Master Brake cylinder - JeepForum.com
post #1 of 6 Old 08-14-2019, 01:13 PM Thread Starter
Fletcherman
Hi. I have a 94 YJ in the UK. Master break cylinder gone. Jeep have given me a part number 5252627 but I can't find this part, only number 5252626. It looks identical? Does anyone know more... Will this fit
Fletcherman is offline
post #2 of 6 Old 08-14-2019, 03:58 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
You are most likely not going to find a mopar replacement part unless its been remanufactured.
I'd try your local online parts supply places & get one for a 1995 4.0L YJ. This way, you'll get a dual diaphragm master cylinder, and buy the '95 YJ booster too at the same time.
You may need to reflare the fitting where the hardline goes to the master but that's easy.
Your brakes should work much better with a dual set-up & they don't take up too much more space.
Joe Dillard is offline
post #3 of 6 Old 08-14-2019, 04:36 PM Thread Starter
Fletcherman
Thanks. It seems there are a lot of replacement master brake cylinders that say they fit the 94 2.5L. Are these then not the right part? Thanks for your help.
post #4 of 6 Old 08-14-2019, 07:53 PM
fishadventure
fishadventure's Avatar
they’ll fit but what he’s telling you is the ‘95 YJ 4.0 part fits also-!- and it offers you improvement in braking for
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #5 of 6 Old 08-15-2019, 02:03 AM Thread Starter
Fletcherman
Thanks good advice
post #6 of 6 Old 08-15-2019, 01:01 PM
timatoe
timatoe's Avatar
If you have the means to modify the pushrod, TJ boosters and masters are readily available and super easy to install. There's a thread on here in YJ Tech on what mods are needed.
timatoe is offline
