Major Repair, Mean Max's AX-15 Rebuild QUESTION THREAD!!!! - Page 15 - JeepForum.com
 3Likes
post #211 of 212 Old 04-25-2018, 10:17 AM
sheza65
Originally Posted by fishadventure View Post
Mean Max mentions to not lose this pin for first gear spacer... If you do- or in my case, find it damaged- you can make one.
Or just buy one. I did recently. It was $3.99 at Advance Auto and had it quickly vs $1.99 at Quadratec & waiting a bit longer for shipping.
The OMIX-ADA Part # is 18886.25 and the description is for an AX5, but it is the correct part for the AX15 too.
https://shop.advanceautoparts.com/p/...625/10185326-P
If you need the first gear thrust washer too it is OMIX-ADA Part # 18887.34.
https://shop.advanceautoparts.com/p/...734/10185277-P
sheza65 is offline
post #212 of 212 Old 04-25-2018, 01:34 PM
fishadventure
fishadventure's Avatar
Originally Posted by sheza65
Or just buy one. I did recently. It was $3.99 at Advance Auto and had it quickly vs $1.99 at Quadratec & waiting a bit longer for shipping. The OMIX-ADA Part # is 18886.25 and the description is for an AX5, but it is the correct part for the AX15 too. https://shop.advanceautoparts.com/p/...625/10185326-P If you need the first gear thrust washer too it is OMIX-ADA Part # 18887.34. https://shop.advanceautoparts.com/p/...734/10185277-P
Cool. This will be useful for some folks I'm sure.
Buying isn't always an option, and money isn't always the obstacle... I wasn't willing to wait and nobody local had anything. It took less time to make it than the first auto parts store call I made so I wouldn't waste my time. Never mind IF they had it the 55-60 minute round trip to get it is what I mean.
I posted the specs for it as I couldn't find them in the manual and figured someone else might want to know what to do. Sometimes NOW is the right time for folks, not several days later. You CAN buy almost anything; you DON'T always have to.
Cheers
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
transmission , rebuild , ax-15 , repair
My 94 rebuild thread trucknut YJ Wrangler Technical Forum 53 06-22-2015 04:45 AM
Major Repair - AX-15 rebuild Mean Max YJ Wrangler Technical Forum 43 02-15-2014 06:01 AM
YJ major rebuild barney9393 YJ Wrangler Technical Forum 5 07-12-2006 07:36 PM
Anyone use Loctite thread repair? sentinal02 YJ Wrangler Technical Forum 9 10-07-2005 03:49 PM
