!need help! 92 yj frame. - JeepForum.com
post #1 of 4 Old 06-09-2009, 07:40 AM Thread Starter
flaviovaldez198
need lots help and advice. i recently wrecked my 92 wrangler yj,i hydroplanted into a slow moving semi. i bent the frame where the right front motor mount is. everything looks ok.trucks turns on and moves.
i need to know what other frames would fit onto my wrangler. years and makes.please.and thanks. i dont want to sell her.
flaviovaldez198 is offline
post #2 of 4 Old 06-09-2009, 07:52 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Any YJ frame '87-'95 will work. However for motor mounts, the 2.5 frame will not work obviously. The 4.2 and the 4.0 share the same motor mount setup.
rustywrangler is offline
post #3 of 4 Old 06-09-2009, 08:00 AM Thread Starter
flaviovaldez198
do you know if any other frames would,from like a tj,xj,etc.?
post #4 of 4 Old 06-09-2009, 08:04 AM
rustywrangler
No other frame will work. They are all different. The XJ does not have a frame BTW.
bestop frame better than stock soft top frame? goose142004 YJ Wrangler Technical Forum 10 11-24-2009 12:34 PM
rigid frame or flexible frame blackcat471 TJ Wrangler Technical Forum 8 08-12-2009 02:18 AM
swap wrangler frame with cj7 frame midgetdog YJ Wrangler Technical Forum 7 04-15-2009 10:58 AM
YJ on a TJ frame Ironwind1972 TJ Wrangler Technical Forum 20 03-23-2009 05:18 PM
How diff is TJ windshield frame and YJ frame? darioc YJ Wrangler Technical Forum 6 02-09-2008 04:30 PM
