Mystery Flat Tires? - JeepForum.com
post #1 of 7 Old 01-06-2003, 11:26 AM Thread Starter
swoodnj
Guest
Mystery Flat Tires?
About a month ago I got a flat, and the shop aired it up and could not find anything wrong with it. I put it back on the Jeep and it was fine for about a month...then it went flat again. Once again there didn't seem to be anything wrong with it, I aired it up and have been driving it the last few days with no problem. I am due for new tires, these have some tread left but are getting down there. Just wondered if anyone else had encountered this...
Steve W
PS. Tires are Goodrich All Terrain T/As.
swoodnj is offline
post #2 of 7 Old 01-06-2003, 12:25 PM
Kev
Master of the Obvious
Kev's Avatar
Have you put Fix-a-Flat in the tire? I have seen a few instances such as yours being the result of the Fix-a-Flat sealing the leak for awhile then leaking and sealing up again, etc.
Another possibility are slow leaks; slow leaks can be hard to detect - the most common (in my experience) slow leaks are:
- poorly sealed beads (rust, dirt, wheel weights, etc preventing a good seal),
- plugged holes (if you must plug a tire to get home, get it patched properly ASAP), and
- leaking valve stems/cores.
HTH
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #3 of 7 Old 01-06-2003, 12:42 PM Thread Starter
swoodnj
Guest
Thanks for the reply. I've never used Fix-A-Flat on this Jeep, I"ve had it almost 2 years. The mechanic did say there was a little rot around the bead of the rim, not sure if he did anything about it or not. He did put in a new valve stem.
Ordering new tires today, have had enough of this! I hate the feeling of riding around wondering if/when the tire's going to go flat again...
Steve W
swoodnj is offline
post #4 of 7 Old 01-06-2003, 12:55 PM
Ed Croft
Guest
Yup, I have the same tires and one went low...guy at the shop thought it might be the seal on the rim, so put goo on there to stop any leaks and mounted it back on....(the plugs had been replaced with plug/patches)....still would go low after that. So I went with the tire sealer....worked for a while and now VERY slowly loses air. But like you the tread is getting down there and I'll have to get new ones soon anyway...(with new valve stems).
Really hard to find a slow leak.
I have seen tires hit glass....(from accident site or crap along the road).
What happends is you get a small sliver in your tire, then its "ground up" eventually from driving on it. And you can get a leak that is a BEAR to find if the hole is just so small from a sliver of glass.
I've also seen them get a big hunk of glass in there and have a good size hole left when the glass is ground up. (No problem spotting those!!)
Ed Croft is offline
post #5 of 7 Old 01-06-2003, 01:08 PM Thread Starter
swoodnj
Guest
Well, I'm sorry for your troubles but I am glad that it's not just me! I just got done ordering 4 new All Terrain T/As, don't really have the $$$ but as I look outside at the snow falling....
Steve W
swoodnj is offline
post #6 of 7 Old 01-06-2003, 03:33 PM
89YJmoneypit
KMG365
89YJmoneypit's Avatar
Rims
Make sure they clean your rims where the bead seals real good,I was having the same problem & they said it was because there was corrosion around the rim. They said it was fairly common with the alloy jeep rims.
89 YJ
Transplanted '99 4.0, AX-15, NP231
Red Jeep club #8
Now belongs to my daughter.
97 ZJ Laredo
4.0, 42re, NP242
R.I.P.
Marseilles Fire Dept:
89YJmoneypit is offline
post #7 of 7 Old 01-06-2003, 03:52 PM Thread Starter
swoodnj
Guest
Thanks, someone here at work just said the same thing. Will be sure they clean up the rims...
Steve W
swoodnj is offline
Flat tires! Gope YJ Wrangler Technical Forum 5 08-19-2009 10:24 AM
Lifts, Flat Fenders and Tires. bradbodigon TJ Wrangler Technical Forum 8 05-21-2009 09:42 PM
Tires Flat Spotted tigerheart87 TJ Wrangler Technical Forum 7 03-30-2009 10:57 AM
Flat tire mystery? CHRRRIS TJ Wrangler Technical Forum 13 08-13-2007 07:49 AM
Can front tires vary in diameter if I have a flat? gravelled TJ Wrangler Technical Forum 1 08-05-2003 02:34 AM
