Mystery plugs - JeepForum.com
post #1 of 5 Old 08-13-2021, 03:49 PM Thread Starter
cwstaton
cwstaton's Avatar
Mystery plugs
Can someone tell me what these two plugs are supposed to connect to??
Once a project, always a project
cwstaton is offline
post #2 of 5 Old 08-13-2021, 07:05 PM
jkp
My guess would be for the A/C that would mount to the bracket above the alt.
'92 Islander
'06 Rubicon
jkp is offline
post #3 of 5 Old 08-13-2021, 10:44 PM
timatoe
timatoe's Avatar
The round one for sure A/C, other one might be as well. They used the same harness regardless of options installed.
timatoe is offline
post #4 of 5 Old 08-14-2021, 06:07 AM
fishadventure
fishadventure's Avatar
Or is it the idle-bump for the power steering on a 2.5? It could be the high pressure switch- you’re probably right.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is online now
post #5 of 5 Old 08-15-2021, 09:36 PM
SevenSlotAddict
IIRC, the FSM has all the plug drawings in the Electrical portion. A couple guys here have them to DL from their signatures. Having a copy of the FSM is the best reference you can own.
Good luck!
SevenSlotAddict is offline
