Lift before regearing? - JeepForum.com
 1Likes
  • 1 Post By jbolty
post #1 of 9 Old 05-21-2021, 04:43 PM Thread Starter
DeeDubz
1987 YJ Wrangler
I have a 87 YJ that I wanna put a 2.5 or 4 inch lift on. It needs to be regeared. My top speed on the freeway is 55mph at 3600rmp. My question is which one should I do first or does it even matter?
DeeDubz is offline
post #2 of 9 Old 05-21-2021, 05:29 PM
jbolty
Administrator
jbolty's Avatar
does not really matter except lift means change in tires which affects gearing. If you have the axles pulled to regear do the lift at the same time and save effort. so I guess the answer is both at once.
what motor, trans, what gears do you have. what tires are you wanting?
jbolty is offline
post #3 of 9 Old 05-21-2021, 07:41 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Pretty much what @jbolty said.
55 MPH at 3600 rpm seems like you are over-geared. Higher RPM at speed as a result of too tall of a gear.
Are you running a 5 speed or a 3-speed auto?
at 2.5" of lift you could run 32 or 33 inch tires (depending upon the lift) what size tires do you have now?
What size tire are you considering after the lift?
Here is a calculator tool you can use to determine your RPM at Speed based upon your info: http://www.grimmjeeper.com/gears.html
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #4 of 9 Old 05-22-2021, 05:16 AM
Boojo35
1987 YJ Wrangler
I am curious if you are running the factory tach converted to your SBC and if it is accurate. 3600 at 55 is a lot of RPM's and suggests that the tach either is not accurate or you already have a steep gear in it. My 87 3 speed auto turns 3200 RPM at 70 MPH. I have 30's and 3.55 gears.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #5 of 9 Old 05-22-2021, 07:53 AM
Waternut
Waternut's Avatar
Definitely sounds like the tach is wrong to me.
Waternut is offline
post #6 of 9 Old 05-25-2021, 02:23 PM Thread Starter
DeeDubz
1987 YJ Wrangler
ITs a 3 speed auto. Once the tires need to be replaced im going to go with 33s. Thanks for the calculator
The tach is correct I can tell the engine is running high rpm from the noise. Im not sure what kind of gears I have. I hate to ask but how would one find out?
DeeDubz is offline
post #7 of 9 Old 05-25-2021, 02:37 PM
jbolty
Administrator
jbolty's Avatar
foolproff way is to take off the diff cover and count the teeth on the ring and pinion. The number is probably etched in as well but just count them.
Luuca likes this.
jbolty is offline
post #8 of 9 Old 05-25-2021, 06:33 PM
93YJ4FUN
This question is only from reading others information here, so bear with me. This was the first thought that came to me when reading the rpm vs speed the OP posted.
Doesn't the auto come with much lower gear ratio than manual? Is it possible that someone stuck 4.10 manual gears in or did a swap from another YJ not knowing there is a difference? If I remember correctly, the Dana 35 is on the rear and is a pretty weak differential. Maybe the PO had one blow up on him and swapped.
93YJ4FUN is offline
post #9 of 9 Old 05-26-2021, 05:09 AM
Boojo35
1987 YJ Wrangler
Yes. The thought is that if the tach is accurate then the gears have been swapped thus why it is suggested to count the teeth on the ring and pinion.
Boojo35 is offline
