New clutch and master cylinder - JeepForum.com
 2Likes
  • 1 Post By stephencbrinson
post #1 of 6 Old 07-12-2019, 01:55 PM Thread Starter
stephencbrinson
I just finished replacing the transmission (ax5 because I lost 1st and 3rd) with a used that was rebuilt 2 years ago.
When I did the swap, I installed a new flywheel, pressure plate, clutch, throw out bearing, and master cylinder.
Now the clutch will not engage. I can put it in gear but nothing when the clutch is out. I am reasonably sure I have it bleed completely. I got the master cylinder from ORiely.
What could cause this?
Sent from my SM-G930U using Tapatalk
stumper likes this.
1992 YJ, 2.5L, AX5, D30, D35, 2.5 RE lift
Daniel 3:18
Ephesians 2:1-12
stephencbrinson is offline
post #2 of 6 Old 07-13-2019, 02:36 PM Thread Starter
stephencbrinson
An update on this.
I have replaced the master cylinder with a new PowerTorque brand from O'Riely's and then an LUK from NAPA. Still no clutch.
I opened the bleeder, filled the master cylinder, pumped the clutch 2x and fluid began to run through the system. I continued to refill the master cylinder until no air came through. I closed the bleeder. Clutch to the floor, cracked the bleeder, closed the bleeder. Clutch up, then to the floor, cracked the bleeder. Repeated 10x or so making sure the master cylinder stayed full.
Started the jeep, clutch in, trans to 1st, clutch out and nothing. Just like it is in neutral.
What should I check next?
Daniel 3:18
Ephesians 2:1-12
post #3 of 6 Old 07-13-2019, 02:54 PM
timatoe
timatoe's Avatar
Internal slave or external? Also when you say there's nothing, does that mean if you start it in gear with the clutch pressed in it tries to take off?
timatoe is offline
post #4 of 6 Old 07-13-2019, 03:05 PM Thread Starter
stephencbrinson
Internal slave.
By nothing I mean that it is like the clutch is depressed all the time. I can start in gear with the clutch out with no issue. I can shift gears with the clutch out.
Daniel 3:18
Ephesians 2:1-12
post #5 of 6 Old 07-13-2019, 05:40 PM Thread Starter
stephencbrinson
I figured it out.
The transfer case was in neutral.
timatoe likes this.
Daniel 3:18
Ephesians 2:1-12
post #6 of 6 Old 07-14-2019, 08:30 AM
timatoe
timatoe's Avatar
Originally Posted by stephencbrinson View Post
I figured it out.
That was my next question. FYI, if the clutch isn't working it will be "in gear" essentially all the time (assuming it's actually in gear).
Glad it wasn't anything major. Nice to have a problem like that every so often.
timatoe is offline
