Locker in a Dana 35 c clip? - Page 2 - JeepForum.com
 3Likes
post #16 of 22 Old 03-16-2014, 01:37 AM
fratis
fratis's Avatar
Originally Posted by lpukas2 View Post
From my experience, my lunch box lockers where way more forgiving then the detriots I have now, you can not put them into the same category.
They aren't in the same category. One is a full case unit and one is not. They do, however, do the same thing. They either lock and unlock or they don't meaning they either work or don't work.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #17 of 22 Old 03-16-2014, 01:47 AM
92 Green YJ
92 Green YJ's Avatar
Here ya go. My Dana 35c. It was open. Running 35s on steel wheels. It blew up on my driving on the freeway to the local parts place. A few of the ring gear bolts decided to shear. A chunk of which was shot thru the diff cover punching a hole in it and causing most of the fluid to drain out. Other chunks tore up the ring and pinion and housing pretty good. That being said, I got new bolts from the parts house whose lot I wound up in. Tore it apart, cleaned it up as best I could and removed the busted metal shavings, slapped it all back together and wheeled it that weekend and drove it for a month while I bought and built up my 8.8 to replace it.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #18 of 22 Old 01-26-2019, 02:46 PM
GChief
Junior Member
GChief's Avatar
Originally Posted by JohnnyZJ View Post
i'm putting a locrite in my D35.
i'm going to start a wheeling/driving journal to see how long it goes before I grenade it. knowing me it will be the first time out.
8.8 eventually after the baby is born and the wifes working again.
Resurrection time. I am getting ready to do the same in a ZJ overland build. How did that work out for your?
GChief is offline
post #19 of 22 Old 01-26-2019, 06:45 PM
bruinjeeper
bruinjeeper's Avatar
....ummh. his last activity appears to be April 2016. I think he grenaded his D35 and bought a 2007 JKU.
Do things right, and do it once. Swap the axle to something stronger.
NHfireLJ and GChief like this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #20 of 22 Old 01-31-2019, 03:41 AM
GChief
Junior Member
GChief's Avatar
Thanks, the plan was to swap the axles since I'll be in there anyway.
GChief is offline
post #21 of 22 Old 02-01-2019, 12:58 PM
fishadventure
fishadventure's Avatar
He means take out the D35 and put in a 8.8 or D44. Not just the internal axles.
The 8.8 isn’t that expensive btw
bruinjeeper likes this.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is online now
post #22 of 22 Old 02-01-2019, 04:19 PM
bruinjeeper
Thanks fish.
Picked my 8.8 4.10s open up for 75-80$ish... can't recall.
Ya. GREAT deal.
~YJOTM MAY '16~
~YJOTM JULY '19~
axle , c clip , dana 35 , differential , locker
