machining 5.13 gears to fit dana 30 - JeepForum.com
post #1 of 6 Old 05-19-2014, 07:23 AM Thread Starter
vansboarderx
vansboarderx's Avatar
I have a Ford 8.8 I built with 5.13 gears. I haven't built a front end yet. Still have the stock d30. I k ow 5.13 gears aren't made for that axle, but does anyone know of a set of 5.13 gears that is small enough to to fit in there or close to it. I can machine the ring gear down a little and get it in there, but Idk if the bolt pattern and threads match up on the ring gear to bolt right into the existing carrier. I can drill and tap new holes if I have to. That's easy. Any ideas? Thanks
vansboarderx is offline
post #2 of 6 Old 05-19-2014, 07:37 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Do you plan on running the 37" Iroks reliably with this combo?
If so, call Wayne. If not nevermind.
Joe Dillard is offline
post #3 of 6 Old 05-19-2014, 07:38 PM
Norcal_chris
Norcal_chris's Avatar
Dana 44.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #4 of 6 Old 05-20-2014, 09:56 AM
Sparrows
Sparrows's Avatar
Sounds like a bad idea. The pinion gets incredibly small. There is a reason there aren't lower gears made for our hp30.
I would find a different axle...
Cheers
June '13 YJOTM
Sparrows is offline
post #5 of 6 Old 05-22-2014, 05:14 PM Thread Starter
vansboarderx
I found 5.13 for the Dana 30 that's under the new jk's. They aren't even .25 difference in size, and the pinion shaft is about .10 difference. Very little machining. I may give this a try. I'd prefer a different front end, but this is all I can do at the moment financially. I still plan to spin those 37" iroks, but I rarely use 4wd as it is. Just straight mud bogging. Nothing special. I just want to know I have the 4wd incase I need it.
post #6 of 6 Old 05-22-2014, 05:16 PM Thread Starter
vansboarderx
And who is wayne
