76 Old 09-09-2020, 08:11 PM
bruinjeeper
The hose itself could have a pin hole leak. Ur gonna have to crawl under with a flash light and look while it runs.
Is it a misty liquid? Verified?
Or vapor/fumes/smoke
post #36 of 76 Old 09-09-2020, 08:12 PM Thread Starter
CaliYJ3
Thanks! Going to have to find a face shield cause its hot mist lol Its misty water. I am using water for the radiator flush. After I confirmed the thermostat was no longer leaking, I saw that happening.
Also not sure if this helps, but it doesn't do it until the Jeep is fully warmed up.
CaliYJ3 is offline
post #37 of 76 Old 09-09-2020, 08:15 PM
bruinjeeper
You may also want to check the side of your engine block under the exhaust manifold.
There are plug looking things... "freeze plugs". Could also have sprung a leak on those plugs. Check the side of the block with a flash light, see if you can notice any residual wetness.
When your jeep fully warms up, your thermostat opens... flowing the water. That make sense
post #38 of 76 Old 09-09-2020, 08:21 PM Thread Starter
CaliYJ3
Thanks for all the info, I will jack it up tomorrow and take look! Appreciate the help!
CaliYJ3 is offline
post #39 of 76 Old 09-18-2020, 04:23 PM Thread Starter
CaliYJ3
Sorry been pretty busy. Got the thing on jack stands. I was able to recreate the rattle. Here’s a new link without wind.
https://youtu.be/wHuP78HD3n0
Regarding the leak, I haven’t dove too much into it. But it’s coming a hole on the fender/wheel liner.
CaliYJ3 is offline
post #40 of 76 Old 09-19-2020, 04:18 AM
fishadventure
fishadventure's Avatar
If there’s nothing hitting the driveshaft you need ujoints
That isn’t a leak from that hole, just evidence. It’s either spraying onto inside of there or it’s your overflow tank leaking if that’s your driver’s side
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #41 of 76 Old 09-19-2020, 05:31 AM
bruinjeeper
Agreed. Do some research...dig man, dig!
Give that wet spot a lick. You'll know quickly if it's coolant. Haha
cpia84 likes this.
post #42 of 76 Old 09-19-2020, 01:07 PM Thread Starter
CaliYJ3
Ya I agree, was just showing where it’s coming from. There’s also a slight coolant leak coming from where the motor and tranny meet. I don’t get it lol I change the thermostat and now have all these leaks and they aren’t coming from the housing either lol
CaliYJ3 is offline
post #43 of 76 Old 09-19-2020, 01:43 PM
bruinjeeper
There is a freeze plug back there too.
post #44 of 76 Old 09-19-2020, 09:47 PM
4Low2G0
4Low2G0's Avatar
yes there is, that's a trans out job.
Whats over that next ridge?
4Low2G0 is online now
post #45 of 76 Old 09-21-2020, 01:23 PM Thread Starter
CaliYJ3
If its a trans out job, probably do the clutch at the same time.
CaliYJ3 is offline
JeeperDon
