Negative arch SOA Springs - JeepForum.com
 4Likes
post #1 of 16 Old 04-11-2019, 09:25 AM Thread Starter
Duck Doctor
Had a set of double military wrap springs built for my SOA build that were theoretically designed to provide 1” lift over stock springs.
Installed the springs and drive about 100 miles over a couple months. Couple weeks ago went on a two hour long easy trail ride. Get home and the leaf springs sagged to the point that they now have a noticeable negative arch. Lost about 2” of height in one day.
Should I just toss these springs and have a new set built by another company? I need the additional ground clearance for the Rubicon trail and Fordyce. Going to have to run the TJ until I can get this suspension issue dealt with.
Duck Doctor is offline
post #2 of 16 Old 04-11-2019, 12:10 PM
Steve707
Steve707's Avatar
Did you buy them new? Id try to contact the company you bought them from if they sagged that much so soon.
Steve707 is offline
post #3 of 16 Old 04-11-2019, 01:12 PM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by Duck Doctor View Post
Had a set of double military wrap springs built for my SOA build that were theoretically designed to provide 1 lift over stock springs.
Installed the springs and drive about 100 miles over a couple months. Couple weeks ago went on a two hour long easy trail ride. Get home and the leaf springs sagged to the point that they now have a noticeable negative arch. Lost about 2 of height in one day.
If you are tossing money away, Toss some this way...
^^^ This...
FWIW, I'm running crown 6 leaf with added main leaf and 37's with plenty of height . Not too expensive too. Do you really need that extra inch? She maybe, but you?
AUDREY...95 YJ UNLIMITED
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is online now
post #4 of 16 Old 04-11-2019, 01:24 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I agree with Steve, that is too much sag too soon. Contact the mfg.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #5 of 16 Old 04-11-2019, 02:59 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I recall your other thread from a few months ago about the new Atlas leaf's when you were installing them.
https://www.jeepforum.com/forum/f12/...ected-4338025/
Judging by the looks/design of the Atlas leaf's you installed a few months ago, I'm not surprised.
Yours remind me of some brand new leaf's that a friend was testing out on his SOA YJ. His didn't last for even one trail before they gave up the ghost.
Joe Dillard is online now
post #6 of 16 Old 04-11-2019, 04:59 PM Thread Starter
Duck Doctor
Yeah. They are Atlas springs. Those extra inches are absolutely necessary wheeling in the California rocks otherwise I’ll just spend the entire time hungup on the rockers.
I have a built XJ and TJ that I also use but thought this YJ would be a fun rig to build.
I’ll Likely just buy a new seat of springs from Alcan or Deaver. Don’t feel like dealing with this again. Should’ve spend the extra few hundred dollars upfront. Now I get to buy twice.
post #7 of 16 Old 04-11-2019, 07:38 PM
Boojo35
Wow... Those give spring steel a new name.
bharris68 likes this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
post #8 of 16 Old 04-11-2019, 07:59 PM
fishadventure
fishadventure's Avatar
Not saying your springs aren’t junk but just curious what you did for bumpstops.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #9 of 16 Old 04-12-2019, 04:41 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
This, If they go negative arch especially alot you can kill the main leaf quick. Also, the quickest way I have seen leafs killed is from a heavy braking event with large tires. I killed a set when someone pulled out infront of me and they wrapped and unloaded a few times while I was hard on the brakes. They were on the jeep for two days. I believe @Radonexplosion had a similar issue braking before a sudden rut IIRC.
Randonexplosion likes this.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #10 of 16 Old 04-12-2019, 06:37 AM
JeeperDon
JeeperDon's Avatar
Just get a set of RE SOA 1.5" springs, done. I've had mine for near 15 years with no issue, on both northeast and southwest tough stuff. You absolutely have to add an anti-wrap to the rear. Set it all up right once, done for years.
bharris68 and timatoe like this.
Web Admin for
post #11 of 16 Old 04-12-2019, 08:26 AM
timatoe
timatoe's Avatar
I'd do the 1.5 RE's or 2" BDS.
I ran the 2" BDS for a long time with no issues SOA, through the trails you've mentioned. I only pulled them because I went full width with a substantial stretch, they're still rocking on another rig no issue.
timatoe is offline
post #12 of 16 Old 04-12-2019, 11:32 AM
Randonexplosion
Randonexplosion's Avatar
@87TPIYJ Radonexplosion sounds way cooler
Randonexplosion is offline
post #13 of 16 Old 04-12-2019, 02:12 PM
Joe Dillard
Yeah. They are Atlas springs. Those extra inches are absolutely necessary wheeling in the California rocks otherwise Ill just spend the entire time hungup on the rockers.
I know what you mean. "LCOG" rigs tend to find themselves at the end of a snatch strap or winch more often if wheeling in the big rocks (I'm talking JV).
I lived in SoCal for ~50 years, and wheeled there since the 70's up until I moved out east ~5 years ago.
post #14 of 16 Old 04-13-2019, 10:27 AM Thread Starter
Duck Doctor
Thanks for the help guys. I’ll look into the BDS and RE springs. Hope to have a new set installed within the month. I installed the MORE anti wrap last week.
post #15 of 16 Old 04-13-2019, 10:37 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Thanks for the help guys. Ill look into the BDS and RE springs. Hope to have a new set installed within the month. I installed the MORE anti wrap last week.
I think you just solved the issue. Those pictured by Joe Dillard are from spring wrap, which every time I hear "SOA" I also end up hearing "Spring wrap" in a conversation shortly after.
Rick
Cutlass327 is offline
Negative arch on SOA springs Waternut YJ Wrangler Technical Forum 9 02-04-2019 06:29 PM
How much settling on stock HD SOA springs? Waternut YJ Wrangler Technical Forum 19 01-13-2019 09:19 PM
Custom SOA Leaf Springs Taller than Expected Duck Doctor YJ Wrangler Technical Forum 29 12-23-2018 09:50 AM
SOA springs welderman85 YJ Wrangler Technical Forum 20 05-24-2018 06:35 AM
Anyone have Alcan Springs for SOA? ejg3855 Jeep CJ Forum 14 01-27-2018 11:30 AM
