Need to know gear ratio - JeepForum.com
post #1 of 8 Old 01-10-2010, 01:23 PM Thread Starter
jkind
1987 YJ Wrangler
I got under the Jeep and it has a Dana 30 in the front. I can't make out anything else except stamped numbers reading 43622. I hear that the 4.2L YJ's came with 3.07 ratio. I need to replace the rear end and need to match these up. What should I look for?
jkind is offline
post #2 of 8 Old 01-10-2010, 01:26 PM
K9trnr
K9trnr's Avatar
there should be a small plate between 2 of the blots on the dif cober that states your gear ration, if you cannot find it, I would suggest e-mailing "Jeep" (I cannot find the link) and getting a build sheet....that is, if you are sure it has not been modified already.
Chuck
formerly known as "cwagoner"
"Things will remain the same until they change"
1989 F350
K9trnr is offline
post #3 of 8 Old 01-10-2010, 01:26 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
If you need to replace the rear end, open up the rear diff and look at the stamp/casting number on the ring gear. That will give you your rigs ratio.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 8 Old 01-10-2010, 01:29 PM
Otahyoni
Otahyoni's Avatar
1986
There might be a steel tag that has the axle specs on it held under one of the cover bolts, or another option would be to pull the cover and count teeth. Other than that i'm afraid i'm not much help...
~Chris
And all of the diodes may have committed suicide, leaving you with a fun whirly thing under the hood that produces nothing.
Otahyoni is offline
post #5 of 8 Old 01-10-2010, 01:37 PM
Howiedooit
last resort, count the teeth, # of ring gear teeth/ #of pinon teeth = gear ratio
Howiedooit is offline
post #6 of 8 Old 01-10-2010, 01:39 PM
Fhajad
Fhajad's Avatar
Use this link and provide your full VIN for the build sheet: Contact Jeep
Fhajad is offline
post #7 of 8 Old 01-10-2010, 02:23 PM
postaldave
postaldave's Avatar
Jack up the rear end. Count driveshaft revolutions while rotating the tire. Turn the tire 2 complete rotations if your other tire remains stationary and does not rotate. Turn the tire 1 complete rotation if the other tire turns in the same direction. The number of times the driveshaft rotates equals the gear ratio. If the driveshaft rotates about 3x, the gear ratio is 3.07. If it rotates 3 3/4 turns, the gear ratio is 3.73. You can mark the driveshaft to help you count.
tape a string onto the driveshaft if you want to make it fool proof
postaldave is offline
post #8 of 8 Old 01-10-2010, 07:28 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
x2 on the rotate and open the diff test.
I had an axle with a tag saying 3.07 on the front when I got the jeep and I popped it open and it was 3.07!
I did a spin on the rear and calculated 3.73 but the darn tag said 3.07. Popped the cover and it was an aftermarket pinion gear with 3.73.
Since then, when I buy axles at yards, I ignore all tags and pop covers and read the rings.
The guys are saying read the ring gear. It will not always just say 3.07 3.73 or 4.1 on it. It will say something like "41 10", or 41 ring gear teeth and 10 pinion gear teeth, or 41/10 = 4.10. Or.."41 11"...41/11 = 3.73...etc etc...
hotelconucc93 is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 07:30 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
