!!Need Help!!Power Train Control Module for 1991 jeep wrangler - JeepForum.com
post #1 of 4 Old 10-06-2004, 12:25 PM Thread Starter
Bjh
Guest
Just got off the phone with the dealership and they said that my Jeep will not run because the Power Train Control Module is not working. They said that the Voltage Regulator is inside this PCM.
They also said that this part has been discountinued and they found it used somewhere in California, for around $450!!!! Wtf!! I have all ready put a lot of money into this Jeep just to get the clutch fixed but now another $450 is the NAIL IN MY THE COFFIN .
I could use any advice, information, or MONEY$$$(just jokin aabout the $$)
Thanks for any responses!
Bjh is offline
post #2 of 4 Old 10-06-2004, 12:37 PM
jenmal
Try these guys: www.ecmsplus.com
I can hardly believe that this part is that much money, I think the dealerships screwing with you. I would search for that item elsewhere. Here is another place too: http://www.rockauto.com/ and http://www.restore4x4.com/index.tpl?...eCP5&term=jeep
jenmal is offline
post #3 of 4 Old 10-06-2004, 08:42 PM
razskidoo1
Guest
Whats the problem?
razskidoo1 is offline
post #4 of 4 Old 10-06-2004, 10:35 PM Thread Starter
Bjh
Guest
Alternator is not keeping its power, because of the PCM. They said its an external alternator and it takes readings from the PCM.
I recharge the battery and within a couplr of days its dead again. I all ready got a new battery, battery cables, and alternator. They have all been tested and they all work except for this PCM.
And I cant find it any where unless its under a different name. I've tried Rockauto.com and restore4x4.com.
Bjh is offline
93 wrangler electronic control module jws1961 YJ Wrangler Technical Forum 0 01-31-2008 06:40 PM
Jet Power Control Module joburnet TJ Wrangler Technical Forum 7 02-27-2007 08:08 PM
power control module q's rick95 YJ Wrangler Technical Forum 8 08-15-2006 07:35 PM
OK......BOUGHT MY FIRST JEEP -- 1991 Wrangler 6 Cyl 4.0L juanplopez YJ Wrangler Technical Forum 11 10-18-2005 05:21 AM
power control module??? krbl111 TJ Wrangler Technical Forum 0 12-23-2002 07:26 AM
