New front driveshaft vibration - JeepForum.com
 1Likes
  • 1 Post By fishadventure
post #1 of 9 Old 08-09-2020, 07:12 PM Thread Starter
tropicalYJ
About 6 months ago I removed my front driveshaft to replace the u-joints, but I figured since I had just installed a brand new rear driveshaft I'd just upgrade to a beefier front one. I had the new shaft sitting in my shed for the past 6 months while I drove my Jeep without a front shaft. Last week, I had some free time so I decided to install the new shaft so I could get out mudding again, and to my surprise the Jeep had a slight vibration that was not there before. I double checked that the u-joints were seated properly and that the straps and u-bolts were tight. At this point I contacted the manufacturer of the driveshaft and they stated that I need a double cardan shaft in the front. The original shaft I removed was not a double cardan shaft and I did not have these vibrations with it.
Some extra info (not sure if it helps): I have a SYE installed in the rear with a double cardan shaft. I have a Spartan locker in the front.
If it's true that my front angle is off, would I be able to drop the t-case slightly even with the SYE in the rear? Really can't afford dropping $300 for a new shaft + another $60 for the output yoke on the t-case, so I'm looking for a cheaper fix. The vibration isn't that bad and I'd like to ignore it but it's definitely noticeable on a 150 mile highway drive and in stop and go traffic. I don't know much about pinion angles and things of that nature so if you could explain this to me like I'm a 5 year old I'd greatly appreciate it.
tropicalYJ is offline
post #2 of 9 Old 08-10-2020, 07:43 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Why is the front shaft spinning in 2wd on a YJ? That's what the CAD is for. Put it in 2wd, jack up the left front tire, and see if you can rotate the tire without the drive shaft turning. If the tire and driveshaft are locked together, your locker is causing the problem.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 9 Old 08-10-2020, 10:22 AM
80cj
80cj's Avatar
1980 CJ5
He has a Spartan locker up front so it will cause the diff to turn.
80cj is offline
post #4 of 9 Old 08-10-2020, 10:42 PM
Waternut
Waternut's Avatar
Dropping the t case drops the rear but angles the front up which makes the front driveshaft angle worse.
My money is that you accidentally pulled the slip joint out of the new aftermarket driveshaft and you put it back together to where the u joints aren't inline anymore.
If the u joints are aligned, download the clinometer app on your phone and measure the angles of your diff pinion angle and the pinion angle of the transfer case. I typically use the lower flange on the axle side and the upper flange on the t case side. Let us know how far off those angles are from each other. You're hoping for less than 4 degrees mismatch and ideally want less than 2.
Waternut is online now
post #5 of 9 Old 08-11-2020, 05:52 AM
fishadventure
fishadventure's Avatar
When did the locker go in? As part of that? Or it’s been there? And the same tires and wheels?
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 9 Old 08-12-2020, 11:27 AM Thread Starter
tropicalYJ
Originally Posted by fishadventure View Post
When did the locker go in? As part of that? Or its been there? And the same tires and wheels?
Same tires and wheels. The PO installed the locker several years ago. I've owned the Jeep for 3 and a half years with it in.
post #7 of 9 Old 08-12-2020, 11:30 AM Thread Starter
tropicalYJ
So I was messing around with the driveshaft and I removed it from the front yoke. When I tried to pull the u-joint back into the yoke, the shaft would not extend no matter how hard I pulled. So I went all muscle man on it and I ended up popping the front part of the shaft off. I put it back to what appears to be the same spline position it was originally in, but now I think I screwed that up. If it is off by 1 spline will it cause a vibration?
post #8 of 9 Old 08-12-2020, 01:10 PM
fishadventure
Yes
Waternut. Seer.
Waternut likes this.
post #9 of 9 Old 08-13-2020, 08:14 PM
Wookiedave
Junior Member
Wookiedave's Avatar
May need to have the front shaft balanced. I had to do that when I put my new front end on and it had a locker. It made my front shaft spin all the time and I found out it was bent slightly. I didnt know with the old front end.
Wookiedave is offline
