New Guy with Diff question. To Lock or Not?? - JeepForum.com
 4Likes
  • 1 Post By jbolty
  • 1 Post By Waternut
  • 1 Post By bruinjeeper
post #1 of 14 Old 02-18-2020, 02:52 PM Thread Starter
kittyhawk
Good afternoon everyone,
Well I've been out of the Jeep game for the last eight years and Just picked up a 94 YJ for a Ranch Jeep. I bought a plain jane S with the 2.5L, 5 speed with 4:10 diffs, the rears a 35 with a traclock upgraded shafts, running BFG/AT235x75x15.
I found out a few weeks ago the traclock is not traclocking at all. I changed out the rear diff and refilled with new and added the friction modifier and its still not working properly.
Since Im only using around the ranch with the occasional run to the feed store and DQ I was thinking of replacing the traclock with a lunch box locker.
Now my questions, What's a good locker and one that's an easy install I can do my self, and other than a locker any good options for the front?
I know all about the weakness of the 35 but with the small tires and low HP I figure ill be ok.
I look forward to hearing some input.
Thanks and Stay Safe everyone.
kittyhawk is offline
post #2 of 14 Old 02-18-2020, 03:31 PM
jbolty
jbolty's Avatar
aussie locker is dependable, fairly cheap and easy to install. In my experience it seems to help more in the front and avoids some of the risk from locking the D35
93YJfalcon likes this.
jbolty is offline
post #3 of 14 Old 02-18-2020, 03:50 PM
Waternut
Waternut's Avatar
I would look into rebuilding the trac loc in the rear. Probably just worn clutches and I doubt it'd cost more than about $60 to replace them. I know you said you'll barely drive it on the road but I generally discourage people from putting a lunchbox locker in the rear especially with a manual transmission. The road manners are terrible and every time you shift, the jeep will dart left or right. There are lots of people who learn to live with it. After driving like that once, I refused to do that regularly. As an FYI... friction modifier is used to ease the engagement with limited slip diffs meaning that it makes the clutches slip more. Without friction modifier, the clutches will be a bit more grabby.
An Aussie, Spartan, or Lokka lunchbox locker for the front would be a good, easy upgrade and you'll barely even know it's there until you engage 4wd.
Waternut is offline
post #4 of 14 Old 02-18-2020, 03:53 PM
jkbrereton
Dana 35s don't have a good track record for being locked, but a lot of that may be due to bigger tires and wheeling style. With a 4 banger you might be ok.
Sent from my Pixel 2 XL using Tapatalk
jkbrereton is offline
post #5 of 14 Old 02-19-2020, 12:46 AM
RockWoRM
RockWoRM's Avatar
Any locker you can 'do yourself' IMHO would be an auto lunchbox type. From reviews, the Aussie is prolly your best bet. I had a, IMO, a bullet proof power trax no slip, but they are pricey. Any full locker and even a Detroit will require re-setting gears.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #6 of 14 Old 02-19-2020, 06:52 PM
NHfireLJ
NHfireLJ's Avatar
Agreed, for a ranch truck, even w the D35, Aussie locker
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #7 of 14 Old 02-20-2020, 12:17 PM
paulhead
if it works fix it
paulhead's Avatar
I'm not a fan of the Spartan, pops pretty gnarly. Lockrite I think is the best, just my 2 cents. And I'd only put a lunch box in the front. Full case Grizzly for the rear, behaves great.
Trying to weld has honed my grinding skills
paulhead is offline
post #8 of 14 Old 02-21-2020, 07:35 AM
bruinjeeper
bruinjeeper's Avatar
interesting thread.
been reading up on adding a locker to the rear end lately (would go with ARB as i AM set on the 8.8 as my final axle choice back there).
carry on gents
paulhead likes this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #9 of 14 Old 02-21-2020, 12:32 PM
80cj
80cj's Avatar
1980 CJ5
I installed Detroit Tru Tracs in my freinds YJ. Excellent traction and great street manners and no special lubricants. The downside is the cost and it requires swapping out the differential. Trac loks tend to slip a lot because preload pressure on the clutch plates is relatively low to make them street friendly. They wear out relatively fast.
80cj is offline
post #10 of 14 Old 02-28-2020, 04:05 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Rebuild clutches in the rear and lunch box up front. You should be able to do both for less than $300.
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #11 of 14 Old 02-28-2020, 05:30 AM
Waternut
Waternut's Avatar
Originally Posted by bruinjeeper View Post
interesting thread.
carry on gents
I know this is off topic from the original thread but you should at least look at the OX air locker. Basically the same price except you get a super beefy diff cover, install is a little easier, and for $25 more you can get a "drive-away lock" that in 5 minutes will allow you to lock your diff if you have any issues with your air system or lines.
bruinjeeper likes this.
Waternut is offline
post #12 of 14 Old 03-08-2020, 03:30 PM
Boojo35
1987 YJ Wrangler
Another vote for a rebuild. Very affordable and probably suits a ranch truck just fine.
With that being said though, lots of good suggestions here.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #13 of 14 Old 03-08-2020, 08:17 PM
bruinjeeper
interesting thread.
carry on gents <img src="https://www.jeepforum.com/forum/images/smilies/popcorn.gif" border="0" alt="" title="PopCorn" class="inlineimg" />
Good point.
Just looked into them. Actually cheaper but does not include an actuator, though the cover and the provision for it does eliminate the need to drill through the pumpkin.
Sorry for the mini hi-Jack.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #14 of 14 Old 03-09-2020, 09:00 AM
mudbug85603
mudbug85603's Avatar
A lunchbox locker is not recommended for the D35 they are fine in the D30. Rebuild the LSD you have and add 27 spline 1541H axles or add a Eaton TruTrac with 27 spline 1541H shafts or bite the bullet and add a full case locker that accepts 30 spline shafts and 1541H shafts.
'98 TJ 5sp Super 35 D30 w/Aussie 5.13 on 33's
'94 YJ 5sp 4.88 Super 35/HP30 w/Aussie on 33's
mudbug85603 is offline
