!!!!!!!!my new jeep!!!! - JeepForum.com
post #1 of 12 Old 09-15-2005, 06:21 AM Thread Starter
natedawg87317
hey guys
after long moths of seaching i finally found a new jeep to replace the on i totaled, and i couldnt be happier. its a 93 4.0 with 139000 miles but the motor was over hualed 60000 ago. its that bright blue color ( if anyone knows the real name please tell me i have a little surface rust repair to do). once i figure out how to put picture on the internet i will post some.
nate
natedawg87317 is offline
post #2 of 12 Old 09-15-2005, 11:13 AM
Tarheelkidd
Tarheelkidd's Avatar
Nate,
Crongrats! I just purchased my first jeep a month ago. It is a 93. I was told that my color was teal blue. I am not sure if that is the color you have or not.
Tarheelkidd is offline
post #3 of 12 Old 09-15-2005, 02:27 PM
ditchdoc
ditchdoc's Avatar
Good job on the new jeep. I have a bright blue 91 and my color is Canyon Blue metallic. Paint code is KCA. Look on your plate on the firewall it will have your paint code on it. BTW if it is canyon blue good luck finding it over the counter. I'm lucky enough to have a wife that works at a body shop so I had them mix me some up. According to the Jeep dealer the color has been discontinued and they have no more cans or touch up.
Jason
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
CSA Jeepers Association Member #6
ditchdoc is offline
post #4 of 12 Old 09-15-2005, 07:35 PM
brcfan0142
Guest
congrats!!!, heres my first jeep
i got my 93 4.0 about a month ago, this is my first jeep, and i'll never own another type of vehicle. If something happens to this one, i'll be gettin another one. LOL
It has a 4 inch body lift with 33 X 12.50 BFG At's. Someday I wanna drop it to a two inch body, and add a two inch suspension.
Sorry picture is a little blurry, it was taken with my cell.
http://pg.photos.yahoo.com/ph/dm131/...08.jpg&.src=ph
brcfan0142 is offline
post #5 of 12 Old 09-15-2005, 10:05 PM
Hokie_YJ
The RockFather
Hokie_YJ's Avatar
Yeah, that's something you definately should do. That much BL puts way to much strain at the body mounts, and with our YJs gettin on up in years, you don't want the body to give way around those mounts. Then you'r right back on the frame where you started. Not good at all.
Edit: It is a good looking jeep, body seems to be real good. Mine is the same color, but I got a black hard top, and black steel rims.
"Beat it like it owes you money"
Jeep Wrangler with some bolt-on "stuff"
Hokie_YJ is offline
post #6 of 12 Old 09-16-2005, 02:27 AM
blevinsbulldog
i didnt even know they make a 4'' bl
95' RIO GRANDE
2.5 AKA THE SCREAMING HAMSTER
REAR TRACK BAR REMOVED
1 1/4 SHACKLES---3''BL
33X12.50 BFG A/T
GREEN JEEP CLUB MEMBER # 176
blevinsbulldog is offline
post #7 of 12 Old 09-16-2005, 02:58 AM
xxxflhrci
xxxflhrci's Avatar
My' 89 has had a 2 inch BL under it for nearly 10 years. It ain't fell to the frame yet.
xxxflhrci is offline
post #8 of 12 Old 09-16-2005, 04:52 AM
ginsy
Guest
He is talking about the 4 inch body lift, 1-2 is the max that most people should go. cause of the added strain on the body mounts. i personally am not a fan of body lifts and at most would do a 1 inch
ginsy is offline
post #9 of 12 Old 09-16-2005, 05:25 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
They dont make a 4in body lift.....legal reasons. 3 is as big as it gets....unless he's using 4x4 wood blocks Nice looking tho!
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #10 of 12 Old 09-16-2005, 03:32 PM
dylanking
Guest
Hmm... in Canada I know that ProComp has a 4" Lift Kit :O)
But, 3" is still pretty high, especially if you go for an SOA too.
dylanking is offline
post #11 of 12 Old 09-16-2005, 04:52 PM
brcfan0142
Guest
it is a three inch lift, sorry, i just measured it. i said four inch because the guy i bought it from said it was four. should have measured first.
i never put the lift on it, the previous owner did. If i did it, it would have been a suspension lift.
Oh well i don't get rough with my yj, i keep it clean, no mud on this frame
post #12 of 12 Old 09-16-2005, 10:12 PM
Hokie_YJ
The RockFather
Hokie_YJ's Avatar
Clean....... I think i've washed mine twice in the 2 years i've owned it., I've Forgot what it looks like clean.
Hokie_YJ is offline
Pulled a Fellow Jeep out in wading Riverlong island..anyones jeep? LITJGuy Wrangler General Discussion 72 12-16-2010 09:31 AM
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 09:22 PM
Jeep Mopar Part No 82210294 Jeep JK Rubber Liner muttytruckster JK Wrangler Technical Forum 3 09-03-2009 08:11 AM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
