Low fuel pressure - JeepForum.com
post #1 of 6 Old 04-15-2019, 05:40 PM Thread Starter
Taylorfoy
Taylorfoy's Avatar
Low fuel pressure
So I put in my fuel cell and I’m not getting very much fuel pressure at the rail only like 20 psi. I looked at the wires and for some reason I had to ground out the gauge wire for the pump to run. I’m confused on why I did that for one lol and two why that would be keeping my Jeep from running and possibly getting enough pressure
Taylorfoy is offline
post #2 of 6 Old 04-15-2019, 07:11 PM
StrippedTorx
StrippedTorx's Avatar
How do you have your fuel lines connected?
StrippedTorx is offline
post #3 of 6 Old 04-15-2019, 08:00 PM Thread Starter
Taylorfoy
Taylorfoy's Avatar
The lines are from the assembly through the floor to the fuel rail
post #4 of 6 Old 04-15-2019, 08:03 PM Thread Starter
Taylorfoy
Taylorfoy's Avatar
I also took the line off the filter and had a buddy cycle the key twice and not very much gas came out maybe about 1/2 or less a inch in the bottom of a medium size bottle. I think the pump I got was trash (it’s spectrum from autozone, I know I know I was in a hurry and made a stupid move) but now I’m hoping that the pump is the issue and that putting a external pump or new assembly will fix it. I’m pretty sure the wires in the old assembly were messed up. And if they weren’t before they are now lol
post #5 of 6 Old 04-15-2019, 10:13 PM
StrippedTorx
I would double check make sure nothing is pinched or loose. But it sounds like your pump. At least over the internet.
post #6 of 6 Old 04-16-2019, 04:42 PM
Boojo35
Originally Posted by Taylorfoy View Post
I looked at the wires and for some reason I had to ground out the gauge wire for the pump to run. Iím confused on why I did that for one lol and two why that would be keeping my Jeep from running and possibly getting enough pressure
You answered your own question.... You have a crappy fuel pump ground.
You need to fill out your profile or give info on what year and powertrain you are running to get better answers.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
Fuel Pressure Regulator pandemic01 YJ Wrangler Technical Forum 7 03-28-2019 11:36 AM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 447 02-02-2019 10:42 PM
Almost stall on stops when engine is hot. High LTFT dynamiccast WJ Grand Cherokee Forum 3 12-07-2018 12:11 PM
No fuel or spark. But everything checks out. 19xj95 XJ Cherokee Technical Forum 10 04-26-2018 10:43 AM
