Looking for Jack recommendations - JeepForum.com
 5Likes
post #1 of 28 Old 11-28-2019, 07:00 PM Thread Starter
BChamberlin
BChamberlin's Avatar
I have a couple inch lift and 33ís. Need a new jack so looking for recommendations.
Sent from my iPhone using Tapatalk
1994 Wrangler YJ
1999 Wrangler TJ [R.I.P.]
2008 Wrangler X
BChamberlin is offline
post #2 of 28 Old 11-28-2019, 07:14 PM
222Doc
222Doc's Avatar
on the lighter side the stock type scissor jack can even lift 35s by the axle, no matter the lift. if its a bit short 2x4x12" block of wood as well as 4x6x12". a small bottle jack as well. will cover the range well. basically all i ever use i real life in many years. some times that scissor can get under things nothing else can, there junk but useful junk. For all the high lifts carried and never used but those others do.
222Doc is online now
post #3 of 28 Old 11-28-2019, 08:12 PM
Bazzer
Bottle jack with the SWaG adaptor
Sent from my iPhone using Tapatalk Pro
Bazzer is offline
post #4 of 28 Old 11-28-2019, 08:52 PM
RockWoRM
RockWoRM's Avatar
IMHO for 33's a good scissor or bottle jack should be all you need. Your standard Hi lift jack is typically only good for meats up to 35's anyway. And they do take up space. But they can be used for unusual situations, albeit rare. I carry both simply b/c I already had a Hi lift, but will usually use a bottle jack for changing a tire.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 28 Old 11-29-2019, 09:07 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
For those who use the stock scissor jack.....it is known to fail without warning. I have seen this firsthand. When it does, it comes crashing down at lightening speed. The screw strips in the threaded block suddenly & all the weight comes down.
shaggyjim likes this.
Joe Dillard is offline
post #6 of 28 Old 11-29-2019, 09:36 AM
jsawduste
2006 YJ Wrangler
Goggle "SafeJack"
jsawduste is offline
post #7 of 28 Old 11-30-2019, 01:27 PM
NHfireLJ
NHfireLJ's Avatar
Pricey but the ARB (or other brands) lift bags / jacks are pretty cool. Air or exhaust power... Used one last winter when a rover threw a tire chain... easy peasy
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #8 of 28 Old 11-30-2019, 01:44 PM
timatoe
timatoe's Avatar
Originally Posted by jsawduste View Post
Goggle "SafeJack"
That's a pretty slick get up, little pricey though.
timatoe is offline
post #9 of 28 Old 11-30-2019, 02:04 PM
Bazzer
Whatís wrong with this?
https://www.swagoffroad.com/SWAG-Bot...adle_p_66.html
Inexpensive and safe to use. I have a Hi-Lift but would only use it to aid recovery. A small bottle jack with this adaptor is all you need.
Bazzer is offline
post #10 of 28 Old 11-30-2019, 09:17 PM Thread Starter
BChamberlin
Doesnít anyone sell something you donít have to take somewhere to get welded?
1994 Wrangler YJ
2008 Wrangler X
post #11 of 28 Old 11-30-2019, 09:23 PM
paulhead
if it works fix it
paulhead's Avatar
I got one of these, just haven't found a place to mount it yet. I use the hell out of it at home. Tractor Supply has them too.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
timatoe, Blob and IronScott like this.
Trying to weld has honed my grinding skills
paulhead is offline
post #12 of 28 Old 12-01-2019, 06:25 AM
jay-h
A decent hydraulic bottle jack (with some spacer boards to put it on for both stability and height) is a practical choice, and not too expensive. There are also folding jack stands you can use for a safety while working
[I've never had to change one of my tires on the trail, but my jack has been used by others several times]
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #13 of 28 Old 12-01-2019, 06:46 AM
NHfireLJ
NHfireLJ's Avatar
https://www.ebay.com/i/264297229034?...hoCqlwQAvD_BwE
SOLD
style intake
NHfireLJ is offline
post #14 of 28 Old 12-01-2019, 03:55 PM Thread Starter
BChamberlin
I have a Hi-Lift. Isnít that safe enough to use to get jack stands under it? Iíd never work under a Jeep thatís only supported by a Hi-Lift. Thatís suicide.
1994 Wrangler YJ
2008 Wrangler X
post #15 of 28 Old 12-01-2019, 06:11 PM
bpounds
bpounds's Avatar
A Hi-lift is for extrication from stucks. You can change a tire with it, but it's just a PITA to use because it isn't meant for that job. Risky too. And this is coming from someone who carries a Hi-Lift off-roading.
For side of the road tire changes, I just carry the stock jack under the hood. It's as safe as any jack, and none of them are risk free, nor idiot proof.
For repair and maintenance at home in the driveway, a $69 Harbor Freight floor jack gets the call. That's what gets used more than anything. Due to the fact that I don't get stuck and don't get flat tires, if I can help it.
I've got a couple of hydraulic bottle jacks. Used them for lifting the house. Wouldn't have much use for one under the vehicles.
It's December, so I guess it's time for our monthly "which jack" thread.
paulhead likes this.
Bill
Jeepers drive high!
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
