Location of the Crankcase? - JeepForum.com
post #1 of 7 Old 11-05-2019, 11:04 AM Thread Starter
Fishstic
Fishstic's Avatar
For a 4.0 l6, about to get it cleaned out.
Sent from my Pixel 3a XL using Tapatalk
Fishstic is offline
post #2 of 7 Old 11-05-2019, 12:20 PM
Chrisnvegas
Chrisnvegas's Avatar
The oil pan?
Is this about sludge?
Be careful if it is.
"Alferd Packer: ďStand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is offline
post #3 of 7 Old 11-05-2019, 02:06 PM Thread Starter
Fishstic
Fishstic's Avatar
Originally Posted by Chrisnvegas View Post
The oil pan?
Just some light sludge nothing to worry about, but would rather clean it out now before it gets worse.
Fishstic is offline
post #4 of 7 Old 11-05-2019, 02:42 PM
Chrisnvegas
If it's light, I would clean by doing frequent oil changes. Lots of damage can occur by chipping away. If the oil pressure is ok and the engine is running well, I wouldn't be too concerned.
post #5 of 7 Old 11-05-2019, 05:45 PM
Boojo35
1987 YJ Wrangler
I agree with @Chrisnvegas . Chipping away at sludge can create particles that clog the oil pump pick up screen and starve the engine for oil. Frequent oil changes will help but throw a half a quart of ATF in your oil about 500 miles or so before you change your oil.
Not really clear from your post though where your sludge is and how you are cleaning it.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #6 of 7 Old 11-05-2019, 06:55 PM
Siva283
Siva283's Avatar
Stirring up dirt in an oil system is never a good idea.
Ask me how I know...
Siva283 is offline
post #7 of 7 Old 11-06-2019, 12:48 PM
Bazzer
How do you know youíve got sludge in the crankcase without removing it? the crankcase I mean. If itís off then itís a simple matter to clean, if itís still on the vehicle then you can flush it. But normal oil changing is more than sufficient to keep it clean, thatís what the oil filter is for.
Sent from my iPhone using Tapatalk Pro
Bazzer is offline
