New Here! - Page 2 - JeepForum.com
 17Likes
post #16 of 76 Old 08-27-2020, 11:48 AM Thread Starter
CaliYJ3
Originally Posted by jbolty View Post
Good news on the rust.
If you are in the mood for wiring do the headlight relay mod. The full power for the headlights goes thru the switch and there is always a significant voltage drop at the lights, plus the switch gets hot and fails.
Thank you, I will def take a look!
CaliYJ3 is offline
post #17 of 76 Old 08-28-2020, 09:50 AM Thread Starter
CaliYJ3
Test mounted the wheels I picked up!
CaliYJ3 is offline
post #18 of 76 Old 08-28-2020, 10:23 AM
cpia84
cpia84's Avatar
Good looking wheels. What tires and size do you plan on putting on the Jeep? As long as the rust is just the driver's floor pan i say you got a good jeep. Enjoy the tinkering and upgrading your Jeep.
cpia84 is online now
post #19 of 76 Old 08-28-2020, 11:04 AM
4Low2G0
4Low2G0's Avatar
Welcome to the group, do what Chris said with the belts, hoses and fluids.
Have fun with your new addiction...LOL
Oh and don't go crazy with tire size with the 2.5!
Whats over that next ridge?
4Low2G0 is online now
post #20 of 76 Old 08-28-2020, 01:55 PM Thread Starter
CaliYJ3
I haven't done any searches on the tire size yet, still haven't decided if we want to lift it. The little ol 2.5 motor is pretty weak. So I don't think I can go to heavy on tires. Probably thinking 31's is my max if I don't lift it?
CaliYJ3 is offline
post #21 of 76 Old 08-28-2020, 03:17 PM
4Low2G0
4Low2G0's Avatar
Check to see what gears it has now.
Drive it as is for a while.
You'll be surprised what the little Jeep will do stock, then decide what to do.
post #22 of 76 Old 08-28-2020, 08:14 PM Thread Starter
CaliYJ3
Created a quick YouTube video of the rattle. Can anyone assist with what it may be?
https://youtu.be/JWA75N_BLEE
CaliYJ3 is offline
post #23 of 76 Old 08-29-2020, 06:09 AM
fishadventure
fishadventure's Avatar
A lot of noise, wind
Anyone else hear a squeaky ujoint and something dangling on a driveshaft?
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #24 of 76 Old 08-30-2020, 01:41 PM
4Low2G0
4Low2G0's Avatar
Yep sounds like a U-Joint or something hung up in the drive shaft,
but when you start off in first gear, I hear a worn transmission.
post #25 of 76 Old 08-31-2020, 09:13 AM Thread Starter
CaliYJ3
Thanks, I couldn't find anything around the driveshaft. I'll check over the u-joints later this week.
CaliYJ3 is offline
post #26 of 76 Old 08-31-2020, 09:40 AM
bruinjeeper
bruinjeeper's Avatar
It sounded lighter as opposed to more dense.
Make sure there is proper clearance for the exhaust system, front to back.
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #27 of 76 Old 08-31-2020, 10:52 AM Thread Starter
CaliYJ3
Next step is put it up on jack stands and see if I can recreate the noise with the vehicle off by spinning the wheels. I think that would help me narrow things down, if it works lol
CaliYJ3 is offline
post #28 of 76 Old 09-09-2020, 06:05 PM Thread Starter
CaliYJ3
Does anyone know what this is? It’s located below the coolant reservoir. Drivers side. Up against the firewall.
CaliYJ3 is offline
post #29 of 76 Old 09-09-2020, 07:04 PM
bruinjeeper
Charcoal.canister.
Part of your emissions control equipment.
Locks in vapors, which then get sucked into the manifold via vacuum for burning.
Looks hooked up properly too.
CaliYJ3 likes this.
post #30 of 76 Old 09-09-2020, 07:22 PM
pa.driven
pa.driven's Avatar
Welcome to the forum!
CaliYJ3 likes this.
pa.driven is offline
JeeperDon
