Looking for part# J3240729 - JeepForum.com
 13Likes
post #1 of 24 Old 10-09-2019, 06:50 PM Thread Starter
MildCharisma
Anyone have a line on where I can find the OEM underhood lamp unit? OEM part #J3240729.
MildCharisma is offline
post #2 of 24 Old 10-09-2019, 06:55 PM
bruinjeeper
bruinjeeper's Avatar
is this for a restoration build?
because if not - that light is useless and can be upgraded for much cheaper and with little effort.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is online now
post #3 of 24 Old 10-09-2019, 07:52 PM
Chrisnvegas
Chrisnvegas's Avatar
I have that light, it comes with an integral mercury switch and is as good as the light bulb installed. 1156 base.
I have not seen a NOS available for years. If you want the real thing, it's going to be a used part. Ebay, Jeep salvage shops, junk yards ect.
End the Ethanol Rip-Off
Chrisnvegas is offline
post #4 of 24 Old 10-09-2019, 11:53 PM
xpage
I cut the wire, added a physical on/off switch then hooked up LED strip lights to the folded sheet metal on the sides of the engine bay and on the firewall. It works pretty well.
xpage is offline
post #5 of 24 Old 10-10-2019, 01:03 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
I just decided I wasn't going to break down after dark.
jbolty, Boojo35, Dhaole and 3 others like this.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #6 of 24 Old 10-10-2019, 09:17 AM Thread Starter
MildCharisma
Like this idea.
Yeah thats the only place I've been able to find it. For a silly price at that.
This seems like the ideal scenario.
No, I was being lazy, saw the open single slot connector and figured I'd just throw something in there. Seems like it would be easy enough to cut something else in with more lighting power.
post #7 of 24 Old 10-10-2019, 11:28 AM
bruinjeeper
Yea... I did as Xpage... put in a manual switch. It was an old LED mini bar ...low draw. And a recycled switch that comes with wiring harnesses. I save all that crap...I can swivel it around to focus the light where needed
20190902_212648_1570724828071.jpg   20190902_212641_1570724879555.jpg   20190905_193502_1570725044837.jpg
~YJOTM MAY '16~
~YJOTM JULY '19~
post #8 of 24 Old 10-10-2019, 01:50 PM Thread Starter
MildCharisma
That's a pretty sweet setup! I am a long way from having an engine bay that clean. Inherited a mess, but that's half the fun.
The under hood lamp is a need since I seem to be diagnosing something every other week, sometimes on the road.
post #9 of 24 Old 10-10-2019, 01:53 PM
Louie4
Injanir
Louie4's Avatar
I would like one too. My stock one broke off and so far Iíve been too lazy to wire up something else.
Sent from my iPhone using Tapatalk
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #10 of 24 Old 10-10-2019, 02:37 PM
jbolty
jbolty's Avatar
except for maybe checking the oil or a jump start I have never found under hood lights to have much value. They never seem to light up where you need to see except in your eyes.
Being a YJ guy I spend a fair amount if time roaming junkyards and have come across a few GM cars that had a nifty light under the hood then pulls out on a wire and has a crank to wind it back in. I grabbed a couple which then sat on the shelf for a year or two until finally deciding that just using a flashlight was way easier tossed them.
"The right to be heard does not necessarily include the right to be taken seriously." óHubert Humphrey
jbolty is offline
post #11 of 24 Old 10-11-2019, 01:19 PM
bruinjeeper
Obviously never worked in my type of context. Public underground parking garage with no light above my spot that I can use because I cant fold the hood all the way back due to the damn fire sprinkler getting in its way. :
My mini light bar spreads the light right across my bay. And I can swivel it easily towards firewall or radiator.
It came on real handy on my PS pump install most recently (I jerry rigged it up while awaiting for the pump to arrive).
Hope I never have to, but I can see its use on the side of the road. My setup anyhow.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #12 of 24 Old 10-11-2019, 05:02 PM
Chrisnvegas
Here's the controversial light in question.
Is it bright enough to perform an appendectomy?
Probably not. Check fluids? Yeah.
IronScott likes this.
post #13 of 24 Old 10-11-2019, 08:16 PM
Boojo35
That light is a common GM part through the same years. Broaden your search.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #14 of 24 Old 10-12-2019, 12:22 AM
Awesome
Awesome's Avatar
I have no idea how you guys keep your engine bay so clean. My splash guards fell off YEARS ago and now every time I drive through anything the underside of my hood gets dirty. It's stained pretty good.
sptrmike and Chrisnvegas like this.
The 4th 5-seater YJ in the world.
Awesome is offline
post #15 of 24 Old 10-12-2019, 09:02 AM
jbolty
jbolty's Avatar
and here is the light I mentioned, it pulls out about 10' and cranks back in
Chrisnvegas likes this.
jbolty is offline
