Mass confusion surrounding my YJ. - Page 3 - JeepForum.com
 14Likes
post #31 of 32 Old 04-07-2019, 04:30 PM
Boojo35
1987 YJ Wrangler
Originally Posted by blake989 View Post
For the original topic, I've rolled my 95 4-banger on all versions of tires, wheels, and lifts over the last 20 years...the two biggest impacts to speed/power were: gearing and wheel type. Gearing was the biggest, but you're going to see the RPMs go up and fuel needle go down quick (currently running 4.88s behind an automatic). Ran steel wheels for a while, then eventually picked up a set of 17" alloys, and believe it or not that was a very noticeable difference (in a good way).
It goes back to what @Chrisnvegas said. Bigger tires equals more reciprocating mass or weight. The weight alone puts a strain on the driveline and axles. BUT..... IT ALSO REQUIRES MORE BRAKING FORCE. You are stopping and accelerating more reciprocating weight. The other difference is the increased tire diameter reduces your effective gear ratio. with that being said.
Did you tires on your 17" wheels have the same diameter and revolutions per mile as the tires on your steel wheels? Yes. You went in the right direction removing reciprocating weight..... for sure....
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #32 of 32 Old 04-10-2019, 04:06 PM
blake989
Yes. After that experience I did a little research on the topic of rotating mass and centripetal force. Physix is real man!
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
2.5 , 4cyl , 5spd , wrangler , YJ
CONFUSION: Pelosi wishes ‘Happy Thanksgiving’ — on Valentine’s Day! SDDAVE Politics, Religion & Controversy 3 03-07-2019 07:53 AM
Mass airflow sensor codes Bertzjeep WK Grand Cherokee & XK Commander Forum 0 01-01-2019 07:50 AM
307 mass shootings in 2018? ezflip Politics, Religion & Controversy 25 11-13-2018 01:36 PM
New Jeep owner from Mass MandalorXJ New Members/Introductions 1 11-07-2018 02:11 AM
Does the NP241 come with mass vibe dampner ? RoscoeJ Engines & Drivetrain 7 12-06-2017 09:57 AM
