Major Repair, Mean Max's AX-15 Rebuild QUESTION THREAD!!!! - Page 14 - JeepForum.com
 3Likes
post #196 of 212 Old 10-03-2017, 01:38 PM
fishadventure
fishadventure's Avatar
@coop2729 when you say it won't downshift while driving/moving but it will downshift stopped. Describe how it feels/acts/sounds/moves when it won't downshift while moving. Will increased pressure get it to shift? Can you double clutch and get it to shift? I'm uncertain as to the logic here.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #197 of 212 Old 10-04-2017, 12:34 PM
coop2729
@fishadventure It won't shift down into 4th at all at high speed. There is no grinding but double clutching will not allow it to fall in. It literally feels as if there was no gear there for it to shift in. I have tried forcing it in with a moderate to fair amount of pressure but it does not feel as if it even would slip into gear. I don't want to break anything so I did not go neanderthal on it with pressure, but I think it's fair to say it does not want to engage back down into 4th gear at higher speeds. At rest, the gear shifts in very smooth with no problems, moving around 10-15mph it also shifts down from 5th to 4th pretty smooth. When I'm doing 45-50 it will not shift in whatsoever. I don't know how to better explain it than that. Hopefully that gives you a better idea of what's happening.
Thanks,
Justin
coop2729 is offline
post #198 of 212 Old 10-04-2017, 01:21 PM
Opihi59
from here it gets rough
Opihi59's Avatar
I've built a few of these AX 15s, Can't say I have encountered your issue before, and now after going thru the manual about 4 times, I really can't come up with a legitimate reason for this to happen, and of course a solution to your issue.
A few things come to mind but only weakly. We do know there is a reverse pin in the tail housing, it is designed to prevent you from going from 5th into reverse without moving across the neutral gate. Not sure if you removed this and then replaced it incorrectly, or it has a broken spring, but it's a thought. The other issue is the restrictor pins, you do know that there is a Left and a Right restrictor pin, they are not interchangeable even though they will screw in on either side. If you may have swapped left for right and vice versa, that's a real weak possibility. One of them has a stiffer spring and off the top of my head I can't recall which one is stiffer. Note that I say weak, but it's not a big deal to remove them and swap sides and see if that makes a difference, unless you absolutely know for certain that you did not swap them left for right in your rebuild. I always stamp mine with a die, or a pin punch with a little L or R before I remove them. Really not sure if this makes a functional difference AT ALL. I'd post up photos of this but thanks to Photosuckit......
Another thought is just let it go for a while, see if something doesn't bed in with a little mileage and get better with time. I know on at least one of my rebuilds it took a while for the synchros to bed in properly, and I felt at that time my error was going straight to Redline MT-90 synthetic rather than using another lube first, then changing over at 500 miles. I'm going to guess you're using an El Cheapo 10W-30 motor oil lube in your tranny like the rest of us. What leads me to this suggestion is that this transmission will make the 5 to 4 downshift stationary, or at low speeds. It can't be totally FUBAR or TARFU with this degree of function so drive it for a while and don't go all Jihad on it. Yet.
Good luck on this.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #199 of 212 Old 10-05-2017, 06:46 AM
fishadventure
I'd probably listen to opihi anyway, but if at speed it goes into 3rd from 5th, and then WILL go into 4th, I'd just go with opihi59's suggestion and drive it. Just curious- when you're double clutching are you throttling up in neutral to spin the shaft faster? Then clutch-in and shifting to 4th?
When I read posts with mystery weirdness like this I always wish the poster was nearby so I could drive it. I'm no jeep guru but when I drive friends cars or trucks with mech-oddities the result after experiencing the problem is a light bulb coming on in my head
post #200 of 212 Old 10-06-2017, 08:55 AM
coop2729
The pins were all put back in where they came from. When I try double clutching, I do rev it up in neutral but the result is the same. If I wasn't planning on selling it I would just continue to drive it as is, it really doesn't bother me that much. Over the past few days I've really been messing with it when driving to see if I could get it to go in and I actually did get it to shift down a few times. I got it to drop in by double clutching but when I move it down into 4th I wiggled it from side to side slightly around where 4th gear should be while pulling it down. It didn't drop right in but every once in awhile I could get it to down shift, most of the time I still had to got from 5th to 3rd.
coop2729 is offline
post #201 of 212 Old 10-06-2017, 09:05 AM
mark1305
mark1305's Avatar
Without going back through this whole thread I can't remember if I posted anything prior to my simple complaint about Photobucket on the previous page.
But, just in case I haven't.... When I changed the oil out in my AX-15 soon after getting the Jeep a few years ago I pretty much drained all the synchros out as brass flakes. Luckily I grew up in the 60s & 70s driving more sticks than autos and not all sticks were synchronized back then. Now this won't really apply if there is an issue with a pin placement on one of the shafts, but may help if its a synchro issue even though the box was rebuilt.
Mine demands a quick shift 1-2 at low speed. A slow shift 2-3 and 3-4 at whatever speed. I almost never use 5th even on the expressway near me. And its hard to get a smooth shift up to 5th and harder shifting down to 4th again. Sometimes I instinctively double clutch in downshifts anywhere from 4th down to 2nd and only shift to 1st at a stop. I use an axiom from when I was a motorcycle track day instructor that we pounded into students - brakes are for slowing but downshifts are for preparing for the next acceleration and not engine braking. Coming to red lights or stops in say 3rd gear I just clutch or go to N and coast to the stop using only brakes.
But on the routine downshifts it is almost an even split between double clutching or slightly more often just holding the clutch in and coasting around the corner or whatever and using gentle pressure on the stick to see if it will slip into the lower gear. If not, then the double clutch. It becomes a "feel" thing with the gearbox.
I have test driven a YJ with a good AX-15 so I know what I'm missing. But as long as mine doesn't puke steel chips and I can shift it old style I'll leave it alone. Still have to tackle the clutch over the so called cool and dry season down here during the winter.
And naturally I had planned on pulling my box and running it down to Mean Max when he was still in Stuart, just a couple hours away. Waited too long and he went up to the Midwest for a new career. Like the old saying, "Timing is everything".
Like I said, if not just a synchro type issue this may not help, or maybe help get by until another tear down.
mark1305 is offline
post #202 of 212 Old 10-06-2017, 09:42 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I keep trying to post this info on old threads that have been killed by PBuckit. Here's a quote that I posted on another forum. It at least for now will allow you to see the pics in these old threads.
"I found a little relief for those of you that are blocked on PB. If you use Google Chrome, you can click on the link below. It will give you an option to add it to Chrome. Then when you click on a pic in PB. You will be able to see it, but you still won't be able to post them on the forum.
If you don't have Google Chrome, you can always get it. I use Firefox myself, but I do have Chrome also."
https://chrome.google.com/webstore/d...fegnfnflicjjgj
As an example, here is a Quote of post #5 in this thread. I had to copy the image and convert it to a jpg with MS paint, then attach it to the post. Kind of a PITA. I haven't been able to make this work on my phone though.
Originally Posted by Mean Max View Post
I think you probably have a bad input shaft bearing, as in the pic below.
I just rebuilt an AX-5 that had the same issue. To answer your question, yes a full rebuild is in order.
Max
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #203 of 212 Old 10-17-2017, 07:43 AM
Mr.B
Mr.B's Avatar
That add on above doesn't seem to be working anymore. Here is a new on that works.
https://chrome.google.com/webstore/d...er-info-dialog
Ham license:
Everyone is Welcome
Mr.B is offline
post #204 of 212 Old 10-17-2017, 12:07 PM
Opihi59
Opihi59's Avatar
I haven't been on the forum as of late, and haven't seen recent traffic on photobucket fixes. If a thread doesn't exist as to how to resurrect our embedded photos, please post one up with all the details for those of us that aren't computer savvy, and it likely it will become a permanent sticky.
I know I have spent countless hours documenting builds, making useful threads with many many photos, and it seems without this fix, they've all been for nothing other than text perhaps. The photos make these threads useful.
Thanks for posting up this potential solution.
Mr.B likes this.
Opihi59 is offline
post #205 of 212 Old 10-17-2017, 12:56 PM
Mr.B
Mr.B's Avatar
I probably will. But it needs to go to all the forums, not just the YJ forum.
Ham license:
Everyone is Welcome
Mr.B is offline
post #206 of 212 Old 10-17-2017, 01:54 PM
Opihi59
Opihi59's Avatar
Our mods are pretty sharp guys--they know when a thread is posted that is germane to multiple sub-forums, they sticky it across the board. If you don't see this happen, a quick PM to your favorite senior mod will yield results. They respond.
Opihi59 is offline
post #207 of 212 Old 10-17-2017, 02:51 PM
Mr.B
Mr.B's Avatar
Here's the link to the thread, I put it in Wrangler General Discussion, so more members can see it.
https://www.jeepforum.com/forum/f176/.../#post39095969
Ham license:
Everyone is Welcome
Mr.B is offline
post #208 of 212 Old 04-23-2018, 01:39 PM
fishadventure
So I'm in the middle of a rebuild and I don't really want to wait for parts. Since this is the reverse idler I'm thinking its a low-risk risk to not replace it. From what I can tell something was dropped in the trans cuz this is the only evidence of damage but there's big pieces of somethings that aren't relatable to these little pieces of chipped teeth
I think someone had a bad 'event,' did a dirty rebuild replacing maybe the mains haft and bearings, and then just did what I'm thinking of doing: reused the chipped gear.
Right now I'm like 75% to buying a new one but I've seen other trans work fine with worse damage (the gear this meshes with is not damaged).
How stupid would it be to reuse it? Reverse gear handles a lot of torque.
Anybody got a used one? New on Amazon is like $50 or $55 (and up of corse!) I'd pay you for it obviously.
post #209 of 212 Old 04-23-2018, 09:04 PM
Opihi59
Opihi59's Avatar
Personally, I'd replace it. Sure reverse isn't used that often, but someone has failed to let the transmission spin down before going into reverse and likely has just jammed it in repeatedly. If you are capable of rebuilding, then the money you save from having to buy new, reman or pay someone else to do it (good luck w that) can be put into making sure you don't go into half measures. Don't compromise for a few bucks; don't have contempt of your own skills. Do it right.
Replace it.
Opihi59 is offline
post #210 of 212 Old 04-24-2018, 07:11 AM
fishadventure
Originally Posted by Opihi59 View Post
Personally... don’t have contempt of your own skills. Do it right. Replace it.
Translated it into Traditional Puritan English: impatience is not a virtue.
Mean Max mentions to not lose this pin for first gear spacer... If you do- or in my case, find it damaged- you can make one. I don't know the "factory" length, but the pin fits at 0.245" long. The undamaged portion of my pin was 0.177"; I cut mine from a 'free coupon' Harbor Freight screw driver shaft that measured 0.1805" diameter. I cut the shaft with a 1/8" disc in the angle grinder, chucked the shaft in a drill, and then while running drill at high speed I cut it to length with the disc grinder like a crude lathe - leaving a tiny center portion I could break off so I didn't lose the piece. Again chucking in the drill I dressed to length and wire brushed the hard edges of both ends on the bench grinder. Or, you could go to hardware store and hope for the best? Making it was faster and guaranteed to fit.
Mr.B likes this.
transmission , rebuild , ax-15 , repair
My 94 rebuild thread trucknut YJ Wrangler Technical Forum 53 06-22-2015 03:45 AM
Major Repair - AX-15 rebuild Mean Max YJ Wrangler Technical Forum 43 02-15-2014 05:01 AM
YJ major rebuild barney9393 YJ Wrangler Technical Forum 5 07-12-2006 06:36 PM
Anyone use Loctite thread repair? sentinal02 YJ Wrangler Technical Forum 9 10-07-2005 02:49 PM
