March 2019 YJOTM - Vote Now! - JeepForum.com
View Poll Results: Who is YOUR March 2019 YJOTM elect?
paulhead 3 9.09%
daddyjeep87 5 15.15%
Awesome 1 3.03%
bpounds 2 6.06%
DirectMatrix 1 3.03%
AZdEvilYJ 12 36.36%
bruinjeeper 9 27.27%
Voters: 33. You may not vote on this poll
 12Likes
Closed Thread
post #1 of 30 Old 03-26-2019, 05:18 PM Thread Starter
bruinjeeper
bruinjeeper's Avatar
Voter Rules
1st rule of YJOTM is you do not vote for yourself.
2nd rule of YJOTM is you DO NOT VOTE FOR YOURSELF.
3rd rule of YJOTM is you do NOT solicit votes from outside JF or within JF. Investigations have been held, jeeps have been disqualified. DON'T do it!
4th rule of YJOTM is all nonsupporting members must post when you vote or it will not be counted. Paid members do not have to post when voting.
5th rule of YJOTM is all voters will remain public as to promote self moderation
Up for grabs: Bragging rights for March 2019 YJOTM and $200 gift cert. from Qtec (Thank you @Quadratec - you rock). REMINDER: All YJOTM winners are automatically entered for the chance at being voted for the illustrious title of YJOTY as well as inclusion on the /f12 Calendar. Let's Git'r DONE!
Username: paulhead
1994 YJ
Been building this thing up for the last 3-4 years. Got it with 114K original miles 33's, 2.5" lift, winch and stock everything else. Moab seats are probably my newest mod, switched from RS's. Does a new girlfriend that I turned into a jeep head count as a mod? Tag her on then.
Build Thread
Details are as follows:
94 YJ 4.0 3spd with trans cooler, Rustys motor mounts, Optima Yellowtop, '95 booster/MC upgrade
Transfer Case NV241OR (4:1) Rubicon Rock Trac, Adams drive shafts front and rear
D30 , Yukon (Warn) hubs, Lockright, Beefy steering, Dynatrac u-bolt flip kit
Ford 8.8 w Yukon Grizzly locker, Superior Super 88 kit and Ruff Stuff spring under ubolt plates, 4.10 gearing
4” Zone springs,
35” General Grabber X3’s
Smitty winch, Hi lift, homemade 5lb CO2
Armor, Barnes 2" belly drop, Rustys dif covers, CCFAB
tube fenders, rockers. Gas tank mod to add 5 gals.
Cushy Grant steering wheel and Corbeau Moab seats
Username: daddyjeep87
1987 YJ
-Specifications and modifications
From the ground up...
35x12.50 Cooper STT's on cheap steelies
Front Axle - Late 70's ford radius arm high pinion Dana44
-extended radius arms and Ballistic Joints on the frame end
-4.56 gears
-Detroit True Trac
Rear Axle - Late 70's ford 9"
-disk brake conversion
-Single Triangulated 4 link
-4.56 gears
-Detroit Locker
Custom built suspension, 5" or so higher than stock
-ADS 16" travel Nitrogen shocks all the way around
-Ballistic Fab shock hoops front and rear
-Rear lower links are 2"-1/4" wall DOM with 2.63" Ballistic Joints on both ends
-Rear upper links are 1 1/2"-1/4" wall DOM with more Ballistic Joints on both ends
-Wheel base stretched to 102"
Steering box moved forward 2"
Astro Pitman arm
High steer
RCI fuel cell behind the rear seat
Modified family style cage that is tied in to the rear shock hoops
Rear bumper built off of the frame with receiver hitch and fixed tire carrier
Front bumper build out of 1/4" plate with integrated winch mount, Ballistic Fab D-ring mounts, and 2" rock lights
Front fenders built out of 1 3/4"-.120" wall square tubing and 14 ga. plate
Trail Tubes stinger welded to front bumper and bolted to front fenders
Quadratec Q9500i winch
3/16" rocker guards bolted to the tub
'95 ish 5.7 TBI engine - stock, but cleaned up to look nice
'79 Turbo 350
'95 NP241C with ORD SYE kit
Custom built adapter from TH350 to NP241
Modified XJ t-case shift lever
Champion aluminum radiator
Optima red top
Custom built battery box
Home built drive shafts
Custom Krylon paint complete with old school hot rod flames. This was modeled after the Muscle Machines toy Jeeps if anyone remembers them
Quadratec Bimini plus
-Brief history of your jeep and how it came to be.
I originally bought this jeep in February of 1999. It ran like crap due to the stock carb, but that was soon replaced with a Holley 2 barrel. I put on a 4" Rough Country lift and some 31" BFG MT's and ran it like that for a lot of years. It eventually got a Howell TBI upgrade. After the frame rusted out and the tranny died it slowly got build into what it is today. I had a 5.2 rebuilt by my local VoTech school, but that didn't work out so well. I am now finishing up my GM drive train swap. Somewhere around 2001 is when It picked up the DaddyJeep name. My oldest son would hear me coming home from work and run to the door and say "DaddyJeep" so it kind of stuck.
My newest DaddyJeep artwork.
Username: Awesome
1995 YJ
Specifications and Modifications:
4.0 I6
AX15, NP231 w/'True Neutral', Tummy Tuck – True Flat Belly
TeraFlex Super Short Slip Yoke Eliminator
Tatton's Beefy Driveshafts front and rear
8.8, 4.10:1, Limited Slip, Disk Brakes, U-Bolt Flip, Solid cover
D30, WJ Knucles/Brakes, 1-ton Crossover Steering, CAD Delete, Aussie, 4.10:1, Solid cover
31x10.5x15" Duratracs (too small)
Custom front bumper, Rugged Ridge 8500lb Winch
Rear Tire Carrier Bumper, LED Reverse Light Bars
York On Board Air, Freightliner Air Horns
Bilstein 5100 Series longer-travel shocks, Custom shock extensions in the rear
Superlift 3.5" Springs, sagged to about 1.5"- maybe a bit more, Custom Shackles
1" Body Lift
Track Bar / Sway Bar Delete Mod
Ford Ranger Front Bench Seat – Jeep seats 5
Custom Shifter Knobs
Cobra GMRS Radio
Custom Security Storage Trunk
I've built the whole thing myself. A lot of time and effort went into building this Jeep. I don't have a dedicated build thread, but I've documented the major modifications in threads through the years. I purchased it when I was 17 at the behest of my dad, who owned a TJ Rubicon at the time. I've owned it for about 12 years now. I met my wife because of this Jeep (seriously), dated her in this Jeep, and I got married to her in this Jeep. Although it is no longer a daily driver and I live in an area where four-wheeling is scarce, I will keep it until one of my kids eventually wants it. I belong to a Jeep club that is fairly active, and I go wheeling with them whenever I can. The whole family rides along in the 5-seat YJ.
Pictures:
Username: bpounds
1988 YJ
We call her Mauser after my favorite smokepole. In 2013 I found myself working at a newly relocated office, and no longer had access to a full working fab shop. I've always been a hands on kind of guy, and now with the kids all grown and gone, and no company shop to tinker around in, I figured I needed a gas and oil hobby to keep my hands busy. I started out looking for a Samurai, just something to run around town in, but decent smog legal units were hard to find, and even worse to find parts for. So once I came to my senses I upshifted gears and started looking for a CJ or YJ. Found this one for $3,900 and away we go. I have very modest goals for her, nothing like some of the great rigs we see around here. And there is no hurry either, because our journey together is what matters, not the finished rig. The best thing is, my wife loves this thing as much as I do.
Original 4.2L
Howell TBI fuel injection
CRT HEI ignition
Retro-fit NEW AX-15 with external slave
Advanced Adapters SYE
True neutral TC mode shifter
Adams rear DC driveshaft
Brown Dog motor mounts
Zone 2" lift
Berzerks 1/2" boom shackles
No tracks, no sways, no problem
Dirtworx rear bumper and tire carrier
Warn M8274 Winch with remote SS relay
Mod'd battery tray with Optima Yellow
Military terminals
Custom HD battery cables
LED front fogs
LED rear backup lamp
Green LED dash cluster lights
22" light bar on custom mounts
14" Windshield Wipers mod
Late model TJ side mirrors
Custom mirror relocation
Rugged Ridge console and seats
In & out GOpro mounts
Custom Maglite Rack
Decals to cover scar tissue
Daily Driver
Username: DirectMatrix
1992 YJ
jeep name: Delilah
I don't really consider this a build in the traditional offroading sense. More mods centered around fun projects I want to tackle, or have tackled, to make my YJ exactly the way I want it. I'm all about fit and finish that makes the Jeep appear stock, but is a vast improvement over what Chrysler did in 1992.
As she sits currently, she has the rebuilt 2.5L engine with about 40,000 miles on it and the majority of the Jeep is stock. All work was done by me, mostly with inspiration from things I found on JF. Upgraded items include:
Westlake SL369 - 31x10.50R15LT 109Q tires
complete overhaul of the fluids, suspension bushings and steering components
Chevy Tahoe overhead console/switch panel DIY
Ford Explorer front seats
Nissan Pathfinder tire carrier fabbed/modified to fit
Fabbed drop down tailgate from Ford Econoline rear door hinges and stock YJ tailgate.
aftermarket hood assist kit with modified rad supports
Hidden Hitch towbar
DIY dual battery kit with self rescue and fabricated battery tray
stainless brake lines throughout DIY bent myself
15>20 gallon fuel tank mod
4.0L throttle body mod
new mirror relocation brackets fabricated from a Mitsubishi Montero
handbrake mod from a ZJ
Gentex temp/compass dimmable rear view mirror from a Saturn View
Mishimoto electric fan
130amp Denso alternator upgrade plus DIY big 3 cable upgrade
Brown Dog motor mounts to keep those 4 pesky squirrels in place and under control
Upcoming projects include:
Restore CJ hardtop
Restore fiberglass hard doors
finish wiring overhead console
finish installing Ford Explorer split fold rear seats
DIY lizardskin/monstaliner on the interior
new front bumper and fenders
exterior paint job
axles at some point in the far future
Now that I'm a homeowner, I'm really close to getting her to be my garage-kept project car, rather than my daily driver and then I can really get to work! So many projects have been waiting to get finished. All I've been doing lately is changing the oil and driving it.
Build thread: https://www.jeepforum.com/forum/f12/...hread-4119729/
Night time wrenching. Who has time during the day?
Playing around in a rare southern VA snowstorm.
From two, I will make one!
Engine rebuild
Username: AZdEvilYJ
1995 YJ Rio Grande
I got my YJ in a trade for my 1994 GMC K1500 back in the beginning of 2009 when I decided to go back to college. I didn’t want to give up my 4wd but needed something more fuel efficient… what better than a 4banger jeep!! I drove it bone stock for about 7 months while I paid off some debt, and then the jeep bug hit. It started with some 130watt spot lights, then some 30in mud tires. As I wheeled more, gained more experience behind the wheel, and tackled tougher terrains I have evolved my jeep out of necessity through trial & error, all while still maintaining my mall-crawlin’ good looks
After almost 6 years of enduring the 4cyl stuggles, I have finally pulled the trigger on my v8 swap and after many beers, re-do’s, electrical gremlins, transmission leaks, and more beers the swap is complete with a few offroad trips on it and about 2500 miles, im loving the power of the 350 and the ease and control of the auto trans (I know I know…).
All the struggles have been worth the effort until the next phase of the build! I have the superduty 60 in the garage, plans for the matching Sterling 10.25/10.5 and then the parts collection will commence.
Here’s the current specs:
• 1994 TBI 5.7 350, Advanced Adapters Motor Mounts
• 1988 700r4 with Lokar 12” Shifter
• 1988 NP231cHD / 1995 NP231j Hybrid with JBFAB Billet cable shifter
• JB Conversions SYE and a shortened and beefed up XJ CV front drive shaft for my new rear shaft
• Ford Taurus 2 speed electric fan with Volvo relay, Saab inline temp housing, and VW 2spd temp switch
• Dodge Durango Steering Box and Ruff Stuff Heim Steering
• Locked F/R - HP30(Solid Cover, Lock-Rite Locker, TJ shafts, Timkin hubs, 4.10) and Ford 8.8 (Solid cover, Lokka Locker, Disc Brakes, 4.10)
• Metalcloak 4” arched Front Fenders
• Metal cloak Frame-built Bumper with Winch Guard and Hi-Mount Shackle System
• Warn VR8 winch with, 100’ of synthetic rope and billet hawse.
• Rubicon Express 4in suspension, BSERK stock length Shackles
• 35x12.5R17 ProComp MT2 and 17x9 KMC enduro beadlocks
• Poison spyder full custom cage
• Poison Spyder Crusher Corners and Hood Louvers
• Barnes4wd full length rocker sliders
• Modified TJ Bestop extend-a-trunk security tonneau
• C-RES top, Bestop Supertop and soft doors, CJ7 Full Steel Doors
ROKMEN aluminum drop down tailgate
Mastercraft suspension seats
• Projector LED headlights
• KC cyclone LED rock lights, LED tail lights, red LED dash lights, 7’ 45w LED spots on the windshield, and 12” IllumiNationLed Light Bar up front guiding the way
• Pioneer stereo with Rampage steel security console, 12” shallow-depth Pioneer Sub, Kicker Amp, and I’m sure plenty of other stuff here and there.
Username: bruinjeeper
1995 YJ
Rebuilt 2.5L/30RH/NP231J
- 3.5" BDS springs
- 3/8" Currie greasable boomshackalaka's front, 1” lift booms rear
- 33x12.5r15 Cooper Discoverer S/T
- 15x8 Cragar soft 8's
- Bilstein 5100s
- D30 w/ TJ shafts (CAD delete) and shock mounts moved up on tube w/ perches mounted atop setup for SOA with 1" Stretch, Built Ford 8.8 w/ G2 aluminum cover – 4.56 gearing
- 4.0 Throttle Body
- 1” JKS MML
-American RatRods aluminum hood vents.
- Currie SS braided extended brake hosing all around
- RR SYE and XJ cut down rear driveshaft
- Beefy DOM steering linkage, cross over heim steering setup (TMR bracket)
-M.O.R.E rear shock extensions
- 136AMP GC alternator and wiring upgrade
- Flex-a-lite electric fan conversion
- LED CREE Headlights wiring/relay upgrade
- Transmission cooler and deep tranny oil pan for the auto tranny
- LED undercarriage lighting, 3x3 LED light pods (x4), 2x7 LED light bars (x2) 1x6 LED mini light bar mounted on rear spare tire relocated license plate.
- Poison Spyder BFH winch bumper
- S]-[ittybilt 10K X20 wireless waterproof winch
- Modified china made rear swing out tire carrier (shovel mount, rotopax mounts, flagpole mount, hatchet mount)
- Red LED interior lighting/gauges
- Blue Black Widow racing buckets w/ Sparco 4 pt. Harnesses
- Rampage frameless soft top with Bestop half door sliders.
- 4" flush mount tail lights and dime LED reverse lights
- Airaid CAI, full Pacesetter longtube headers into a magnaflo cat and dumped out of a Walker SoundFX exhaust before the rear axle.
- Rock hard cage tie-ins and overhead mounted switch panel
- Monstalined interior and exterior
- S]-[ittybilt 0" front tube fenders, S]-[ittybilt rear 3" tube fender flares and rocksliders with tube step
- Dime size LED signal (x8) incorporated into the stock system. Front of tube fender, tube fender side wall, rear quarter panel, tire carrier.
- Home brewed drop down tailgate table
In the near future:
1” BL, Front shock hoops, OBA, Tummy tuck (but this is always changing)
Lil' More:
My only daily driver and still kickin'. Thanks for helping me get sicker, and sicker... it's been a fun and bank account crippling adventure that has taught me a lot of good. Thanks guys and gals for the fantastic relief from the daily grind, and for all the future endeavours y'all will undoubtedly assist with. Just adding into the numbers here – no good pics yet with all the new additions. It's getting to a point where I can be fairly confident when i do challenge it and myself.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #2 of 30 Old 03-26-2019, 06:08 PM
Bong_Holyeo
Bong_Holyeo's Avatar
ugh im gonna have to stew over this one for a day or two..
April 2018 YJOTM
June 2019 YJOTM
Bong_Holyeo is offline
post #3 of 30 Old 03-26-2019, 06:56 PM
Waternut
Waternut's Avatar
Voted
Waternut is offline
post #4 of 30 Old 03-26-2019, 08:27 PM
Awesome
Awesome's Avatar
Dang. AZDevil decides to come back and make the competition tougher. What's up with that?!
paulhead likes this.
The 4th 5-seater YJ in the world.
Awesome is offline
post #5 of 30 Old 03-26-2019, 08:40 PM Thread Starter
bruinjeeper
his blackout period ended
~YJOTM MAY '16~
~YJOTM JULY '19~
post #6 of 30 Old 03-26-2019, 09:12 PM
Awesome
Awesome's Avatar
No, I mean he wasn't on the forum much for a while.
Awesome is offline
post #7 of 30 Old 03-26-2019, 09:28 PM Thread Starter
bruinjeeper
I know. His visits correspond with the ending of his YJOTM black out periods lol.
..I'm kidding of course
~YJOTM MAY '16~
~YJOTM JULY '19~
post #8 of 30 Old 03-27-2019, 07:51 AM
TSEJEEPERS
TSEJEEPERS's Avatar
Voted
Thanks for doing this bruinjeeper!
bruinjeeper likes this.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 30 Old 03-27-2019, 09:10 AM
jeep63
jeep63's Avatar
Another good month!
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
post #10 of 30 Old 03-27-2019, 11:26 AM
Steve707
Steve707's Avatar
Voted.
Steve707 is offline
post #11 of 30 Old 03-27-2019, 02:28 PM
jmart2119
One Nation, Under God
jmart2119's Avatar
This is a great lineup! Gonna have to think about it for a couple days...
2018 YJ of the Year
YJOTM | Aug'15 | Dec'16 | Jan'18
1989 YJ - 98 5.7L Vortec, 4L60E, NP241, D30+8.8, 5.13's, 35" ProComp MT2's
jmart2119 is offline
post #12 of 30 Old 03-27-2019, 02:29 PM
jmart2119
jmart2119's Avatar
No but for real though
DirtKar and bruinjeeper like this.
2018 YJ of the Year
post #13 of 30 Old 03-27-2019, 02:59 PM
Dake
Dake's Avatar
Voted
Waiting on my Rough Country lift to sag!
April 2020 YJOTM
Dake is offline
post #14 of 30 Old 03-27-2019, 04:48 PM
stcarter44
Voted
stcarter44 is offline
post #15 of 30 Old 03-27-2019, 05:35 PM
Awesome
Awesome's Avatar
Voted.
I really had a hard time deciding. All of these are good rigs.
Awesome is offline
Closed Thread
March WJ of the Month Contest (2019) - VOTE NOW! ChrisHager WJ Grand Cherokee Forum 10 04-01-2019 12:01 PM
March 2019 YJOTM - Enter Now! bruinjeeper YJ Wrangler Technical Forum 32 03-25-2019 06:22 AM
February 2019 YJOTM - Vote Now! bruinjeeper YJ Wrangler Technical Forum 37 03-04-2019 08:03 PM
YJOTM - March 2018 - Vote Now! bruinjeeper YJ Wrangler Technical Forum 25 03-31-2018 09:41 PM
March 2018 YJOTM - Vote now! bruinjeeper Wrangler General Discussion 0 03-25-2018 09:58 AM
