My Jeep won't start - JeepForum.com
post #1 of 10 Old 06-12-2021, 08:35 PM Thread Starter
sambosma
My Jeep won't start
My Jeep Wrangler 1995/4 cylinder/manual was stored for winter and I tried starting it today. It did not start and just made continuous clicking noises.
When I jump start using my daily car it is still not turning over. It cranks for a short time and stops.
I tried taking the battery terminals out, cleaned them thoroughly and attached them again. Is my battery completely dead/busted that even jump start won't help? Do I need a new battery?
sambosma is offline
post #2 of 10 Old 06-12-2021, 10:57 PM
xpage
check relays aren't corroded and check the electromagnet moves/clicks when given power.
ASD relay, fuel relay could be culprits. Did you check for spark when it is cranking?
xpage is offline
post #3 of 10 Old 06-13-2021, 01:32 AM
Chrisnvegas
Chrisnvegas's Avatar
Stored for the winter. What's that? Just let it sit? Or did you remove a battery cable and keep the battery on a trickle charger?
Yeah, the battery may be fried if you just let it sit and discharge to death. So many jumper cables. Some aren't worth a sheet.
So thin they can't carry enough amperage to turn the starter.
I'd charge the battery overnight first. See if it will take a charge.
Societies that are truly free can survive only if an open debate and an uncensored exchange of ideas can take place
Chrisnvegas is offline
post #4 of 10 Old 06-13-2021, 05:50 AM
Johndj32
I thought you were asking what winter was.
I would check the battery with a multimeter. Both at rest and under load. If the battery is good it should be 12.4 volts or more at rest after charging overnight like Chris said. Under load it should still be around 10 volts for at least 30 seconds.
Johndj32 is offline
post #5 of 10 Old 06-13-2021, 07:26 AM Thread Starter
sambosma
I live in New England with harsh winters and lots of salt on the road. I don’t want to damage the rails even though they aren’t perfect. So I disconnect the negative terminal of battery and put tarp on it from Nov through May. And cancel insurance and registration. Past two years it just started after I connected negative terminal.
The battery shows 10 volts only. This is why I am jump starting it.
I have to say that jumper cable gets warm. My understanding was that the engine should start even though battery is dead since it draws all the juice from donor battery.
https://streamable.com/qlrzth
I will buy new cables and also get battery tested.
sambosma is offline
post #6 of 10 Old 06-13-2021, 07:26 AM Thread Starter
sambosma
Please see video https://streamable.com/qlrzth
sambosma is offline
post #7 of 10 Old 06-13-2021, 07:45 AM
Johndj32
I'm not a mechanic but I've had my fair share of dead batteries and that sure seems like a dead battery.
Like Chris said jumper cables aren't what they used to be. If it reads only 10 volts with no load the battery will not have enough power to crank it, just like the video shows. Try charging it overnight like Chris said, if it still says 10 volts you have a bad battery.
In theory you should be able to jump it, but the connection has to be good and the battery can't be too far gone or the power goes to charging the bad battery and not to starting the rig. Hope this helps.
Johndj32 is offline
post #8 of 10 Old 06-13-2021, 10:29 AM Thread Starter
sambosma
She’s roaring like a Lion.
It was the jumper cables. Like you guys said cheap jumper cables do not carry enough amp to kick start starter on a dead battery. I bought new heavy gauge cables and let the dead battery charge for 12 mins.
I measured 14 volts at battery and also at positive terminal/alternator body. This was to make sure that Jeep has good ground. I turned the head lights on and they were bright. Finally, gave the ignition and she started after a little stutter.
I have not turned her off yet. I will go directly to auto parts store to get the battery checked and replaced if necessary. Thank you for all your help. This thread is closed.
sambosma is offline
post #9 of 10 Old 06-13-2021, 03:21 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
....he was
This was my first winter "sitting" the jeep.
I give her a few fan cycles every 3rd day to charge up the battery and keep the juices flowing. Trickle charger is less hands on, but i like my hands on my jeep
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #10 of 10 Old 06-17-2021, 06:41 PM
Johndj32
Originally Posted by bruinjeeper View Post
....he was
I use mine for plowing in the winter, but not on the road, just my driveway so it doesn't see salt anymore. So my hands on is using it to get my other vehicles out. In northern Wisconsin we get a fair amount of snow (Lake Effect kicks in ), not sure how that compares to the snow in Toronto though.
I can't imagine living where it's hot and dry all the time. I like the season change myself. I do have to say I'm jealous of the NO RUST though.
Johndj32 is offline
