Need Mech. Help!! Not Sure What I Did To It!! - JeepForum.com
post #1 of 7 Old 12-26-2002, 03:40 PM Thread Starter
Hsoj
Guest
Ok here we go, I just got my jeep 2 days ago and I took it wheelin today. I went through some small spots fine, there was one really big hole that I hit 3 times, the 2nd time through my jeep started making popping sounds from the exaust. On the way home it stalled and I could not get it going. it would restart but when i let off the clutch it would backfire and cut off. I had to hae my dad tow me home with my escape :-( What could it be?
Hsoj is offline
post #2 of 7 Old 12-26-2002, 03:42 PM
YJwrangler93
Guest
You may try checking the distributer. Thats what usually throws my jeep outta wack.
YJwrangler93 is offline
post #3 of 7 Old 12-26-2002, 07:53 PM
NaeKid
NaeKid's Avatar
Did you play in the water, snow, mud, or dry sand and such?
I found with my Jeep, if I ran over rough enough roads at high enough speeds (some people would call it high speed off-roading) electrical parts would break connection ... and I would stall out.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #4 of 7 Old 12-26-2002, 10:45 PM Thread Starter
Hsoj
Guest
I was going through some water about 2 feet deep, maybe 3. then just mud other than that.
Hsoj is offline
post #5 of 7 Old 12-27-2002, 08:46 AM
NaeKid
NaeKid's Avatar
Sounds like the standard aversion to water syndrome that my Jeep exhibited .. moisture in the distributer really sucks the big one.
What you have to do when that happens is pull the distributer off, dry it as best as possible (rotor and cap), then smear a little bit of die-electric grease on all the connections inside the cap and on the rotor.
Pull the plug wires, make sure that they also are dry, and then goop the die-electric grease onto the connectors on the top of the cap and put the wires back on.
You should be fine till the next big run into water
Silver
NaeKid is offline
post #6 of 7 Old 12-27-2002, 09:47 AM
Gator
Guest
you got water in your Distributor & got all the igntion connections wet.. since your into Mudding, take a big can of WD-40 with you next time... when you know you are going mudding, pop the hood open & spray the entire ignition system, along with the Fuse block that sits in front of the battery... the WD-40 keeps water & moisture out
oh to help clean up, take the cheapest cooking spray & spray your inner fender wells & under the jeep some... Mud wont stick to it
Gator is offline
post #7 of 7 Old 12-27-2002, 01:10 PM
virgil_likes_rum
Guest
I had the same thing happen to me when I went through a lil lake (big big puddle). I dried the distributor connections and spray WD 40 and it worked like new. I have heard that using the grease is better and longer lasting though.
virgil_likes_rum is offline
mech in Mississippi? juandicuad Mississippi Jeep Forum 6 03-24-2014 11:29 AM
Mech. Oil Press Guage Install 4.0 TJ KLM TJ Wrangler Technical Forum 3 07-10-2009 05:15 AM
another real quick mech ? JeepJunkieIFFA YJ Wrangler Technical Forum 3 07-19-2008 01:04 AM
My mech put a hole in my frame.... durangoyj YJ Wrangler Technical Forum 8 11-17-2007 07:36 PM
mech gauge DirtyJeep95 YJ Wrangler Technical Forum 3 02-23-2007 02:05 PM
