Main fuel supply line on sending unit/pump assembly - JeepForum.com
post #1 of 1 Old 10-06-2009, 12:59 PM Thread Starter
drum03
drum03's Avatar
I am in the process of installing a new sending unit/pump assembly in my '95 YJ. I mounted the sending unit to the tank just fine, but connecting the fuel hose to the main fuel supply line nipple has been a frustrating chore (to say the least). The steel supply line on the sending unit is visibly larger than the return line next to it. I spent 4 hours (no exaggeration) trying to fit that 5/16" EFI hose onto the supply line. I finally gave up and bought a short section of 3/8" hose and a 3/8" to 5/16" reducer fitting. I know this isn't the stock set-up, but I couldn't, for the life of me, get that 5/16" hose pushed on. Have any of you guys ran into this problem? If so, how did you alleviate the problem?
drum03 is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 10:08 AM
Fuel pump sending unit WhatBump1 TJ Wrangler Technical Forum 3 06-03-2009 07:20 PM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 05:42 PM
Fuel Sending Unit/Pump - 1 unit in an 89? saxsan YJ Wrangler Technical Forum 3 10-01-2007 12:48 PM
'95 Fuel pump/sending unit ? Tnuts YJ Wrangler Technical Forum 1 04-12-2002 12:53 PM
